CME Hunt Group - External call drop
jshaw
When I ring the pilot number internally for below hunt group, it works as anticipated with the call being passed between the two phones in the list before going to the final number. When I ring the pilot number from a mobile phone, the call cuts out at about 36 seconds into the call. Any ideas would be appreciated!
ephone-hunt 12 peer
 pilot 5844
 list 5731, 5766
 final 5760
 timeout 40, 40
 no-reg pilot
 description Test
 present-call idle-phone
11 Replies 11
Rajan
Can you provide below debugs for one such call to check further.
- If the calls coming through PRI:
debug isdn q931
debug voip ccapi inout
If you are using SIP, then
debug ccsip messages
Rajan
Pls rate all useful posts by clicking the stars below
Hi there,
Please find requested log attached. I've replaced my mobile number in the config with 0400000000
Thank you
It seems like the call is disconnected with cause code 19 by the CME which is "No user answer". Can you share the output of the below command to check the status of hunt pilot and members:
show ephone-hunt
Here you go:
Group 12
    type: peer
    pilot number: 5844, peer-tag 20259
    list of numbers:
        5731, aux-number A5844A1100, # peers 1, logout 0, down 0
            peer-tag  dn-tag  rna  login/logout  up/down
             [20258     31     0       login      up  ]
        5766, aux-number A5844A1101, # peers 1, logout 0, down 0
             [20260     56     0       login      up  ]
    final number: 5760
    preference: 0
    preference (sec): 7
    timeout: 40, 40
    description: Test
    present-call: idle-phone
    hops: 2
    next-to-pick: 1
    E.164 register: no pilot
    auto logout: no
    stat collect: no
    callqueue display: continuously
    debug: no
R0g22
Seems like the call is never sent to the HG final extension. I see the both the phones ringing for 16 seconds total and then disconnect sent from VG -
Jan 22 22:03:58.725: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x95FF
Cause i = 0x8093 - User alerting, no answer
Can you add a "show run" from the CME ? Also "show dial-peer voice summary" output please.
Hi there, please find requested output attached - 1/2
Please find requested output attached - 2/2
R0g22
Can you remove "max-redirect" from telephony-service and try again please ? If it still does not work, please collect the logs for the following debugs -
debug voip application callsetup
debug voip application redirect
debug voip application session
debug voip application supplementary service
debug voip application error
debug ephone detail
debug sccp message
debug voip vtsp all
Thank you for your assistance, I'll give it a shot once I get back to the office later in the week then report back.
Cheers
Hi there,
Still no luck.
Please find logs attached - I've changed my mobile number to 0400000000.
R0g22
I don't see the final leg for Redirect Update happening. Can you remove the hunt group and then re-add and test ? If you have already done it, test with a different type maybe sequential ?
