02-01-2016 05:51 AM - edited 03-17-2019 05:41 AM
I have a CME setup. When i make a call and get an automated service saying "dial one for.... dial two for....." it doesn't recognize when I press 'one' or 'two'...
What am i missing?
What is this functionality called?
Solved! Go to Solution.
02-01-2016 11:24 PM
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmenetwk.html#pgfId-1066825
Deepak
02-01-2016 09:19 AM
Sounds like your DTMF method is incorrect on your dial-peers. Please provide "sh run" from the CME router, and explain what trunk type you are using: SIP, PRI, FXO?
02-01-2016 11:12 PM
Hi Chris,
Thanks for the response, good to know its called DTMF! I'm reluctant to release the configuration for the router because of where it used. Is it possiable you can advise a specific section that would help?
Cheers, Tom.
02-01-2016 11:24 PM
Deepak
02-02-2016 12:56 AM
Thanks both; that's sorted it!
02-02-2016 12:58 AM
Glad your issue got resolved and thanks for updating the forum.
Deepak
