CME Licensing, and firmware supported
aelankoud
Hi Experts,
we have a Router IOS version 15.5(3)S4b, 40 IP Phones 7821, 2 IP Phones for conference 8831, 1 IP Phone 8841, and 1IP Phone 8851.
1st question : how I can know the version of CME ? I searched in the Compatibility Matrix cisco wensite, I didn't find this version.
2nd question : what version of firmware can I use for these IP Phones ?
3rd question : I used telephony-service command, then max-ephone, the max the IP Phones who give me 42, knowning that, we had purchased 45 Basic License, and 1 Enhanced License. why it give me 42 (maximum of numbers).
thank you for helping me ?
Youssef.
Manish Gogna
Hi Youssef,
the following couple of links has all details of CME compatibility and supported platforms, IOS and firmware versions
http://www.cisco.com/c/en/us/support/unified-communications/unified-communications-manager-express/products-device-support-tables-list.html
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/33matrix.html
CME licensing is explained here including the newly introduced Smart licensing
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/manual/cmeadm/cmeover.html#concept_F83A35F7FC83473E951DE6E438190309
Manish
- Do rate helpful posts -
Hi Manish,
thank for your quick answer.
I don't find the 15.5S4 version on these links. where i can exactly find the Compatibility Matrix for this version ?
I'm confused, why this version doesn't exist in this board.
Thank you again.
Youssef
The compatibility matrix that i shared lists the minimum recommended IOS for any CME version, you need to ensure that either the same IOS version or a higher one is used to install the corresponding CME version. Not every IOS version will be listed, but it doesn't mean it is not supported.
Manish
