CME Not Showing Dialed Number on Phones
TheRealBTU
Beginner
Beginner
CME 12.0 running on a 2911 router, 8800 Series SIP phones.
Some very weird behavior occurring in a new setup.  We have 6 PSTN lines plugged into the 2911 router;
1. When dialing outbound (our prefix is 9), after the call connects the entire number dialed disappears from the phones except for the "9".  It's very odd to not be able to see the number you just dialed.  I can't seem to find any troubleshooting guidance on this issue unfortunately.
2. When retrieving a parked call (we have two Park BLF's setup on all phones), the caller ID of the parked call does not come through onto the phone that picked up the parked call.  All it displays is the number of the park slot - in our case either 1098 or 1099.
Attached full output of SHOW RUN command.  There is an ephone-dn 3333 setup for Directed Call Park but we do not use that at all.
Any ideas?!
Thanks everyone!!!
Bryan
Maren Mahoney
VIP Advocate VIP Advocate
VIP Advocate
CUCM uses the Remote-Party-ID to populate connected party. I'm not sure if that is the same in CUCME, but it would make sense.
Would your service provider have an issue if you tried removing the 'no remote-party-id' command under the sip-ua? You'd have to bounce voice service after, but it's worth a try.
Maren
TheRealBTU
Beginner
Beginner
Bumping this back up... any thoughts?  It's the same weird behavior for dialing internal extensions.  When dialing 1100, after the call connects only "1" is displayed on the 8800 screen.
Maren Mahoney
VIP Advocate
Maren
Thanks Maren, that worked!  I removed 'no remote-party-id' from sip-ua and now the dialed & connected party display on the phones.  Thanks a million!
Recognize Your Peers
