CME phone lines
maritsak1
hello,
I am new to configuration of CME.
Recently we change service provider. we have 2 phone numbers. one is for fax
we have the fax to ISP's router analog port and our 881V through BRI port.
The problem is that fax's number also rings to out internal CME phones.
The previous provider separate the number from the analog to never go to BRI port.
Now they tell us that they cannot do it and we have to configure our CME to reject the FAX number
from our system.
any suggestions?
our configuration is:
stcapp ccm-group 1
stcapp
stcapp supplementary-services
port 3
fallback-dn 2141
port 4
fallback-dn 2142
port 5
fallback-dn 2143
isdn switch-type basic-net3
voice service voip
ip address trusted list
ipv4 192.168.0.0 255.255.255.0
ipv4 192.168.4.0 255.255.255.0
ipv4 10.1.1.0 255.255.255.0
ipv4 10.1.4.0 255.255.255.0
ipv4 10.90.83.0 255.255.255.0
ipv4 172.16.4.0 255.255.255.0
ipv4 192.168.99.0 255.255.255.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
no supplementary-service h450.7
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
bind control source-interface Vlan100
registrar server
voice hunt-group 1 parallel
list 2141,2142
pilot 2140
voice translation-rule 9
voice translation-rule 10
rule 3 /^/ /9/
voice translation-profile call_in
translate calling 10
translate called 10
voice translation-profile call_out
translate called 9
voice-card 0
license udi pid C881-V-K9 sn FCZ180592MP
dial-control-mib retain-timer 35791
dial-control-mib max-size 500
interface BRI1
no ip address
ip flow ingress
isdn point-to-point-setup
isdn incoming-voice voice
voice-port 1
translation-profile incoming call_in
translation-profile outgoing call_out
compand-type a-law
cptone GR
connection plar 2141
description ** ISDN 2XXXXX **
bearer-cap Speech
voice-port 2
compand-type a-law
cptone GR
bearer-cap Speech
voice-port 3
timeouts ringing infinity
station-id name Konpoleos 2141
station-id number 2141
caller-id enable
voice-port 4
station-id name  2142
station-id number 2142
caller-id enable
voice-port 5
station-id name Konpoleos 2143
station-id number 2143
caller-id enable
voice-port 6
voice-port 7
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local Vlan100
sccp ccm 10.1.4.1 identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer cor custom
name Internal
name Emergency
name Company_EXT
name Special5Digit
name 80X
name National
name Mobile-Gateway
name Mobile-PSTN
name International
dial-peer cor list call-Internal
member Internal
dial-peer cor list call-Emergency
member Emergency
dial-peer cor list call-CompanyEXT
member Company_EXT
dial-peer cor list call-Special5Digit
member Special5Digit
dial-peer cor list call-80X
member 80X
dial-peer cor list call-National
member National
dial-peer cor list call-Mobile-Gateway
member Mobile-Gateway
dial-peer cor list call-Mobile-PSTN
member Mobile-PSTN
dial-peer cor list call-International
member International
dial-peer cor list user-level01
member Internal
dial-peer cor list user-level02
member Internal
member Emergency
member 80X
dial-peer cor list user-level03
dial-peer cor list user-level04
member Internal
member Emergency
member 80X
member National
dial-peer cor list user-level05
dial-peer cor list user-level06
member Internal
member Emergency
member 80X
member National
dial-peer cor list user-level07
member Emergency
member 80X
member National
member Mobile-PSTN
dial-peer cor list user-level08
dial-peer cor list user-level09
dial-peer cor list user-level10
member Internal
member Emergency
member 80X
member National
member Mobile-PSTN
dial-peer voice 1 pots
description ** incoming dial peer ON-TEL **
incoming called-number .
direct-inward-dial
port 1
dial-peer voice 2 pots
description ** incoming dial peer OTE **
direct-inward-dial
port 2
dial-peer voice 3 pots
service stcapp
port 3
dial-peer voice 4 pots
port 4
dial-peer voice 5 pots
port 5
dial-peer voice 6 pots
port 6
dial-peer voice 7 pots
direct-inward-dial
port 7
dial-peer voice 8 pots
direct-inward-dial
dial-peer voice 9 pots
dial-peer voice 10 pots
dial-peer voice 11 pots
dial-peer voice 12 pots
dial-peer voice 13 pots
dial-peer voice 14 pots
dial-peer voice 15 pots
dial-peer voice 16 pots
dial-peer voice 17 pots
dial-peer voice 18 pots
dial-peer voice 19 pots
dial-peer voice 20 pots
corlist outgoing call-Emergency
description Emergency Services
translation-profile outgoing call-out
destination-pattern 910[0,8]
direct-inward-dial
port 1
forward-digits 3
dial-peer voice 21 pots
destination-pattern 10[0,8]
direct-inward-dial
port 1
forward-digits 3
dial-peer voice 22 pots
destination-pattern 9112
direct-inward-dial
port 1
forward-digits 3
dial-peer voice 23 pots
destination-pattern 112
direct-inward-dial
port 1
forward-digits 3
dial-peer voice 24 pots
destination-pattern 9166
direct-inward-dial
port 1
forward-digits 3
dial-peer voice 25 pots
destination-pattern 166
direct-inward-dial
port 1
forward-digits 3
dial-peer voice 26 pots
destination-pattern 91[7,9]1
direct-inward-dial
port 1
forward-digits 3
dial-peer voice 27 pots
destination-pattern 1[7,9]1
direct-inward-dial
port 1
forward-digits 3
dial-peer voice 28 pots
destination-pattern 91[3,9]9
direct-inward-dial
port 1
forward-digits 3
dial-peer voice 29 pots
destination-pattern 1[3,9]9
direct-inward-dial
port 1
forward-digits 3
dial-peer voice 30 pots
corlist outgoing call-National
destination-pattern 910[1,3,5].$
direct-inward-dial
port 1
forward-digits 4
dial-peer voice 31 pots
destination-pattern 92.........$
direct-inward-dial
port 1
forward-digits 10
dial-peer voice 32 pots
destination-pattern 969........$
direct-inward-dial
port 1
forward-digits 10
dial-peer voice 33 pots
destination-pattern 91399$
direct-inward-dial
port 1
forward-digits 4
dial-peer voice 34 pots
dial-peer voice 35 pots
dial-peer voice 36 pots
dial-peer voice 37 pots
dial-peer voice 38 pots
dial-peer voice 39 pots
dial-peer voice 40 pots
dial-peer voice 41 pots
dial-peer voice 42 pots
dial-peer voice 43 pots
dial-peer voice 44 pots
dial-peer voice 45 pots
dial-peer voice 46 pots
dial-peer voice 47 pots
dial-peer voice 48 pots
dial-peer voice 49 pots
dial-peer voice 50 pots
dial-peer voice 51 pots
dial-peer voice 52 pots
dial-peer voice 53 pots
dial-peer voice 54 pots
dial-peer voice 55 pots
dial-peer voice 56 pots
dial-peer voice 57 pots
dial-peer voice 58 pots
dial-peer voice 59 pots
dial-peer voice 60 pots
dial-peer voice 61 pots
dial-peer voice 62 pots
dial-peer voice 63 pots
dial-peer voice 64 pots
dial-peer voice 65 pots
dial-peer voice 66 pots
dial-peer voice 67 pots
dial-peer voice 68 pots
dial-peer voice 69 pots
dial-peer voice 70 pots
dial-peer voice 71 pots
dial-peer voice 72 pots
dial-peer voice 73 pots
dial-peer voice 74 pots
dial-peer voice 75 pots
dial-peer voice 76 pots
dial-peer voice 77 pots
dial-peer voice 78 pots
dial-peer voice 79 pots
dial-peer voice 80 pots
dial-peer voice 81 pots
dial-peer voice 82 pots
dial-peer voice 83 pots
dial-peer voice 84 pots
dial-peer voice 85 pots
dial-peer voice 86 pots
dial-peer voice 87 pots
dial-peer voice 88 pots
dial-peer voice 89 pots
dial-peer voice 90 pots
dial-peer voice 91 pots
dial-peer voice 92 pots
dial-peer voice 93 pots
dial-peer voice 94 pots
dial-peer voice 95 pots
dial-peer voice 96 pots
dial-peer voice 97 pots
dial-peer voice 98 pots
dial-peer voice 99 pots
dial-peer voice 100 voip
destination-pattern 20..$
session protocol sipv2
session target ipv4:10.1.1.1
incoming called-number 214.
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 101 voip
codec g711ulaw
no vad
dial-peer voice 102 voip
codec g711ulaw
no vad
telephony-service
no auto-reg-ephone
pin 123456
fxo hook-flash
max-ephones 5
max-dn 50
ip source-address 10.1.4.1 port 2000
max-redirect 5
timeouts interdigit 5
system message CME
cnf-file location flash:
cnf-file perphone
time-zone 26
time-format 24
date-format dd-mm-yy
mwi relay
max-conferences 1 gain -6
hunt-group logout HLog
multicast moh 239.1.4.1 port 5060 route 10.1.4.2
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 20..
transfer-pattern 21..
transfer-pattern 22..
transfer-pattern 23..
secondary-dialtone 9
fac standard
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 1
number 2141
label Konpoleos 2141
name Konpoleos 2141
First thing you’re dial peer configuration is incredibly messy and very hard to follow. I personally would recommend you to start over with the bare minimum of dial peers so that you can easily follow the flow of the call through the system.
One example of the messiness, you have direct inward dial set on many dial peers and from the look of it I’m going to guess that it seems that you think it would use the port set on it to match the call to that specific dial peer. This is not how dial peer match works in the inbound direction. Recommend you to read through this fantastic document about dial peers and how these work for each direction. https://www.cisco.com/c/en/us/support/docs/voice/ip-telephony-voice-over-ip-voip/211306-In-Depth-Explanation-of-Cisco-IOS-and-IO.html
Apart from this you have a ton of dial peers without any configuration, neither of them should be needed and just adds to the messiness.
For your question at hand it would be helpful if you could provide a bit of specifics about your call flow. Bare minimum is what called number each of the different calls cases would have? We can’t know what the called number for fax calls or the other calls are if you don’t share this information.
Response Signature
