04-18-2013 01:03 AM - edited 03-16-2019 04:52 PM
We have a CME , lets consider we are making internal calls:
when user A is speaking on the line and user B calls user A, is there a way for user B to get that user A is busy or on another call without limiting user A to a busy-trigger-per-button, i want user A to receive the call and user B to know that user A is on another call without being transfered to the call busy number.
this is the current config of the dn:
ephone-dn 4 dual-line
number 41104
pickup-group 1
description ##
name ###
allow watch
call-forward busy 41199
call-forward noan 41199 timeout 15
mwi sip
ephone 3
device-security-mode none
mac-address 203A.0723.A4EB
paging-dn 12
type 7945
logout-profile 3
04-18-2013 01:34 AM
Hi Marc
Is ephone 4 for User A. If 41199 is your Voicemail number, it will go to voice mail. If dont you want to it go voicemail, remove
call-forward busy 41199.
max-calls-per-button 4
busy-trigger-per-button 1
04-18-2013 01:39 AM
Hi Ofentse,
yup ephone 4 is User A, the thing is, it wont go to 41199 when only 1 line is used as the dual line can have multiple lines before giving you a busy tone, in this case user A while speaking will see that user B is calling him and user B will be waiting for user A to answer him, what i want is to have User B notified that user A is on another call.
04-18-2013 02:11 AM
Hi Marc
add under ephone 4 and remove call-forward busy 41199
busy-trigger-per-button 1 .
Please test
04-18-2013 04:10 AM
I dont want to remove the busy 41199 and i dont want the 2nd call on the line to be busy, i just want a notification for the internal calling number to know that it is on another call.
04-18-2013 05:29 AM
Hello
please use the below configuration
number 41104
huntstop channel
or there is other way to know that user A has a call (This feature called presence), find the below config for this feature
(router-Config)#presence
(router-Config)#presence call-list
ephone-dn 4 dual-line (for line on A which you need to know if he has a call or not).
number 41104
allow-watch
ephone x (x: ephone number of B)
blf-speed-dial 1 41104 label x (x: name of the user of line 41104)
when the call come to phone A user B will get indicator the A has a call
Thank you
please rate if this will help
04-18-2013 05:02 PM
I think Islam's line of thinking is valid. While you may not be able to natively alter the ringback tone heard by the calling party. I think that using a Monitor/Watch solution is a good idea. You don't even need to call the remote party. Just look at the phone for a visual confirmation of status.
You can use the blf-speed-dial approach or you can simply add a Monitor or Watch line appearance on the calling party.
Of course, if you are trying to make this universally applicable to all call origination points (including the PSTN) then monitor/watch won't help.
I'd ask myself if thinking of the problem in a different way is still addressing the core requirement.
-Bill (@ucguerrilla)
04-18-2013 04:28 PM
There is no way to do this with just configuration.
You can use my script "selective busy ringback". It can be acquired on the website mentioned in my profile.
