07-17-2017 01:49 PM - edited 03-17-2019 10:48 AM
I am trying to setup a call handler for one of our campuses.
I have created a
My question is when I call AT&T and have them port the old number over to the number of the
will it forward to the call handler?
Example:
Old number: 903-872-xxxx
Call Handler extension:6498
Whole number for call handler and
In other
I am pretty new to this so if you need more info please just let me know.
Thank you in advance for your help.
07-17-2017 02:04 PM
Hi there,
Yes this should work just fine! You will just need to use Call Forward All on the CTI-RP (6498) to forward the call to Unity Connection and everything else should match up correctly.
Cheers!
Rob
07-17-2017 02:11 PM
07-17-2017 04:20 PM
That should work mate, make sure you call into the CTI RP internally to see if you land on your call handler,
if it doesnt work, make sure you have a forwarding routing rule on your unity box
Please rate if useful
07-17-2017 04:29 PM
Thanks for the reply Dennis.
I am able to call the CTI-RP internally and land on the call handler.
I thought I would do some testing. We have a campus that already has a CTI-RP configure for the AT&T DID to be forwarded to their internal front office extension. It works great.
To test I replaced the existing extension with the CTI-RP for the call handler.
I gave it a call and only got a Cisco voice what sounded like an unconfigured voice mail. Not the call handler.
my concern is when the number is finally ported over PTSN callers will get the default voice mail instead of the call handler.
07-17-2017 07:38 PM
I dont follow 100%, so obviously your 6498 call handler works when you dial into it.
if you do a translation pattern that translates your ATT DID into the know, working 6498 call handler, what happens.
07-17-2017 03:03 PM
Hi there,
Yes, using the Call Forward All to VM checkbox is exactly what I was referring to.
Cheers!
Rob
