05-18-2016 10:43 AM - edited 03-17-2019 06:57 AM
We have a smaller site we support with an aging call manager, recently a new firewall was installed which caused some issues.
At this time however we can talk to the networks, all IPs ping each other but we cannot get the GUI to load for CME or CUE.
The local tech says he used to manage the system using this link 10.6.29.2/Web/Common/HomePage.
Although I can ping the IP 10.6.29.2 we cannot access gui. Nothing to my knowledge was changed on the CME. and the firewall shows the traffic pasing thru but timing out..
Gui is loaded in flash:
60 -rw- 2410 Jan 21 2008 16:47:22 -06:00 telephony_service.html
Some configs:
ip route 10.6.29.2 255.255.255.255 Service-Engine1/0
interface Service-Engine1/0
description *** NM-CUE ***
ip unnumbered GigabitEthernet0/1
ip broadcast-address 0.0.0.0
service-module ip address 10.6.29.2 255.255.255.0
service-module ip default-gateway 10.6.29.2
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
CME-HGGG#sh telephony-service
CONFIG (Version=4.1(0))
Version 4.1(0)
Cisco Unified CallManager Express
For on-line documentation please see:
www.cisco.com/univercd/cc/td/doc/product/access/ip_ph/ip_ks/index.htm
ip source-address 10.6.29.1 port 2000
load ata ATA030100SCCP040211A
load 7914 S00104000100
load 7960-7940 P0030702T023
max-ephones 168
max-dn 500
max-conferences 12 gain -6
dspfarm units 0
dspfarm transcode sessions 0
conference software
hunt-group report delay 1 hours
Number of hunt-group configured: 2
hunt-group logout DND
max-redirect 15
voicemail 88500
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] US (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line mode is single
moh music-on-hold.au
time-format 12
date-format mm-dd-yy
timezone 0 Greenwich Standard Time
url directories http://10.1.1.40/ccmpd/xxxxdir.xml
url services http://10.6.29.2/voiceview/common/login.do
url authentication http://10.6.29.2/voiceview/authentication/authenticate.do
call-forward pattern .T
transfer-pattern .T
after-hours block pattern 1 918005551212 7-24
after-hours block pattern 2 91900 7-24
after-hours block pattern 3 91411 7-24
after-hours block pattern 4 91...411....
after-hours block pattern 5 9411
night-service code *789
night-service day Sun 00:00 23:59
night-service day Mon 17:00 07:59
night-service day Tue 17:00 07:59
night-service day Wed 17:00 07:59
night-service day Thu 17:00 07:59
night-service day Fri 17:00 07:59
night-service day Sat 00:00 23:59
keepalive 30
timeout interdigit 5
timeout busy 20
timeout ringing 180
caller-id name-only: enable
system message xxxxx
web admin system name xxxx password xxxx
web admin customer name Customer
edit DN through Web: enabled.
create cnf-files version-stamp 7960 May 18 2016 07:58:30
transfer-system full-consult
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
Any help will be appreciated..
-Dennis
05-18-2016 11:21 AM
Dennis,
Did you try
http://10.6.29.2/ccme.html yet?
Also, you might want to include contents of flash where GUI files are located in your next post.
Sami
05-26-2016 08:29 AM
I should have clarified this earlier. I cannot access GUI from http://10.6.29.1/ccme.html
I also cannot access via: http://10.6.29.2/ccme.html
The local contact says they used http://10.6.29.2/Web/Common/HomePage.do ? to make all changes in the past which is why i referenced that IP.
I am able to ping to and from both IPs but no gui.
Any ideas?
05-26-2016 08:29 AM
Do you have "file privilege 0" command in cme router ? Pls check it once.
Suresh
05-26-2016 08:56 AM
It is not configured and I am unable to add it.
CME-HGC(config)#file privilege 0
% Invalid input detected at '^' marker.
Version 12.4(11)XJ, RELEASE SOFTWARE (fc1)
System image file is c3825-ipvoicek9-mz.124-11.XJ.bin
05-26-2016 09:25 AM
Oopss..you have quite old version, actually this command was introduced in 15.1.X version.
Can you take ethereal capture so you will get you know if any port block issue, you need to verify port 80 (HTTP) or 443 (Secure/HTTPS) specially.
Suresh
05-26-2016 09:30 AM
Yes very old version which is scheduled to be upgraded.
I'll have to coordinate with a local onsite resource but yes I can grab a capture and look for any blocking.
05-26-2016 09:33 AM
Hey Dennis,
You need to run this command inside telephony service.
You can also try debugging http sessions
debug ip http all and debug ip http error
Also check any ACL for port 80 (HTTP) or 443 (Secure/HTTPS) on new FW.
05-18-2016 11:22 AM
You open CME GUI using below:
http://router_ipaddress/ccme.html
where router_ipaddress is the IP address of your Cisco Unified CME router. For example, if the IP address of your Cisco Unified CME router is 10.10.10.176, enter the following:
http://10.10.10.176/ccme.html
If the above does not help, then review your settings as per the below guide:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmegui.html
Deepak
05-18-2016 11:43 AM
Yes, I have been trying at the proper address but it does not respond.
DIR of flash.
irectory of flash:/
1 -rw- 34237100 Dec 27 2007 21:07:32 -06:00 c3825-ipvoicek9-mz.124-11.XJ.bin
2 -rw- 1826 Aug 6 2007 23:56:48 -05:00 sdmconfig-38xx.cfg
3 -rw- 6036480 Aug 6 2007 23:57:20 -05:00 sdm.tar
4 -rw- 861696 Aug 6 2007 23:57:36 -05:00 es.tar
5 -rw- 1164288 Aug 6 2007 23:57:52 -05:00 common.tar
6 -rw- 1038 Aug 6 2007 23:58:06 -05:00 home.shtml
7 -rw- 113152 Aug 6 2007 23:58:18 -05:00 home.tar
8 -rw- 1697952 Aug 6 2007 23:58:38 -05:00 securedesktop-ios-3.1.1.45-k9.pkg
9 -rw- 416354 Aug 6 2007 23:58:56 -05:00 sslclient-win-1.1.3.173.pkg
11 -rw- 660 Dec 27 2007 21:50:00 -06:00 vlan.dat
12 -rw- 129476 Jan 17 2008 22:26:02 -06:00 P0030702T023.bin
13 -rw- 459 Jan 17 2008 22:26:24 -06:00 P0030702T023.loads
14 -rw- 685334 Jan 17 2008 22:26:40 -06:00 P0030702T023.sb2
15 -rw- 129880 Jan 17 2008 22:26:56 -06:00 P0030702T023.sbn
16 -rw- 281506 Jan 17 2008 22:27:12 -06:00 ATA030100SCCP040211A.zup
17 -rw- 49599 Jan 17 2008 22:27:34 -06:00 S00105000200.sbn
18 -rw- 49169 Jan 17 2008 22:27:52 -06:00 S00104000100.sbn
19 -rw- 650 Jan 17 2008 22:28:02 -06:00 RingList.xml
20 -rw- 651 Jan 17 2008 22:28:22 -06:00 DistinctiveRingList.xml
21 -rw- 4000 Jan 17 2008 22:28:40 -06:00 Ring1.raw
22 -rw- 4000 Jan 17 2008 22:28:52 -06:00 Ring2.raw
23 -rw- 4000 Jan 17 2008 22:29:02 -06:00 Ring3.raw
24 -rw- 4000 Jan 17 2008 22:29:58 -06:00 Ring4.raw
25 -rw- 4000 Jan 17 2008 22:30:10 -06:00 Ring5.raw
26 -rw- 4000 Jan 17 2008 22:30:24 -06:00 Ring6.raw
27 -rw- 4000 Jan 17 2008 22:31:28 -06:00 Ring7.raw
28 -rw- 4627 Jan 21 2008 16:46:36 -06:00 admin_user.html
29 -rw- 653523 Jan 21 2008 16:46:38 -06:00 admin_user.js
30 -rw- 2455679 Jan 21 2008 16:46:46 -06:00 apps11.8-2-2ES1.sbn
31 -rw- 2453223 Jan 21 2008 16:46:52 -06:00 apps41.8-2-2ES1.sbn
32 -rw- 1029 Jan 21 2008 16:46:52 -06:00 CiscoLogo.gif
33 -rw- 618 Jan 21 2008 16:46:52 -06:00 CME_GUI_README.TXT
34 -rw- 439073 Jan 21 2008 16:46:54 -06:00 cnu11.8-2-2ES1.sbn
35 -rw- 435144 Jan 21 2008 16:46:56 -06:00 cnu41.8-2-2ES1.sbn
36 -rw- 2146813 Jan 21 2008 16:47:02 -06:00 cvm11sccp.8-2-2ES1.sbn
37 -rw- 2141085 Jan 21 2008 16:47:08 -06:00 cvm41sccp.8-2-2ES1.sbn
38 -rw- 953 Jan 21 2008 16:47:08 -06:00 delete.gif
39 -rw- 16344 Jan 21 2008 16:47:08 -06:00 dom.js
40 -rw- 864 Jan 21 2008 16:47:08 -06:00 downarrow.gif
41 -rw- 302171 Jan 21 2008 16:47:10 -06:00 dsp11.8-2-2ES1.sbn
42 -rw- 509001 Jan 21 2008 16:47:12 -06:00 dsp41.8-2-2ES1.sbn
43 -rw- 6146 Jan 21 2008 16:47:12 -06:00 ephone_admin.html
44 -rw- 377390 Jan 21 2008 16:47:12 -06:00 jar11sccp.8-2-2ES1.sbn
45 -rw- 229364 Jan 21 2008 16:47:14 -06:00 jar41sccp.8-2-2ES1.sbn
46 -rw- 4658 Jan 21 2008 16:47:14 -06:00 logohome.gif
47 -rw- 496521 Jan 21 2008 16:47:16 -06:00 music-on-hold.au
48 -rw- 3724 Jan 21 2008 16:47:16 -06:00 normal_user.html
49 -rw- 79908 Jan 21 2008 16:47:16 -06:00 normal_user.js
50 -rw- 129828 Jan 21 2008 16:47:16 -06:00 P00308000400.bin
51 -rw- 461 Jan 21 2008 16:47:18 -06:00 P00308000400.loads
52 -rw- 701768 Jan 21 2008 16:47:20 -06:00 P00308000400.sb2
53 -rw- 130232 Jan 21 2008 16:47:20 -06:00 P00308000400.sbn
54 -rw- 1347 Jan 21 2008 16:47:20 -06:00 plus.gif
55 -rw- 2759 Jan 21 2008 16:47:20 -06:00 Readme7960-40.txt
56 -rw- 662 Jan 21 2008 16:47:20 -06:00 SCCP11.8-2-2SR1S.loads
57 -rw- 642 Jan 21 2008 16:47:20 -06:00 SCCP41.8-2-2SR1S.loads
58 -rw- 843 Jan 21 2008 16:47:22 -06:00 sxiconad.gif
59 -rw- 174 Jan 21 2008 16:47:22 -06:00 tab.gif
61 -rw- 662 Jan 21 2008 16:47:22 -06:00 term06.default.loads
62 -rw- 662 Jan 21 2008 16:47:22 -06:00 term11.default.loads
63 -rw- 642 Jan 21 2008 16:47:22 -06:00 term41.default.loads
64 -rw- 642 Jan 21 2008 16:47:22 -06:00 term61.default.loads
65 -rw- 870 Jan 21 2008 16:47:22 -06:00 uparrow.gif
66 -rw- 9968 Jan 21 2008 16:47:22 -06:00 xml-test.html
67 -rw- 3412 Jan 21 2008 16:47:24 -06:00 xml.template
