CME Dailing Additional Digits In a Call?
thomas-morgan
I have a CME setup. When i make a call and get an automated service saying "dial one for.... dial two for....." it doesn't recognize when I press 'one' or 'two'...
What am i missing?
What is this functionality called?
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmenetwk.html#pgfId-1066825
Deepak
5 Replies 5
Chris Deren
Sounds like your DTMF method is incorrect on your dial-peers. Please provide "sh run" from the CME router, and explain what trunk type you are using: SIP, PRI, FXO?
Hi Chris,
Thanks for the response, good to know its called DTMF! I'm reluctant to release the configuration for the router because of where it used. Is it possiable you can advise a specific section that would help?
Cheers, Tom.
Deepak
Thanks both; that's sorted it!
Glad your issue got resolved and thanks for updating the forum.
Deepak
