CME outgoing display-ie
casey1hunter
Have CME router connected to call manager via qsig trunk. Outbound calls from CME are not displaying caller ID name to call manager. What am I missing?
interface Serial0/2/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn incoming-voice voice
isdn supp-service name calling profile Network-Extensions operation-value-tag local
isdn outgoing display-ie
no cdp enable
ephone-dn 17 octo-line
number 3001
label 3001 SCCP CUCME
description 3214-3001
ephone 7
device-security-mode none
description 3001 SCCP CUCME
mac-address 0015.2BC7.E368
ephone-template 1
max-calls-per-button 5
busy-trigger-per-button 3
type 7940
button 1:17 2:11
paolo bevilacqua
Check "debug isdn q931" but logic says the calling name is there, in two formats possibly.
BTW why don't you just use H.323 to trunk to CUCM ?
studying for IE lab
Channel ID i = 0xA98385
Exclusive, Channel 5
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0080, '3001'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '3335002'
Name not being sent, try
voice service voip
qsig decode
