I am trying to use the XML service on the phones on a CME system.
This of course requires authentication.
Unfortunately, the authentication URL is set to CUE's authentication because Voiceview Express is in use.
(http://10.1.10.1/voiceview/authentication/authenticate.do)
I am unable to authenticate using either the CME user/pass or the CUE user/pass or the CUE ext/pin.
I found the "fallback-url" command for CUE under "service phone-authentication".
I attempted to set this to "http://cme.ip/CCMCIP/authenticate.asp" -- this did not help either.
The error I am getting when trying to execute any XML requests is:
<CiscoIPPhoneError Number="4" />
Has anyone else solved this problem?
Thanks.
