CME: Restrict specific button for CFwdAll
does someone know if it´s possible to restrict a phone in a way, that the CFwdAll function is not available for a specific DN button?
In the below example the user should be able to use CFwdAll just for the button 1:3, but not for 2:12.
How can this be achieved?
ephone-dn  3  dual-line
 number 6666
 label 6666
 name 6666
ephone-dn  12  dual-line
 number 7777
 label 7777
 name 7777
ephone  1
 no phone-ui speeddial-fastdial
 no phone-ui snr
 no multicast-moh
 mac-address 6CFA.8995.6AB1
 type 7965
 button  1:3 2:12
Many thanks!
Apply an ephone-template to the phone that does not have Cfwdall enabled for the "seized" state. Cfwdall from the "idle" state will only apply to the first line on the phone.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmesoftk.html#wp1042597
-Jameson
-Jameson
-Jameson
-Jameson
Thanks, that´s working!
How would you do it if you´d have more than two buttons configured on that ephone, and you would like to disable the Cfwdall just for some of them?
Unfortunately, it's an all, one, or none configuration (all lines, first line, or no lines).
-Jameson
