IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6062 Views
  • 14 replies
I have an NEC 2400 IMX connected via a PRI to a 2851 series router which in turn is connected to UCM 6.1 via MGCP. 4 digit dialing works great between NEC phones and the ip phones. DID calls into the IP phones work great. However, when I try to ca...
I am running a backup for UCM and it is hung and refreshing I tried to cancel it and it is still hung. THis is what I am gettingCCM DAB-UCM-PUB1 TCT 100 SUCCESS Wed May 27 11:19:24 EDT 2009 2009-05-27-11-19-24_b_dab-ucm-pub1_ccm_tct.log CCM DAB-UCM-P...
I have a centralized CM 6.1 with two remote sites connected via VPN. The one site is having bad call quality on all calls - doesn't matter if they come in the pots or voip. Not sure why this is happening. When a call comes in local pots I plar to ...
Hi. I'm running CCM 5.1.2 with CAR enabled. I am trying to get a fairly simple report but am new to this and having trouble getting to the right place.Basically I need to know the number of external calls are coming into all extensions. Only external...
tahindley by Level 1
  • 556 Views
  • 3 replies
Resolved! DSP problems
Hello All,Does anyone know how I can update my DSP chip to work with a 2801 router? I have a PVDM2-32 in slot 0. Upon the router bootup the PVDM2 module does not go active. when I do a show voice dsp detail, I get the error message: "in slot 0 are us...
Hello - Have been running CallManager 5.1.1.2000-2 for about 2 years. Have a primary callmanager and secondary. When it was set up the default callmanager group had the primary listed first and the secondary (subscriber) listed second. So - all d...
Hi I am using CCM 4.1(3). I have 2 auto attendant console clients running cluster wide. Both were working fine but today one of the client is keep giving problem. While trying to run the client it says "connecting to server" and stays there forever w...
I need help with a problem, occuring more or less since our last CM Upgrade from 5.2 to 6.1.2Phones(7961, 7911) don't assume changes like locale changes and new added expansion modules(7914).The Phones are resetting normally but afterwards the locale...
