03-07-2014 05:53 AM - edited 03-16-2019 10:02 PM
I am facing this wierd issue which came in out of no where.
Whenever I configure a line dn 2000 to call-foward noan to a mobile number after sometimes this line 2000 and sometimes all line go busy.
ephone-dn 1 dual-line
number 2000
call-forward busy 7000
call-forward noan 96617484 timeout 18
CME version is 7.1
I have attached my complete config and show call active voice output.
Please help, I am confused why this is happening.
Solved! Go to Solution.
03-07-2014 06:03 AM
You are having famous FXO disconnect problem and you have to fine your country specific disconnect tones...mo
http://ciscoflair.blogspot.com/2009/05/cisco-fxo-disconnect-issue.html
HTH,
Dragan
03-07-2014 06:03 AM
HTH,
Dragan
03-07-2014 06:12 AM
Thank you Dragan,
I will try this and confirm.
03-07-2014 06:35 AM
Hi Vijit,
Configure custom tone according to your country.
Please refer below link
For tone database you may refer below link
http://www.3amsystems.com/World_Tone_Database?q=India,Disconnect_tone
Nishant Savalia
