CME FXO PORT BUSY
VKMH
Hi All
I have configured cme 2921 router and 7 PSTN line.  When there is incoming and outgoing  calls, an available port will indicate a green light but after the incoming and outgoing call stops, green still there and need to restart the cme again. please check the running configuration
LCC-SIPOREX-CME#sh run
Building configuration...
Current configuration : 34678 bytes
! Last configuration change at 10:28:15 UTC Wed Mar 4 2015
version 15.3
hostname LCC-SIPOREX-CME
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 4 tnhtc92DXBhelxjYk8LWJrPV36S2i4ntXrpb4RFmfqY
enable password admin
no aaa new-model
clock timezone UTC 3 0
ip cef
ip dhcp excluded-address 192.1.1.1 192.1.1.109
ip dhcp excluded-address 192.1.1.200 192.1.1.255
ip dhcp pool 1
 network 192.1.1.0 255.255.255.0
 default-router 192.1.1.111
 option 150 ip 192.1.1.111
 dns-server 192.1.1.104
no ip domain lookup
ip domain name yourdomain.com
no ipv6 cef
trunk group fxo
 voice-class cause-code 1
 hunt-scheme longest-idle
trunk group SIPOREX
 description "Local landline numbers"
 hunt-scheme random
crypto pki trustpoint TP-self-signed-1480474283
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1480474283
 revocation-check none
 rsakeypair TP-self-signed-1480474283
crypto pki certificate chain TP-self-signed-1480474283
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31343830 34373432 3833301E 170D3132 30383037 31303231
  30305A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 34383034
  37343238 3330819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100CE31 54464708 8BC3C22D 347D958E 3AE36BBC 16C56FA2 BD8290E5 D732A779
  FA3EFE94 CB157EA8 2F6BB3AB 7993733A 5F74188B 46D1420C FF20223D 33807E92
  667FE112 C93EF28F 60F4695D 821128CD 82A4B33E 53F15888 BC2B16E3 3CAB0B31
  6DEF8109 882CC001 E5098472 721ABAE2 D2A458E7 E16716AA C3D5723D 38E55222
  62170203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 1477083B A9425D93 CCEB3715 1B69E262 F618B88E 16301D06
  03551D0E 04160414 77083BA9 425D93CC EB37151B 69E262F6 18B88E16 300D0609
  2A864886 F70D0101 05050003 8181007D 071BDAD1 7A89C0D2 54382FCB 74881C0E
  524784C5 972E41CA 0CF827D4 8523F08D EDB74400 FD493D5D 6EDE52B2 A8D68A09
  20490C72 C9B21662 770B5B94 0B96A360 B83B20E7 5295A1AF C0A44518 0B022122
  A666CBBF B803B8CD CB183A28 4E261E71 823DCF69 D185892E 57DA8B3A BE22EDA5
  E7CA8354 9504B0F0 A8AE5F16 0D6329
        quit
voice-card 0
 dspfarm
 dsp services dspfarm
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service h450.2
 no supplementary-service h450.3
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 h323
 sip
  registrar server expires max 300 min 60
voice class codec 1
 codec preference 1 g711ulaw
voice class custom-cptone STC
 dualtone disconnect
  frequency 425
  cadence 250 250
voice register global
 mode cme
 source-address 192.1.1.111 port 5060
 max-dn 40
 max-pool 20
 load 8961 sip8961.9-2-2SR1-9.loads
 authenticate register
 authenticate realm all
 timezone 31
 mwi reg-e164
 voicemail 999
 tftp-path flash:
 create profile sync 0516821625812883
 camera
 video
voice register dn  1
 number 0
 call-forward b2bua noan 999 timeout 20
 allow watch
 pickup-group 555
 name Operator
 label Operator
voice register template  1
 feature-button 1 GpickUp
 feature-button 2 Trnsfer
 softkeys hold  Newcall Resume iDivert
 softkeys idle  Newcall DND Gpickup Cfwdall Redial
 softkeys seized  Redial Endcall Gpickup Meetme
 softkeys connected  Endcall Park iDivert Confrn Hold Trnsfer
voice register pool  1
 id mac 1CAA.0710.0AC1
 type 8961 addon 1 CKEM
 number 1 dn 1
 template 1
 dtmf-relay rtp-nte sip-kpml sip-notify
license udi pid CISCO2921/K9 sn FCZ163270CP
hw-module ism 0
hw-module pvdm 0/0
file privilege 0
username admin privilege 15 password 0 julay102008
redundancy
interface Loopback0
 ip address 172.16.1.1 255.255.255.0
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
 ip address 192.1.1.111 255.255.255.0
 duplex auto
 speed auto
interface ISM0/0
 ip unnumbered Loopback0
 service-module ip address 172.16.1.2 255.255.255.0
 !Application: CUE Running on ISM
 service-module ip default-gateway 172.16.1.1
interface GigabitEthernet0/1
 ip address 192.168.1.159 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface ISM0/1
 description Internal switch interface connected to Internal Service Module
 no ip address
interface Vlan1
 no ip address
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:/GUI
ip route 172.16.1.2 255.255.255.255 ISM0/0
tftp-server flash:sip8961.9-2-2SR1-9.loads
tftp-server flash:xml-test.html
tftp-server flash:home.shtml
tftp-server html
tftp-server flash:/GUI
control-plane
voice-port 0/0/0
 trunk-group SIPOREX
 supervisory disconnect dualtone mid-call
 supervisory custom-cptone STC
 no battery-reversal
 input gain 3
 cptone BE
 timeouts initial 0
 timeouts interdigit 2
 timeouts call-disconnect 1
 timeouts ringing 5
 timeouts wait-release 3
 connection plar 888
 impedance complex2
 caller-id enable
 caller-id alerting line-reversal
 caller-id alerting dsp-pre-allocate
voice-port 0/0/1
 trunk-group SIPOREX
 no battery-reversal
 input gain 3
 cptone BE
 timeouts initial 0
 timeouts ringing 5
 connection plar 888
 impedance complex2
 caller-id enable
voice-port 0/0/2
 trunk-group SIPOREX
 no battery-reversal
 input gain 14
 cptone BE
 timeouts initial 0
 timeouts call-disconnect 3
 timeouts ringing 5
 connection plar 888
 impedance complex2
 caller-id enable
voice-port 0/0/3
 trunk-group SIPOREX
 no battery-reversal
 input gain 14
 cptone BE
 timeouts initial 0
 timeouts ringing 5
 connection plar 888
 impedance complex2
 caller-id enable
voice-port 0/1/0
 trunk-group SIPOREX
 no battery-reversal
 input gain 14
 cptone BE
 timeouts initial 0
 timeouts ringing 5
 connection plar 888
 impedance complex2
 caller-id enable
voice-port 0/1/1
 trunk-group SIPOREX
 no battery-reversal
 input gain 14
 cptone BE
 timeouts initial 0
 timeouts ringing 5
 connection plar 888
 impedance complex2
 caller-id enable
voice-port 0/1/2
 trunk-group SIPOREX
 no battery-reversal
 input gain 14
 cptone BE
 timeouts initial 0
 timeouts ringing 5
 connection plar 888
 impedance complex2
 caller-id enable
voice-port 0/1/3
 trunk-group SIPOREX
 no battery-reversal
 input gain 14
 cptone BE
 timeouts initial 0
 timeouts ringing 5
 connection plar 888
 impedance complex2
 caller-id enable
voice-port 0/2/0
 input gain 14
 timeouts initial 0
 timeouts ringing 5
 connection plar 888
 shutdown
 caller-id enable
voice-port 0/2/1
 input gain 14
 timeouts initial 0
 timeouts ringing 5
 connection plar 888
 shutdown
 caller-id enable
voice-port 0/2/2
 input gain 14
 timeouts initial 0
 timeouts ringing 5
 connection plar 888
 shutdown
 caller-id enable
voice-port 0/2/3
 input gain 14
 timeouts initial 0
 timeouts ringing 5
 connection plar 888
 shutdown
 caller-id enable
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 192.168.1.111 identifier 1 version 7.0
sccp
sccp ccm group 1
 associate ccm 1 priority 1
 associate profile 1 register conference
dspfarm profile 1 conference
 codec g711ulaw
 codec g711alaw
 codec g729ar8
 codec g729abr8
 codec g729r8
 codec g729br8
 maximum sessions 2
 associate application SCCP
dial-peer cor custom
 name internal
 name local
 name national
 name mobile
 name international
 name servicecall
 name 800
 name 9200
dial-peer cor list internal
 member internal
dial-peer cor list local
 member local
dial-peer cor list national
 member national
dial-peer cor list mobile
 member mobile
dial-peer cor list international
 member international
dial-peer cor list Restricted
 member internal
dial-peer cor list LocalCalls
 member internal
 member local
 member servicecall
 member 800
 member 9200
dial-peer cor list LongDistance
 member internal
 member local
 member national
 member mobile
 member servicecall
 member 800
 member 9200
dial-peer cor list International
 member internal
 member local
 member national
 member mobile
 member servicecall
 member 800
 member 9200
dial-peer cor list 800
 member 800
dial-peer cor list 9200
 member 9200
dial-peer cor list servicecall
 member servicecall
dial-peer voice 666 voip
 description " Dial-Peer for CUE VM "
 destination-pattern 999
 session protocol sipv2
 session target ipv4:172.16.1.2
 dtmf-relay h245-alphanumeric h245-signal rtp-nte sip-notify
 codec g711ulaw
 no vad
dial-peer voice 101 voip
 description " Dial-Peer for CUE AA"
 destination-pattern 888
 codec g711ulaw
 no vad
dial-peer voice 3 pots
 trunkgroup SIPOREX
 corlist outgoing mobile
 destination-pattern 905[056].......
 prefix 05
dial-peer voice 4 pots
 trunkgroup SIPOREX
 corlist outgoing national
 destination-pattern 90[234679].......
 prefix 0
dial-peer voice 5 pots
 trunkgroup SIPOREX
 corlist outgoing international
 destination-pattern 900T
 prefix 00
dial-peer voice 6 pots
 trunkgroup SIPOREX
 corlist outgoing local
 destination-pattern 9600T
 prefix 600
dial-peer voice 7 pots
 trunkgroup SIPOREX
 destination-pattern 9800T
 prefix 800
dial-peer voice 20 pots
 trunkgroup SIPOREX
 destination-pattern 9200T
 prefix 200
dial-peer voice 21 pots
 trunkgroup SIPOREX
 corlist outgoing LongDistance
 destination-pattern 905T
 prefix 05
dial-peer voice 22 pots
 trunkgroup SIPOREX
 destination-pattern 904T
 prefix 04
dial-peer voice 23 pots
 trunkgroup SIPOREX
 destination-pattern 908T
 prefix 08
dial-peer voice 24 pots
 trunkgroup SIPOREX
 destination-pattern 909T
 prefix 09
dial-peer voice 1 pots
 trunkgroup SIPOREX
 destination-pattern 9[19]..
 forward-digits 3
dial-peer voice 2 pots
 trunkgroup SIPOREX
 destination-pattern 9[2-8][0-9][1-9]....
 forward-digits 7
dial-peer voice 53 pots
 trunkgroup SIPOREX
 description " Mobile numbers"
 destination-pattern 905........
 forward-digits 10
dial-peer voice 52 pots
 trunkgroup SIPOREX
 description "National lanline numbers"
 destination-pattern 901[1-4,6,7].......
 forward-digits 10
dial-peer voice 51 pots
 trunkgroup SIPOREX
 destination-pattern 9[2,4,6]......
 forward-digits 7
dial-peer voice 60 pots
 trunkgroup SIPOREX
 corlist outgoing 9200
 destination-pattern 99200.....
 forward-digits 9
dial-peer voice 61 pots
 trunkgroup SIPOREX
 corlist outgoing 800
 destination-pattern 9800.......
 forward-digits 10
dial-peer voice 62 pots
 trunkgroup SIPOREX
 corlist outgoing servicecall
 destination-pattern 990.
 forward-digits 3
dial-peer voice 63 pots
 trunkgroup SIPOREX
 destination-pattern 99200......
 forward-digits 10
dial-peer voice 100 pots
 destination-pattern 9T
 port 0/0/0
dial-peer voice 102 pots
 port 0/0/2
dial-peer voice 103 pots
 port 0/0/3
dial-peer voice 104 pots
 port 0/0/1
dial-peer voice 105 pots
 port 0/1/0
dial-peer voice 106 pots
 port 0/1/1
dial-peer voice 107 pots
 port 0/1/2
dial-peer voice 108 pots
 port 0/1/3
presence
 presence call-list
sip-ua
 presence enable
gatekeeper
 shutdown
telephony-service
 sdspfarm units 3
 sdspfarm tag 1 conference
 conference hardware
 conference transfer-pattern
 video
 no auto-reg-ephone
 max-ephones 100
 max-dn 250
 ip source-address 192.1.1.111 port 2000
 system message LCC_SIPOREX
 time-zone 31
 date-format dd-mm-yy
 voicemail 999
 mwi reg-e164
 max-conferences 8 gain -6
 call-park system application
 call-forward pattern 2..
 call-forward pattern .T
 web admin system name admin secret 5 $1$/z7v$KeMByYJJaRhqQzQmfsJpn0
 dn-webedit
 time-webedit
 transfer-system full-consult
 transfer-pattern 2..
 transfer-pattern .T
 transfer-pattern ...
 create cnf-files version-stamp 7960 Dec 23 2014 15:38:58
ephone-dn  1  dual-line
 number 221
 description Mr. Yassir Hayat
 name Mr. Yassir Hayat
 call-forward busy 999
 call-forward noan 999 timeout 15
 corlist incoming LongDistance
ephone-dn  2  dual-line
 number 227
 pickup-group 555
 description Mr. Abdulhakim Assaf
 name Mr. Abdulhakim Assaf
 call-forward noan 999 timeout 10
ephone-dn  3  dual-line
 number 223
 description Mr.Shakir.Mohd
 name Mr.Shakir.Mohd
ephone-dn  5  dual-line
 number 225
 description Cashier
 name Cashier
 corlist incoming Restricted
ephone-dn  6  dual-line
 number 226
 description Mr.Muntasir
 name Mr.Muntasir
ephone-dn  7  dual-line
 number 243
 pickup-group 555
 description GM Secretary
 name Mr. Federico Lumibao
 corlist incoming International
please update ASNP
Thank You
5 Replies 5
Hello
 Can you please add timing guard-out 1000 command under voice port and check how it is going.
Afsal Abdul Gafoor
Hi Dear
thanks fore your reply
i try to this command  but still same issue please check attached file
any more configuration needed my cme.
thank you
Is there any specific reason to disable battery reversal? If no, try to use with battery reversal.
Vivek
Hi vivek
i try to use battery reversal but the port same issue  please check the voice-call status
LCC-SIPOREX-CME#show voice call status
CallID     CID  ccVdb      Port        Slot/DSP:Ch  Called #   Codec    MLPP Dia
l-peers
0x15BE     3924 0x3D1534D0 0/0/1            No DSP  998        None     104/102
0x15C4     3924 0x222EE680 0/0/2            No DSP *998        None      102/104
0x15C5     3931 0x40FE13D0 0/0/0            0/1:1   240        g711ulaw 100/2001
6
0x15CC     3931 0x3D620F68 50/0/19.0               *240        g711ulaw  20016/1
00
2 active calls found
LCC-SIPOREX-CME#
l-peers
0x1699     3ACC 0x40FE13D0 0/0/0            No DSP  998        None     100/102
0x169F     3ACC 0x222EE680 0/0/2            No DSP *998        None      102/100
0x16A0     3AD9 0x3D1534D0 0/0/1            No DSP  998        None     104/105
0x16A7     3AD9 0x40FE3C40 0/1/0            No DSP *998        None      105/104
0x16AE     3AF1 0x22BA0BA8 50/0/49.0                0556014210 g711ulaw 20045/10
0x16B4     3AF1 0xC0C1F7B0 0/0/3            0/1:1  *0556014210 g711ulaw  103/200
45
0x16C2     3B0B 0x22B79054 50/0/37.0                223        g711ulaw 20034/20
003
0x16C3     3B0B 0x3D470ABC 50/0/3.0                *223        g711ulaw  20003/2
0034
4 active calls found
but the still no active calls
pales tell me any another configuration needed
thank you
This is the incoming call to reception phone please check the situation no 1,2
1.       SITUATION NO. 1
                Caller                     :               dialed 4981800
                FXO port 0           :               green light ON
Siporex                 :               phone automatic answering voice will start( welcome to lcc siporex please dial the required extension)
                Caller                     :               dialed “0” operator
                Siporex                 :               nobody picking up the call
                CME                       :               “there is no voice mail associated with this extension, wait while I transfer your call”
                FXO port 1           :               green light ON
                Caller                     :               hang up  the call
                FXO port 0           :               green light still ON
                I think for incoming calls, if nobody answers the call, green still ON forever even if the caller hang up the call.
2.       SITUATION NO. 2
Siporex                 :               operator answers the call and transferred to a extension
Siporex Extension:          answers the call
FXO port 0           :               green light is OFF
I think for incoming calls, if siporex  answers the call, green will turn OFF when the caller or receiver hang up the phone.
Note:    CME should not transfer the call if there is no associated voice mail in a phone handset.
