CME licensing offline
rajkamath
Good day all,
Need advice on license activation for CME on a ISR4321 router. stuck at the moment. DID SLR and reserved licenses for CME14-UL . However don't have any voice commands available and guess I need uck9 to be enabled. Not sure about how to proceed. any advice would be very helpful. attaching sh ver and sh license details.
i tried running command license boot level uck9 and it says not supported due to unavailability of license in SLR mode. The router cannot be connected to online. so trying to SLR mode. sh license command output below
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2022.10.11 15:33:47 =~=~=~=~=~=~=~=~=~=~=~=
sh lice
Router# sh license all
Smart Licensing Status
Smart Licensing is ENABLED
License Reservation is ENABLED
License Conversion:
Automatic Conversion Enabled: False
Status: Not started
Export Authorization Key:
Features Authorized:
<none>
Utility:
Status: DISABLED
Smart Licensing Using Policy:
Status: ENABLED
Data Privacy:
Sending Hostname: yes
Callhome hostname privacy: DISABLED
--More--   Smart Licensing hostname privacy: DISABLED
Version privacy: DISABLED
Transport:
Type: Transport Off
Miscellaneous:
Custom Id: <empty>
Policy:
Policy in use: Merged from multiple sources.
Reporting ACK required: yes (CISCO default)
Unenforced/Non-Export Perpetual Attributes:
First report requirement (days): 365 (CISCO default)
Reporting frequency (days): 0 (CISCO default)
Report on change (days): 90 (CISCO default)
Unenforced/Non-Export Subscription Attributes:
First report requirement (days): 90 (CISCO default)
Reporting frequency (days): 90 (CISCO default)
Enforced (Perpetual/Subscription) License Attributes:
First report requirement (days): 0 (CISCO default)
--More--   Report on change (days): 0 (CISCO default)
Export (Perpetual/Subscription) License Attributes:
Usage Reporting:
Last ACK received: <none>
Next ACK deadline: <none>
Reporting push interval: 0 (no reporting)
Next ACK push check: <none>
Next report push: <none>
Last report push: <none>
Last report file write: <none>
Trust Code Installed: <none>
License Usage
CME v14 Endpoint License (CME_EP):
Description: Unified Communications Manager Express (CME) Endpoint License
Count: 0
--More--   Status: NOT IN USE
Export status: NOT RESTRICTED
Feature Name: CME v14 Endpoint License
Feature Description: Unified Communications Manager Express (CME) Endpoint License
Enforcement type: NOT ENFORCED
License type: Subscription
Reservation:
Reservation status: SPECIFIC INSTALLED
Total reserved count: 26
Product Information
UDI: PID:ISR4321/K9,SN:FDO26300QM1
Agent Version
Smart Agent for Licensing: 5.0.14_rel/89
License Authorizations
Overall status:
Active: PID:ISR4321/K9,SN:FDO26300QM1
--More--   Status: SPECIFIC INSTALLED on Oct 11 10:46:32 2022 UTC
Last Confirmation code: 99ed6142
Specified license reservations:
Term information:
Authorization type: SPECIFIC INSTALLED on Oct 11 10:46:32 2022 UTC
License type: PERPETUAL
Term Count: 26
Purchased Licenses:
No Purchase Information Available
Router#
2 Accepted Solutions
b.winter
have you activated the uck9 lic?
and maybe also agree to the EULA: license accept end user agreement
Then save the config and reboot
rajkamath
had to disable SLR, then activate UCK9,accept end user license agreement, wr and reboot. then redo the SLR to reserve the license. All have been installed and working the way its supposed to.
b.winter
Did accept Eula .
if I try the license boot level uck9 get the below error message as in attached . Should I delete the slr
rajkamath
The exact message is License configuration for feature uck9 is not accepted due to unavailability of license in SLR mode
rajkamath
