07-18-2012 06:07 AM - edited 03-16-2019 12:15 PM
i am having a setup with cme ver 8.6 and 3 fxo lines .some time even all the lines are free also user will not be able to make the call it will give busy tone that time i use to shut and no shut the fxo port it will work .Please help me how to resole the issue . i here attached the config below
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
h225 timeout setup 5
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
voice class dualtone-detect-params 1
freq-max-deviation 20
cadence-variation 20
voice class custom-cptone UAE-CPTONE
dualtone disconnect
frequency 400 405
cadence 380 380 400 350 225 525
license udi pid CISCO2911/K9 sn FCZ1540700Z
hw-module pvdm 0/0
username admin password 0 cisco
redundancy
translation-rule 9
Rule 1 ^00 900
Rule 2 ^02 9
Rule 3 ^03 903
Rule 4 ^04 904
Rule 5 ^05 905
Rule 6 ^06 906
Rule 7 ^07 907
Rule 8 ^08 908
Rule 9 ^09 909
i
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description *** Voice Gateway ****
ip address 192.168.50.4 255.255.255.0
ip pim dense-mode
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.50.4
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
ip route 0.0.0.0 0.0.0.0 192.168.50.250
access-list 23 permit 10.10.10.0 0.0.0.7
voice-port 0/0/0
trunk-group FXOPORTS
translation-profile incoming incomming
translate calling 9
supervisory disconnect dualtone mid-call
supervisory custom-cptone UAE-CPTONE
supervisory dualtone-detect-params 1
input gain 14
compand-type a-law
cptone AE
timeouts call-disconnect 1
timeouts wait-release 1
connection plar opx 5000
shutdown
caller-id enable
voice-port 0/0/1
translate calling 9
input gain 14
compand-type a-law
cptone AE
caller-id enable
voice-port 0/0/2
translate calling 9
input gain 14
compand-type a-law
cptone AE
caller-id enable
voice-port 0/0/3
input gain 14
compand-type a-law
cptone AE
connection plar opx 5001
description **** MANAGER DIRECT LINE ****
caller-id enable
Solved! Go to Solution.
07-18-2012 07:16 AM
Also remove the compound type from your FXO analogue voice ports as this can cause issues.
The compound type is used for digital technology like ISDN/BRI
voice-port 0/0/0
no compand-type a-law
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
Alex.
Please rate useful posts.
07-18-2012 06:55 AM
Most likely, your custom cptone configuration is incorrect.
07-18-2012 07:16 AM
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
Alex.
07-18-2012 07:23 AM
Thanks paolo
Do you have any sample config for CPtone for UAEregion
07-18-2012 07:35 AM
Raja,
Try this website
http://www.3amsystems.com/wireline/tone-search.htm
Select your country and tone
You can only search once a day or something like that so get it right 1st time
Alex.
07-18-2012 08:32 AM
You will need to record the tone and analyze.
I used to have a router in Dubai, but i think I've since lost its configuration.
