12-02-2014 09:14 AM - edited 03-17-2019 01:10 AM
does someone know if it´s possible to restrict a phone in a way, that the CFwdAll function is not available for a specific DN button?
In the below example the user should be able to use CFwdAll just for the button 1:3, but not for 2:12.
How can this be achieved?
ephone-dn 3 dual-line
number 6666
label 6666
name 6666
ephone-dn 12 dual-line
number 7777
label 7777
name 7777
ephone 1
no phone-ui speeddial-fastdial
no phone-ui snr
no multicast-moh
mac-address 6CFA.8995.6AB1
type 7965
button 1:3 2:12
Many thanks!
Solved! Go to Solution.
12-02-2014 11:15 AM
Apply an ephone-template to the phone that does not have Cfwdall enabled for the "seized" state. Cfwdall from the "idle" state will only apply to the first line on the phone.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmesoftk.html#wp1042597
-Jameson
12-02-2014 11:15 AM
-Jameson
12-02-2014 03:39 PM
Thanks, that´s working!
How would you do it if you´d have more than two buttons configured on that ephone, and you would like to disable the Cfwdall just for some of them?
12-03-2014 06:41 AM
Unfortunately, it's an all, one, or none configuration (all lines, first line, or no lines).
