CME (LAB)
Have a simple questions about setting up express on a lab router.  We have an assorted mix of 38xx, 29xx and 39xx series to test with, but wanted to get a feel for the interface and cmd line a bit in a lab eviorment.  With the 12.4 versions phased out, will downloading the 15.0 version on any of those routers allow me to use "most" of the functions and get a small lab online?  Or will it prompt for the key before allowing me to configure any phones, gateways or users?
Andrew
2 Accepted Solutions
ronpatel
Level 8
Level 8
Yes, 15.X IOS is latest IOS for CME also. with 15.X IOS you can get latest CME features and you can run your LAB.
It will not prompt for Key but for ISR G2, you will have to accept EULA and should have activated voice feature pak.
http://www.cisco.com/en/US/prod/collateral/routers/ps10616/white_paper_c11_556985.html
Ronak Patel
Rate all helpful post by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
In addition 15 train requires more RAM than 12.4, so ensure you your router meets the minimum requirements before loading it.
Chris
9 Replies 9
ronpatel
Level 8
Level 8
Ronak Patel
Chris
Thanks guys, I taken your advice and been at the wheel now for a few days with no luck so far.  Gonna keep trying other versions till I get it, but just can't get that darn web gui to come up.  Not that I love gui's or anything, just want to get the full experience and "full setup" under my belt is all so I can move on to the next thing.  Not sure what's the issue but so far I can get the web page to prompt for user credentials but either goes to a blank page or 404 page error.
Cisco 2911
IOS Version- c2900-universalk9-mz.SPA.150-1.M10.bin
CME- CME 8.6.tar
I enabled the features needed in the telephony service-
ip http server
ip http authentication local
no ip http secure-server
ip http path flash:/GUI
telephony-service
max-conferences 8 gain -6
web admin system name admin password cisco
dn-webedit
time-webedit
transfer-system full-consult
Thanks again
Have you uploaded the GUI files in the Flash of your router
Below link gives you the proceudre to configure the GUI
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmegui.html#wp1069575
Ronak Patel
@Ronak
Yes, uploaded a few different versions when things jsut didn't work out.  Formatted the flash and threw a new version on each time.  I'll check out that doc and see what I'm missing here.
R1#sho fl
-#- --length-- -----date/time------ path
2            0 Apr 23 2013 03:47:24 CME 8.6.0 GUI
3         4118 Apr 23 2013 03:47:24 CME 8.6.0 GUI/admin_user.html
4       677820 Apr 23 2013 03:47:26 CME 8.6.0 GUI/admin_user.js
5         1029 Apr 23 2013 03:47:26 CME 8.6.0 GUI/CiscoLogo.gif
6          639 Apr 23 2013 03:47:28 CME 8.6.0 GUI/CME_GUI_README.TXT
7          953 Apr 23 2013 03:47:28 CME 8.6.0 GUI/Delete.gif
8        16344 Apr 23 2013 03:47:28 CME 8.6.0 GUI/dom.js
9          864 Apr 23 2013 03:47:28 CME 8.6.0 GUI/downarrow.gif
10        6315 Apr 23 2013 03:47:28 CME 8.6.0 GUI/ephone_admin.html
11        4558 Apr 23 2013 03:47:30 CME 8.6.0 GUI/logohome.gif
12        3978 Apr 23 2013 03:47:30 CME 8.6.0 GUI/normal_user.html
13       78428 Apr 23 2013 03:47:30 CME 8.6.0 GUI/normal_user.js
14        1347 Apr 23 2013 03:47:30 CME 8.6.0 GUI/Plus.gif
15         843 Apr 23 2013 03:47:32 CME 8.6.0 GUI/sxiconad.gif
16         174 Apr 23 2013 03:47:32 CME 8.6.0 GUI/Tab.gif
17        2496 Apr 23 2013 03:47:32 CME 8.6.0 GUI/telephony_service.html
18         870 Apr 23 2013 03:47:32 CME 8.6.0 GUI/uparrow.gif
19       10230 Apr 23 2013 03:47:32 CME 8.6.0 GUI/xml-test.html
20        3412 Apr 23 2013 03:47:34 CME 8.6.0 GUI/xml.template
21    62754452 Apr 23 2013 04:13:34 c2900-universalk9-mz.SPA.150-1.M10.bin
196534272 bytes available (63619072 bytes used)
Thanks in advance
hi
Cisco Unified CME GUI files are version-specific;  GUI files for one version of Cisco Unified CME are not compatible with  any other version of Cisco Unified CME. If you are downgrading or  upgrading your Cisco Unified CME version, you must downgrade or upgrade  your GUI files.
Ronak Patel
That you are correct sir!
When I move to another version IOS I've been changing them to the matching CME files as well.  I've been using this matrix as a guide to match up an IOS to a CME version.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
Got it!
Since I'm on IOS version c2900-universalk9-mz.SPA.150-1.M10.bin I cleared out the GUI files and now using 8.0.  All good now.
Thanks all,
Andrew
Hi Andrew,
I am glad things work for you..
Dont forget to rate all the helpful posts.
Ronak Patel
