CME Hardware Conference using SIP IP Phones not working
a.burlaos
Does anyone encountered the same issue regarding the Hardware Conferencing using SIP IP Phones for CME?
Scenario:
1. Phone A calling Phone B
2. Phone A pressing Conference button and calling Phone C (Phone B is put on hold).
Phone A tried to merge the calls but it is not working.
Note:
1. Hardware Conference bridge status for SCCP is "UP"
2. Debug ephone hw-conference result
*Feb  9 11:16:50.191: Check associated hwconf with callid 3574
*Feb  9 11:16:50.191: Unable to associate a dn/chan with callid 3574
*Feb  9 11:16:56.815: Check associated hwconf with callid 3574
*Feb  9 11:16:56.815: Unable to associate a dn/chan with callid 3574
*Feb  9 11:16:56.815: skinny_hwcfb_check_resource: for Audio
*Feb  9 11:16:56.815:  skinny_hwcfbi_find_next_mtpcb Got MTPCB conference type req 52:Audio only as Audio only Pass
*Feb  9 11:16:56.815: skinny_hwcfb_get_adhoc_number:
*Feb  9 11:16:56.815: skinny_hwcfb_get_adhoc_number : Failed to get ad-hoc conference resource
*Feb  9 11:16:59.515: Check associated hwconf with callid 3583
*Feb  9 11:16:59.515: Unable to associate a dn/chan with callid 3583
*Feb  9 11:17:00.683: Check associated hwconf with callid 3574
*Feb  9 11:17:00.683: Unable to associate a dn/chan with callid 3574
*Feb  9 11:17:02.095: Check associated hwconf with callid 3583
*Feb  9 11:17:02.095: Unable to associate a dn/chan with callid 3583
*Feb  9 11:17:02.799: Check associated hwconf with callid 3574
*Feb  9 11:17:02.803: Unable to associate a dn/chan with callid 3574
Best Regards,
Arvie
2 Accepted Solutions
You do not have ephone-dn in your config with “conference ad-hoc” added.
ephone-dn 1 octo
number A100
conference ad-hoc
no huntstop
Add as many as you want depending upon how many conferences you are looking to host.
“no huntstop” is needed to allow CME to hunt b/w dn’s i.e. inter-dn.
You need it for conference. You won’t assign them to your voice register pools.
20 Replies 20
are your ad-hoc dns octo-lines.
Hello Mohammed,
No.
Cisco 7821 SIP IP Phone configuration.
voice register dn  9
 number 28126
 allow watch
 name EAU - Riche
 label EAU - Riche
voice register pool  9
 busy-trigger-per-button 1
 id mac <ip phone mac address>
 type 7821
 number 1 dn 9
 dtmf-relay sip-notify
 username 28126 password 28126
 codec g711ulaw
Arvie
But for conference to work you need to configure
ephone-dn x octo
number A01
ephone-dn x octo
number A02
pre 1
Then register your conference bridge under telephony-service
Hi Mohammed,
I'm using SIP instead of SCCP for my IP Phones so i'm not using ephone-dn.
Arvie
Hi Mohammed,
Does it mean that Hardware Conference will only work for SCCP and not for SIP IP Phones?
Arvie
It will work for both but it has to be configured under telephony
Hi Mohammed,
The hardware conference was already added to both voice register global and telephony service but it is still the same.
 mode  cme
 source-address <ip address> port 5060
 max-dn 50
 max-pool 50
 load 7821 sip78xx.10-1-1sr1-4
 authenticate register
 authenticate realm all
 timezone 43
 time-format 24
 hold-alert
 tftp-path flash:
 file text
 create profile sync 0000408060435518
 conference hardware
telephony-service
 sdspfarm units 10
 sdspfarm tag 1 d46d.50ab.6660
 sdspfarm tag 2 EAUC-MTP
 sdspfarm tag 3 conference
 conference hardware
 max-ephones 58
 max-dn 300
 ip source-address <ip address> port 2000
 max-conferences 8 gain -6
 transfer-system full-consult
 transfer-pattern .T
 create cnf-files version-stamp Jan 01 2002 00:00:00
Share a "show run" along with "show sccp" output.
*** Show SCCP ***
eaucpabx#sh sccp
*Feb  9 11:26:26.619: %SYS-5-CONFIG_I: Configured from console by admin on vty0 (172.22.1.119) all
SCCP Admin State: UP
Gateway Local Interface: GigabitEthernet0/0
        IPv4 Address: <ip address>
        Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: <ip address>, Port Number: 2000
        Priority: 1, Version: 7.0, Identifier: 1
MTP Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: <ip address>, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 2
Reported Max Streams: 40000, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: pass-thru, Maximum Packetization Period: N/A
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
TLS : ENABLED
Conferencing Oper State: ACTIVE - Cause Code: NONE
TCP Link Status: CONNECTED, Profile Identifier: 1
Reported Max Streams: 160, Reported Max OOS Streams: 0
TLS : ENABLED
SCCP Application Service(s) Statistics:
Profile Identifier: 2, Service Type: MTP
TCP packets rx 210, tx 57
Unsupported pkts rx 0, Unrecognized pkts rx 156
Register tx 1, successful 1, rejected 0, failed 0
Unregister tx 0, successful 0
KeepAlive tx 52, successful 52, failed 0
OpenReceiveChannel rx 0, successful 0, failed 0
CloseReceiveChannel rx 0, successful 0, failed 0
**** Show run ****
sh run
Building configuration...
Current configuration : 34266 bytes
version 15.4
hostname eaucpabx
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.154-2.T2.bin
boot-end-marker
aqm-register-fnf
enable password qpalz,901
aaa new-model
aaa session-id common
clock timezone PHT 8 0
ip domain name eaucpabx.aboitiz.com
ip cef
no ipv6 cef
voice-card 0
 dspfarm
 dsp services dspfarm
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 supplementary-service h450.12
 no supplementary-service sip refer
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  bind media source-interface GigabitEthernet0/0
  registrar server
voice register pool-type  7821
 xml-config maxNumCalls 6
 xml-config busyTrigger 6
 xml-config custom sshAccess 0
 phoneload-support
 telnet-support
 gsm-support
 num-lines 16
 description cisco ip phone 7821
 reference-pooltype 6921
 mode  cme
 max-dn 50
 max-pool 50
 timezone 43
 time-format 24
 hold-alert
 tftp-path flash:
 file text
 conference hardware
voice register dn  1
 number 28100
 allow watch
 pickup-call any-group
 name EAC - Share
 label EAC - Share
voice register dn  2
 number 28106
 allow watch
 name EAC - Admin
 label EAC - Admin
voice register dn  3
 number 28102
 allow watch
 name EAC - Cirilo
 label EAC - Cirilo
voice register dn  4
 number 28105
 allow watch
 name EAC - HR
 label EAC - HR
voice register dn  5
 number 28103
 allow watch
 name EAC - Conference
 label EAC - Conference
voice register dn  6
 number 28150
 allow watch
 name EAC - Grace
 label EAC - Grace B
voice register dn  7
 number 28144
 allow watch
 name EAC - Riza
 label EAC - Riza
voice register dn  8
 number 28145
 allow watch
 name EAC - Maria Larisse
 label EAC - Maria Larisse
voice register dn  9
 number 28126
 allow watch
 name EAC - Riche
 label EAC - Riche
voice register dn  10
 number 28135
 allow watch
 name EAC - Maintenance
 label EAC - Maintenance
voice register pool  1
 type 7821
 number 1 dn 1
 username 28100 password 28100
 codec g711ulaw
voice register pool  2
 type 7821
 number 1 dn 2
 username 28106 password 28106
 codec g711ulaw
voice register pool  3
 type 8945
 number 1 dn 3
 username 28102 password 28102
 codec g711ulaw
voice register pool  4
 type 8945
 number 1 dn 4
 username 28105 password 28105
 codec g711ulaw
voice register pool  5
 type 7821
 number 1 dn 5
 username 28103 password 28103
 codec g711ulaw
voice register pool  6
 type 7821
 number 1 dn 6
 username 28150 password 28150
 codec g711ulaw
voice register pool  7
 type 7821
 number 1 dn 7
 username 28144 password 28144
 codec g711ulaw
voice register pool  8
 type 7821
 number 1 dn 8
 username 28145 password 28145
 codec g711ulaw
 type 7821
 number 1 dn 9
 codec g711ulaw
 conference admin
voice register pool  10
 type 7821
 number 1 dn 10
 username 28135 password 28135
 codec g711ulaw
license udi pid CISCO2911/K9
hw-module ism 0
hw-module pvdm 0/0
hw-module pvdm 0/1
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
 ip address <ip address>
 duplex auto
 speed auto
 h323-gateway voip interface
 h323-gateway voip bind srcaddr <ip address>
interface ISM0/0
 ip unnumbered GigabitEthernet0/0
 service-module ip address <ip address>
 !Application: CUE Running on ISM
 service-module ip default-gateway <ip address>
ip forward-protocol nd
control-plane
voice-port 0/0/0
 supervisory disconnect dualtone mid-call
 secondary dialtone
 no battery-reversal
 no vad
 timeouts interdigit 2
 timeouts call-disconnect 1
 timeouts wait-release 1
 connection plar opx immediate 7001
 caller-id enable
voice-port 0/0/1
 secondary dialtone
 no battery-reversal
 no vad
 caller-id enable
voice-port 0/0/2
 secondary dialtone
 no battery-reversal
 no vad
 caller-id enable
voice-port 0/0/3
 secondary dialtone
 no battery-reversal
 no vad
 caller-id enable
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm <ip address> identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
 bind interface GigabitEthernet0/0
 associate ccm 1 priority 1
 associate profile 1 register d46d.50ab.6660
 associate profile 2 register EAUC-MTP
 keepalive retries 5
 switchover method immediate
 switchback method immediate
 switchback interval 15
dspfarm profile 1 conference
 description d46d.50ab.6660
 codec g711ulaw
 maximum conference-participants 16
 maximum sessions 10
 associate application SCCP
dspfarm profile 2 mtp
 description EAUC-MTP
 codec g711ulaw
 codec pass-through
 maximum sessions software 20000
sip-ua
 registrar ipv4:<ip address> expires 3600
 sip-server ipv4:<ip address>
gatekeeper
 shutdown
telephony-service
 sdspfarm units 10
 conference hardware
 max-ephones 58
 max-dn 300
 transfer-pattern .T
end
ephone-dn 1 octo
number A100
conference ad-hoc
no huntstop
R0g22
And yes you need these configured irrespective of the fact whether you have sip or sccp phones.
Hi Nipun Singh Raghav,
Do you mean that I need to create ephone-dn for my SIP IP Phone even though i'm using voice register pool for my SIP IP Phones?
Arvie
I’ve already tested it with 5 participants and so far it is working. I’ll try to create up to 10 participants and see if it will work also. Thank you for the information.
Arvie
