CME SIP issue - Cisco 7821 phone not registering
gsidhu
Level 3
Level 3
I am having issues with getting a Cisco 7821 phone to register.
Current deployment is with Cisco 6921 phones SCCP registration
SIP integration with CUE
SIP integration with Mitel system
c2951-universalk9-mz.SPA.154-3.M1.bin (CME 10.5)
In flash:
rootfs78xx.10-1-1SR1-4.sbn
kern78xx.10-1-1SR1-4.sbn
sboot78xx.10-1-1SR1-4.sbn
sip78xx.10-1-1SR1-4.loads
The 7821 phone gets IP address but fails to register. Please could somebody let me know why phone is not registering.
Configuration below (10.245.226.132 is CME address) .
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol pass-through g711ulaw
 modem passthrough nse codec g711ulaw redundancy maximum-sessions 5
 h323
 sip
  registrar server expires max 600 min 60
  options-ping 90
voice class codec 1
 codec preference 1 g711alaw
 codec preference 2 g711ulaw
 codec preference 3 g729r8
voice register global
 mode  cme
 source-address 10.245.226.132 port 5060
 max-dn 30
 max-pool 10
 load 7821 sip78xx.10-1-1SR1-4
 authenticate register
 authenticate realm all
 timezone 22
 date-format D/M/Y
 voicemail 590
 tftp-path flash:
 create profile sync 0061443538560005
 network-locale GB
voice register dn  1
 number 1010
 name user1
 label user1
 mwi
voice register pool  1
 busy-trigger-per-button 2
 id mac F09E.636E.63F2
 type 7821
 number 1 dn 1
 presence call-list
 dtmf-relay rtp-nte
 username 1010 password 123
 codec g711ulaw
 no vad
dial-peer voice 391 voip
 description *** Auto Attendant ***
 destination-pattern 399
 session protocol sipv2
 session target ipv4:10.245.226.131
 dtmf-relay sip-notify
 codec g711ulaw
 no vad
dial-peer voice 392 voip
 description *** Administration Via Telephone ***
 destination-pattern 392
 codec g711ulaw
 no vad
dial-peer voice 393 voip
 description *** Extension Assigner ***
 service ea out-bound
 destination-pattern 393
 session target ipv4:10.245.226.132
dial-peer voice 590 voip
 description *** Voice Mail Pilot ***
 destination-pattern 590
 b2bua
 codec g711ulaw
 no vad
dial-peer voice 1 pots
 description ** Match all incoming POTS calls **
 translation-profile incoming IncomingPSTNcalls
 incoming called-number .
 direct-inward-dial
dial-peer voice 899 voip
 description Call to Mitel
 translation-profile incoming Prefix9
 translation-profile outgoing rem44
 destination-pattern [23]..
 session target ipv4:192.168.114.2
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
interface GigabitEthernet0/0
 description *** Connection to Mitel Phone System  ***
 ip address 192.168.114.5 255.255.255.248
 duplex auto
 speed auto
interface ISM0/0
 description *** Connection to Cisco Unity Express ***
 ip unnumbered GigabitEthernet0/1
 service-module ip address 10.245.226.131 255.255.255.128
 !Application: CUE Running on ISM
 service-module ip default-gateway 10.245.226.132
interface GigabitEthernet0/1
 description *** Connection to IP Phone LAN ***
 ip address 10.245.226.132 255.255.255.128
 duplex auto
 speed auto
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
ip route 0.0.0.0 0.0.0.0 10.245.226.129
ip route 10.245.226.131 255.255.2
tftp-server flash:apps37sccp.1-4-4-0.bin
tftp-server flash:sip78xx.10-1-1SR1-4.loads
tftp-server flash:rootfs78xx.10-1-1SR1-4.sbn
tftp-server flash:sboot78xx.10-1-1SR1-4.sbn
sip-ua
 mwi-server ipv4:10.245.226.131 expires 3600 port 5060 transport udp
 registrar ipv4:10.245.226.132 expires 600
gatekeeper
 shutdown
telephony-service
 authentication credential cmeadmin c4p1ta2012
 xml user xmladmin password xmladmin 15
 extension-assigner tag-type provision-tag
 max-ephones 104
 max-dn 299
 ip source-address 10.245.226.132 port 2000
 auto assign 101 to 105
 no service directed-pickup
 timeouts interdigit 5
 system message CFGS
 url services http://10.245.226.131/voiceview/common/login.do
 url authentication http://10.245.226.132/CCMCIP/authenticate.asp
 cnf-file location flash:
 cnf-file perphone
 load 7931 SCCP31.9-2-1S
 load 6921 SCCP69xx.9-2-1-0
 time-zone 22
 date-format dd-mm-yy
 voicemail 590
 max-conferences 8 gain -6
 call-forward pattern .T
 moh enable-g711 "music-on-hold.au"
 web admin system name cmeadmin secret 5 $1$QmIK$46fDKVSudMxzI2bRp/Ef7/
 time-webedit
 transfer-system full-consult
 transfer-pattern .T
 secondary-dialtone 9
 create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  298
 number 598...
 mwi on
ephone-dn  299
 number 599...
 mwi off
46 Replies 46
i have already upload the file .........after that what can i do......
H-AlSAMAH-RTR01#show flash:
-#- --length-- -----date/time------ path
1 99077424 Oct 6 2014 22:09:10 +03:00 c2900-universalk9-mz.SPA.152-4.M4.bin
2 0 Dec 15 2010 21:24:04 +03:00 GUI
3 4118 Jul 19 2010 16:43:18 +03:00 GUI/admin_user.html
4 677820 Jul 19 2010 16:43:18 +03:00 GUI/admin_user.js
5 1029 Jul 19 2010 16:43:18 +03:00 GUI/CiscoLogo.gif
6 1019 Nov 29 2011 19:14:28 +03:00 GUI/CME_GUI_README.TXT
7 953 Jul 19 2010 16:43:18 +03:00 GUI/Delete.gif
8 16344 Jul 19 2010 16:43:18 +03:00 GUI/DOM.JS
9 864 Jul 19 2010 16:43:18 +03:00 GUI/downarrow.gif
10 6315 Jul 19 2010 16:43:18 +03:00 GUI/ephone_admin.html
11 4558 Jul 19 2010 16:43:18 +03:00 GUI/LOGOHOME.GIF
12 3978 Jul 19 2010 16:43:18 +03:00 GUI/normal_user.html
13 78428 Jul 19 2010 16:43:18 +03:00 GUI/normal_user.js
14 1347 Jul 19 2010 16:43:18 +03:00 GUI/Plus.gif
15 843 Jul 19 2010 16:43:18 +03:00 GUI/SXICONAD.GIF
16 174 Jul 19 2010 16:43:18 +03:00 GUI/Tab.gif
17 2496 Jul 19 2010 16:47:00 +03:00 GUI/telephony_service.html
18 870 Jul 19 2010 16:43:18 +03:00 GUI/UPARROW.GIF
19 10230 Jul 19 2010 16:43:18 +03:00 GUI/xml-test.html
20 3412 Jul 19 2010 16:43:18 +03:00 GUI/xml.template
21 8160 Aug 20 2004 10:58:00 +03:00 Analog1.raw
22 8160 Aug 20 2004 10:58:00 +03:00 Analog2.raw
23 4639974 May 13 2011 13:08:02 +03:00 apps45.9-2-1TH1-13.sbn
24 5280 Aug 20 2004 10:58:00 +03:00 AreYouThere.raw
25 5040 Aug 20 2004 10:58:00 +03:00 AreYouThereF.raw
26 8160 Aug 20 2004 10:58:00 +03:00 Bass.raw
27 12240 Aug 20 2004 10:58:00 +03:00 CallBack.raw
28 16040 Aug 20 2004 10:58:00 +03:00 Chime.raw
29 8160 Aug 20 2004 10:58:00 +03:00 Classic1.raw
30 16080 Aug 20 2004 10:58:00 +03:00 Classic2.raw
31 10800 Aug 20 2004 10:58:00 +03:00 ClockShop.raw
32 575590 May 13 2011 13:07:56 +03:00 cnu45.9-2-1TH1-13.sbn
33 2211969 May 13 2011 13:08:14 +03:00 cvm45sccp.9-2-1TH1-13.sbn
34 2823 Jul 3 2007 02:30:58 +03:00 DistinctiveRingList.xml
35 9600 Aug 20 2004 10:58:00 +03:00 Drums1.raw
36 13440 Aug 20 2004 10:58:00 +03:00 Drums2.raw
37 356907 May 13 2011 13:08:10 +03:00 dsp45.9-2-1TH1-13.sbn
38 15840 Aug 20 2004 10:58:00 +03:00 FilmScore.raw
39 16080 Aug 20 2004 10:58:00 +03:00 HarpSynth.raw
40 8160 Aug 20 2004 10:58:00 +03:00 Jamaica.raw
41 1886651 May 13 2011 13:08:12 +03:00 jar45sccp.9-2-1TH1-13.sbn
42 16080 Aug 20 2004 10:58:00 +03:00 KotoEffect.raw
43 12720 Aug 20 2004 10:58:00 +03:00 MusicBox.raw
44 496521 May 6 2015 17:34:56 +03:00 music-on-hold.au
45 8160 Aug 20 2004 10:58:00 +03:00 Piano1.raw
46 15360 Aug 20 2004 10:58:00 +03:00 Piano2.raw
47 9360 Aug 20 2004 10:58:00 +03:00 Pop.raw
48 7200 Aug 20 2004 10:58:00 +03:00 Pulse1.raw
49 4000 Aug 20 2004 10:58:00 +03:00 Ring1.raw
50 4000 Aug 20 2004 10:58:00 +03:00 Ring2.raw
51 4000 Aug 20 2004 10:58:00 +03:00 Ring3.raw
52 4000 Aug 20 2004 10:58:00 +03:00 Ring4.raw
53 4000 Aug 20 2004 10:58:00 +03:00 Ring5.raw
54 4000 Aug 20 2004 10:58:00 +03:00 Ring6.raw
55 4000 Aug 20 2004 10:58:00 +03:00 Ring7.raw
56 495 Mar 17 2006 04:27:34 +03:00 RingList.xml
57 10800 Aug 20 2004 10:58:00 +03:00 Sax1.raw
58 14160 Aug 20 2004 10:58:00 +03:00 Sax2.raw
59 656 May 13 2011 13:07:34 +03:00 SCCP45.9-2-1S.loads
60 660 May 13 2011 13:07:40 +03:00 term45.default.loads
61 660 May 13 2011 13:07:48 +03:00 term65.default.loads
62 16080 Aug 20 2004 10:58:00 +03:00 Vibe.raw
63 23123 Apr 12 2015 13:44:32 +03:00 startup-config
64 45308 May 6 2015 16:04:18 +03:00 BOOT69xx.0-0-0-14.zz.sgn
65 226112 May 6 2015 16:04:32 +03:00 DSP69xx.0-0-0-11-124120.zz.sgn
66 489 May 6 2015 16:04:42 +03:00 SCCP69xx.9-2-4-3.loads
67 2762328 May 6 2015 16:05:00 +03:00 SCCP69xx.9-2-4-3.zz.sgn
68 0 May 6 2015 16:42:08 +03:00 its
69 0 May 6 2015 16:42:08 +03:00 its/vrf1
70 3483 May 6 2015 16:42:12 +03:00 its/vrf1/XMLDefault.cnf.xml
71 1413 May 6 2015 16:42:12 +03:00 its/vrf1/XMLDefault6921.cnf.xml
72 107 May 6 2015 16:45:50 +03:00 its/SEPDEFAULT.cnf
73 518 May 6 2015 16:45:50 +03:00 its/vrf1/XMLDefault7902.cnf.xml
74 1017 May 6 2015 16:45:52 +03:00 its/vrf1/XMLDefault7905.cnf.xml
75 1304 May 6 2015 16:45:52 +03:00 its/vrf1/XMLDefault7906.cnf.xml
76 604 May 6 2015 16:45:52 +03:00 its/vrf1/XMLDefault7910.cnf.xml
77 1304 May 6 2015 16:45:52 +03:00 its/vrf1/XMLDefault7911.cnf.xml
78 1017 May 6 2015 16:45:54 +03:00 its/vrf1/XMLDefault7912.cnf.xml
79 1017 May 6 2015 16:45:54 +03:00 its/vrf1/XMLDefault7920.cnf.xml
80 1230 May 6 2015 16:45:54 +03:00 its/vrf1/XMLDefault7921.cnf.xml
81 1266 May 6 2015 16:45:54 +03:00 its/vrf1/XMLDefault7925.cnf.xml
82 1304 May 6 2015 16:45:54 +03:00 its/vrf1/XMLDefault7931.cnf.xml
83 553 May 6 2015 16:45:56 +03:00 its/vrf1/XMLDefault7935.cnf.xml
84 553 May 6 2015 16:45:56 +03:00 its/vrf1/XMLDefault7936.cnf.xml
85 1304 May 6 2015 16:45:56 +03:00 its/vrf1/XMLDefault7937.cnf.xml
86 1112 May 6 2015 16:45:56 +03:00 its/vrf1/XMLDefault7940.cnf.xml
87 1274 May 6 2015 16:45:58 +03:00 its/vrf1/XMLDefault7940-7914-1.cnf.xml
88 1274 May 6 2015 16:45:58 +03:00 its/vrf1/XMLDefault7940-7915-12-1.cnf. xml
89 1274 May 6 2015 16:45:58 +03:00 its/vrf1/XMLDefault7940-7915-24-1.cnf. xml
90 1274 May 6 2015 16:45:58 +03:00 its/vrf1/XMLDefault7940-7916-12-1.cnf. xml
91 1274 May 6 2015 16:45:58 +03:00 its/vrf1/XMLDefault7940-7916-24-1.cnf. xml
92 1405 May 6 2015 16:46:00 +03:00 its/vrf1/XMLDefault7940-7914-2.cnf.xml
93 1405 May 6 2015 16:46:00 +03:00 its/vrf1/XMLDefault7940-7915-12-2.cnf. xml
94 1405 May 6 2015 16:46:00 +03:00 its/vrf1/XMLDefault7940-7915-24-2.cnf. xml
95 1405 May 6 2015 16:46:00 +03:00 its/vrf1/XMLDefault7940-7916-12-2.cnf. xml
96 1405 May 6 2015 16:46:02 +03:00 its/vrf1/XMLDefault7940-7916-24-2.cnf. xml
97 1304 May 6 2015 16:46:02 +03:00 its/vrf1/XMLDefault7941.cnf.xml
98 1306 May 6 2015 16:46:02 +03:00 its/vrf1/XMLDefault7941GE.cnf.xml
99 1304 May 6 2015 16:46:02 +03:00 its/vrf1/XMLDefault7942.cnf.xml
100 1318 May 6 2015 16:46:02 +03:00 its/vrf1/XMLDefault7945.cnf.xml
101 1112 May 6 2015 16:46:04 +03:00 its/vrf1/XMLDefault7960.cnf.xml
102 1274 May 6 2015 16:46:04 +03:00 its/vrf1/XMLDefault7960-7914-1.cnf.xml
103 1274 May 6 2015 16:46:04 +03:00 its/vrf1/XMLDefault7960-7915-12-1.cnf.xml
104 1274 May 6 2015 16:46:04 +03:00 its/vrf1/XMLDefault7960-7915-24-1.cnf.xml
105 1274 May 6 2015 16:46:06 +03:00 its/vrf1/XMLDefault7960-7916-12-1.cnf.xml
106 1274 May 6 2015 16:46:06 +03:00 its/vrf1/XMLDefault7960-7916-24-1.cnf.xml
107 1405 May 6 2015 16:46:06 +03:00 its/vrf1/XMLDefault7960-7914-2.cnf.xml
108 1405 May 6 2015 16:46:06 +03:00 its/vrf1/XMLDefault7960-7915-12-2.cnf.xml
109 1405 May 6 2015 16:46:08 +03:00 its/vrf1/XMLDefault7960-7915-24-2.cnf.xml
110 1405 May 6 2015 16:46:08 +03:00 its/vrf1/XMLDefault7960-7916-12-2.cnf.xml
111 1405 May 6 2015 16:46:08 +03:00 its/vrf1/XMLDefault7960-7916-24-2.cnf.xml
112 1304 May 6 2015 16:46:08 +03:00 its/vrf1/XMLDefault7961.cnf.xml
113 1466 May 6 2015 16:46:10 +03:00 its/vrf1/XMLDefault7961-7914-1.cnf.xml
114 1466 May 6 2015 16:46:10 +03:00 its/vrf1/XMLDefault7961-7915-12-1.cnf.xml
115 1466 May 6 2015 16:46:10 +03:00 its/vrf1/XMLDefault7961-7915-24-1.cnf.xml
116 1466 May 6 2015 16:46:10 +03:00 its/vrf1/XMLDefault7961-7916-12-1.cnf.xml
117 1466 May 6 2015 16:46:10 +03:00 its/vrf1/XMLDefault7961-7916-24-1.cnf.xml
118 1597 May 6 2015 16:46:12 +03:00 its/vrf1/XMLDefault7961-7914-2.cnf.xml
119 1597 May 6 2015 16:46:12 +03:00 its/vrf1/XMLDefault7961-7915-12-2.cnf.xml
120 1597 May 6 2015 16:46:12 +03:00 its/vrf1/XMLDefault7961-7915-24-2.cnf.xml
121 1597 May 6 2015 16:46:12 +03:00 its/vrf1/XMLDefault7961-7916-12-2.cnf.xml
122 1597 May 6 2015 16:46:14 +03:00 its/vrf1/XMLDefault7961-7916-24-2.cnf.xml
123 1306 May 6 2015 16:46:14 +03:00 its/vrf1/XMLDefault7961GE.cnf.xml
124 1468 May 6 2015 16:46:14 +03:00 its/vrf1/XMLDefault7961GE-7914-1.cnf.xml
125 1468 May 6 2015 16:46:14 +03:00 its/vrf1/XMLDefault7961GE-7915-12-1.cnf.xml
126 1468 May 6 2015 16:46:16 +03:00 its/vrf1/XMLDefault7961GE-7915-24-1.cnf.xml
127 1468 May 6 2015 16:46:16 +03:00 its/vrf1/XMLDefault7961GE-7916-12-1.cnf.xml
128 1468 May 6 2015 16:46:16 +03:00 its/vrf1/XMLDefault7961GE-7916-24-1.cnf.xml
129 1599 May 6 2015 16:46:16 +03:00 its/vrf1/XMLDefault7961GE-7914-2.cnf.xml
130 1599 May 6 2015 16:46:16 +03:00 its/vrf1/XMLDefault7961GE-7915-12-2.cnf.xml
131 1599 May 6 2015 16:46:18 +03:00 its/vrf1/XMLDefault7961GE-7915-24-2.cnf.xml
132 1599 May 6 2015 16:46:18 +03:00 its/vrf1/XMLDefault7961GE-7916-12-2.cnf.xml
133 1599 May 6 2015 16:46:18 +03:00 its/vrf1/XMLDefault7961GE-7916-24-2.cnf.xml
134 1304 May 6 2015 16:46:18 +03:00 its/vrf1/XMLDefault7962.cnf.xml
135 1466 May 6 2015 16:46:20 +03:00 its/vrf1/XMLDefault7962-7914-1.cnf.xml
136 1466 May 6 2015 16:46:20 +03:00 its/vrf1/XMLDefault7962-7915-12-1.cnf.xml
137 1466 May 6 2015 16:46:20 +03:00 its/vrf1/XMLDefault7962-7915-24-1.cnf.xml
138 1466 May 6 2015 16:46:20 +03:00 its/vrf1/XMLDefault7962-7916-12-1.cnf.xml
139 1466 May 6 2015 16:46:22 +03:00 its/vrf1/XMLDefault7962-7916-24-1.cnf.xml
140 1597 May 6 2015 16:46:22 +03:00 its/vrf1/XMLDefault7962-7914-2.cnf.xml
141 1597 May 6 2015 16:46:22 +03:00 its/vrf1/XMLDefault7962-7915-12-2.cnf.xml
142 1597 May 6 2015 16:46:22 +03:00 its/vrf1/XMLDefault7962-7915-24-2.cnf.xml
143 1597 May 6 2015 16:46:24 +03:00 its/vrf1/XMLDefault7962-7916-12-2.cnf.xml
144 1597 May 6 2015 16:46:24 +03:00 its/vrf1/XMLDefault7962-7916-24-2.cnf.xml
145 1304 May 6 2015 16:46:24 +03:00 its/vrf1/XMLDefault7965.cnf.xml
146 1466 May 6 2015 16:46:24 +03:00 its/vrf1/XMLDefault7965-7914-1.cnf.xml
147 1466 May 6 2015 16:46:26 +03:00 its/vrf1/XMLDefault7965-7915-12-1.cnf.xml
148 1466 May 6 2015 16:46:26 +03:00 its/vrf1/XMLDefault7965-7915-24-1.cnf.xml
149 1466 May 6 2015 16:46:26 +03:00 its/vrf1/XMLDefault7965-7916-12-1.cnf.xml
150 1466 May 6 2015 16:46:26 +03:00 its/vrf1/XMLDefault7965-7916-24-1.cnf.xml
151 1597 May 6 2015 16:46:28 +03:00 its/vrf1/XMLDefault7965-7914-2.cnf.xml
152 1597 May 6 2015 16:46:28 +03:00 its/vrf1/XMLDefault7965-7915-12-2.cnf.xml
153 1597 May 6 2015 16:46:28 +03:00 its/vrf1/XMLDefault7965-7915-24-2.cnf.xml
154 1597 May 6 2015 16:46:28 +03:00 its/vrf1/XMLDefault7965-7916-12-2.cnf.xml
155 1597 May 6 2015 16:46:30 +03:00 its/vrf1/XMLDefault7965-7916-24-2.cnf.xml
156 1304 May 6 2015 16:46:30 +03:00 its/vrf1/XMLDefault7970.cnf.xml
157 1466 May 6 2015 16:46:30 +03:00 its/vrf1/XMLDefault7970-7914-1.cnf.xml
158 1466 May 6 2015 16:46:30 +03:00 its/vrf1/XMLDefault7970-7915-12-1.cnf.xml
159 1466 May 6 2015 16:46:32 +03:00 its/vrf1/XMLDefault7970-7915-24-1.cnf.xml
160 1466 May 6 2015 16:46:32 +03:00 its/vrf1/XMLDefault7970-7916-12-1.cnf.xml
161 1466 May 6 2015 16:46:32 +03:00 its/vrf1/XMLDefault7970-7916-24-1.cnf.xml
162 1597 May 6 2015 16:46:32 +03:00 its/vrf1/XMLDefault7970-7914-2.cnf.xml
163 1597 May 6 2015 16:46:34 +03:00 its/vrf1/XMLDefault7970-7915-12-2.cnf.xml
164 1597 May 6 2015 16:46:34 +03:00 its/vrf1/XMLDefault7970-7915-24-2.cnf.xml
165 1597 May 6 2015 16:46:34 +03:00 its/vrf1/XMLDefault7970-7916-12-2.cnf.xml
166 1597 May 6 2015 16:46:34 +03:00 its/vrf1/XMLDefault7970-7916-24-2.cnf.xml
167 1304 May 6 2015 16:46:36 +03:00 its/vrf1/XMLDefault7971.cnf.xml
168 1466 May 6 2015 16:46:36 +03:00 its/vrf1/XMLDefault7971-7914-1.cnf.xml
169 1466 May 6 2015 16:46:36 +03:00 its/vrf1/XMLDefault7971-7915-12-1.cnf.xml
170 1466 May 6 2015 16:46:36 +03:00 its/vrf1/XMLDefault7971-7915-24-1.cnf.xml
171 1466 May 6 2015 16:46:38 +03:00 its/vrf1/XMLDefault7971-7916-12-1.cnf.xml
172 1466 May 6 2015 16:46:38 +03:00 its/vrf1/XMLDefault7971-7916-24-1.cnf.xml
173 1597 May 6 2015 16:46:38 +03:00 its/vrf1/XMLDefault7971-7914-2.cnf.xml
174 1597 May 6 2015 16:46:40 +03:00 its/vrf1/XMLDefault7971-7915-12-2.cnf.xml
175 1597 May 6 2015 16:46:40 +03:00 its/vrf1/XMLDefault7971-7915-24-2.cnf.xml
176 1597 May 6 2015 16:46:40 +03:00 its/vrf1/XMLDefault7971-7916-12-2.cnf.xml
177 1597 May 6 2015 16:46:42 +03:00 its/vrf1/XMLDefault7971-7916-24-2.cnf.xml
178 1304 May 6 2015 16:46:42 +03:00 its/vrf1/XMLDefault7975.cnf.xml
179 1466 May 6 2015 16:46:42 +03:00 its/vrf1/XMLDefault7975-7914-1.cnf.xml
180 1466 May 6 2015 16:46:42 +03:00 its/vrf1/XMLDefault7975-7915-12-1.cnf.xml
181 1466 May 6 2015 16:46:44 +03:00 its/vrf1/XMLDefault7975-7915-24-1.cnf.xml
182 1466 May 6 2015 16:46:44 +03:00 its/vrf1/XMLDefault7975-7916-12-1.cnf.xml
183 1466 May 6 2015 16:46:44 +03:00 its/vrf1/XMLDefault7975-7916-24-1.cnf.xml
184 1597 May 6 2015 16:46:44 +03:00 its/vrf1/XMLDefault7975-7914-2.cnf.xml
185 1597 May 6 2015 16:46:46 +03:00 its/vrf1/XMLDefault7975-7915-12-2.cnf.xml
186 1597 May 6 2015 16:46:46 +03:00 its/vrf1/XMLDefault7975-7915-24-2.cnf.xml
187 1597 May 6 2015 16:46:46 +03:00 its/vrf1/XMLDefault7975-7916-12-2.cnf.xml
188 1597 May 6 2015 16:46:46 +03:00 its/vrf1/XMLDefault7975-7916-24-2.cnf.xml
189 1304 May 6 2015 16:46:48 +03:00 its/vrf1/XMLDefault7985.cnf.xml
190 405 May 6 2015 16:46:48 +03:00 its/vrf1/ATADefault.cnf.xml
191 1268 May 6 2015 16:46:48 +03:00 its/vrf1/XMLDefaultCIPC.cnf.xml
192 1397 May 6 2015 16:46:50 +03:00 its/vrf1/XMLDefault6941.cnf.xml
193 1397 May 6 2015 16:46:50 +03:00 its/vrf1/XMLDefault6961.cnf.xml
194 1397 May 6 2015 16:46:50 +03:00 its/vrf1/XMLDefault6901.cnf.xml
195 1397 May 6 2015 16:46:50 +03:00 its/vrf1/XMLDefault6911.cnf.xml
196 1266 May 6 2015 16:46:52 +03:00 its/vrf1/XMLDefault7926.cnf.xml
197 1397 May 6 2015 16:46:52 +03:00 its/vrf1/XMLDefault6945.cnf.xml
198 1397 May 6 2015 16:46:52 +03:00 its/vrf1/XMLDefault8941.cnf.xml
199 1397 May 6 2015 16:46:52 +03:00 its/vrf1/XMLDefault8945.cnf.xml
200 903 May 6 2015 16:46:54 +03:00 its/united_states_7960-tones.xml
201 8777 May 6 2015 16:46:54 +03:00 its/united_states_7960-font.xml
202 1313 May 6 2015 16:46:54 +03:00 its/united_states_7960-kate.xml
203 19750 May 6 2015 16:46:54 +03:00 its/united_states_7960-dictionary.xml
204 2740 May 6 2015 16:46:56 +03:00 its/united_states_SCCP-dictionary.xml
205 1479 May 6 2015 16:59:48 +03:00 its/vrf1/SEPC40ACBE01AC4.cnf.xml
206 593920 May 6 2015 17:34:38 +03:00 cucme-mlpp.tar
207 0 May 6 2015 17:35:44 +03:00 cucme-mlpp
208 1755 May 6 2015 17:35:44 +03:00 cucme-mlpp/cucme-mlpp-readme.txt
209 0 May 6 2015 17:35:44 +03:00 cucme-mlpp/G729
210 8532 May 6 2015 17:35:46 +03:00 cucme-mlpp/G729/ATQA.wav
211 9052 May 6 2015 17:35:46 +03:00 cucme-mlpp/G729/BNEA.wav
212 7612 May 6 2015 17:35:46 +03:00 cucme-mlpp/G729/BPA.wav
213 10872 May 6 2015 17:35:46 +03:00 cucme-mlpp/G729/ICA.wav
214 8062 May 6 2015 17:35:48 +03:00 cucme-mlpp/G729/PALA.wav
215 9312 May 6 2015 17:35:48 +03:00 cucme-mlpp/G729/UPA.wav
216 9282 May 6 2015 17:35:48 +03:00 cucme-mlpp/G729/VCA.wav
217 0 May 6 2015 17:35:48 +03:00 cucme-mlpp/G711AU
218 68980 May 6 2015 17:35:48 +03:00 cucme-mlpp/G711AU/ATQA.au
219 73090 May 6 2015 17:35:50 +03:00 cucme-mlpp/G711AU/BNEA.au
220 61550 May 6 2015 17:35:50 +03:00 cucme-mlpp/G711AU/BPA.au
221 87706 May 6 2015 17:35:50 +03:00 cucme-mlpp/G711AU/ICA.au
222 65165 May 6 2015 17:35:50 +03:00 cucme-mlpp/G711AU/PALA.au
223 75199 May 6 2015 17:35:52 +03:00 cucme-mlpp/G711AU/UPA.au
224 74976 May 6 2015 17:35:52 +03:00 cucme-mlpp/G711AU/VCA.au
225 1588 Aug 25 2015 18:58:18 +03:00 its/vrf1/SEP44ADD9BC0E5A.cnf.xml
226 1588 Aug 25 2015 19:00:06 +03:00 its/vrf1/SEP44ADD9BC0E8E.cnf.xml
227 1588 Aug 25 2015 19:00:22 +03:00 its/vrf1/SEP44ADD9BC0B71.cnf.xml
228 1588 Aug 25 2015 19:00:32 +03:00 its/vrf1/SEP44ADD9BC0AB7.cnf.xml
229 1588 Aug 25 2015 19:00:46 +03:00 its/vrf1/SEP44ADD9BC0DCE.cnf.xml
230 1588 Aug 25 2015 19:00:58 +03:00 its/vrf1/SEP44ADD9BC0AB8.cnf.xml
231 2511358 Nov 19 2015 15:44:10 +03:00 kern2.78xx.10-3-1-12.sbn
232 3092888 Nov 19 2015 15:44:48 +03:00 kern78xx.10-3-1-12.sbn
233 41419092 Nov 19 2015 15:46:54 +03:00 rootfs2.78xx.10-3-1-12.sbn
234 39321936 Nov 19 2015 15:49:02 +03:00 rootfs78xx.10-3-1-12.sbn
235 596536 Nov 19 2015 15:49:24 +03:00 sboot2.78xx.10-3-1-12.sbn
236 370348 Nov 19 2015 15:49:46 +03:00 sboot78xx.10-3-1-12.sbn
237 1206 Nov 19 2015 15:50:06 +03:00 sip78xx.10-3-1-12.loads
53772288 bytes available (202715136 bytes used)
Dear zaidysharib
Did you do the step above???
what is the result of the debugs bellow
debug ccsip messages
debug tftp events
Note that you mast do it when the phone tries to register
Best Regards
ART
but the problem of router ios 15.2 upgrade to 15.4
but still error (REGISTERING)
Hi zaidysharib
Did you had problems to issue the commands???
If not... try to debug to see the problem
debug tftp events
Best Regards
ART
if i will run this command any pronblem in exist phone because i am working in live senario and i have a little bit knwledege about voice
debug tftp events
Dear zaidysharib
For debug command you will not cause any problem, debug is for diagnostic propose.
feel free to debug, sure you will not have problem with this...
debug tftp events
After this
undebug all
Best Regards
ART
i am using 7821 cisco phones some of the phone is working well but
some are registered but not able to make any call it give busy tone if i am trying to call on any other extension or out side. forexample i am facing issue with pool 4 can you help in this regard
! Last configuration change at 15:35:39 gmt Wed Jan 13 2016 by admin
! NVRAM config last updated at 14:19:31 gmt Tue Jan 12 2016 by admin
version 15.4
service password-encryption
hostname APSG_CME
boot-start-marker
boot system flash:c2951-universalk9-mz.SPA.154-3.M1.bin
boot-end-marker
logging buffered 500000
no logging console
no logging monitor
enable secret 5 $1$MK0X$bCaR7Ro5BVqMDyIZv.GaN/
enable password 7 132407560C2C567A7A71
no aaa new-model
clock timezone gmt 3 0
ip dhcp excluded-address 192.168.10.1 192.168.10.50
ip dhcp excluded-address 192.168.20.1 192.168.20.50
ip dhcp excluded-address 192.168.50.0 192.168.50.254
ip dhcp pool DATA
 network 192.168.10.0 255.255.255.0
 default-router 192.168.10.5
 dns-server 192.168.50.2 192.168.50.3
 lease 2
ip dhcp pool VOICE
 network 192.168.20.0 255.255.255.0
 default-router 192.168.20.5
 option 150 ip 192.168.20.5
ip dhcp pool SERVERS
 network 192.168.50.0 255.255.255.0
 default-router 192.168.50.1
ip cef
no ipv6 cef
trunk group STC
trunk group LOCAL
cts logging verbose
voice-card 0
voice service voip
 dtmf-interworking rtp-nte
 no supplementary-service h450.2
 no supplementary-service h450.3
 supplementary-service h450.12
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  registrar server
  video screening
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g729r8
voice class codec 222
 codec preference 1 g729r8
voice class dualtone-detect-params 1
 freq-min-power 35
 freq-power-twist 15
 cadence-variation 20
voice class dualtone-detect-params 60
 freq-max-deviation 30
 freq-max-power 15
 freq-min-power 35
 freq-power-twist 10
voice class custom-cptone cptone
 dualtone disconnect
  frequency 425
  cadence 350 350
voice class custom-cptone STC
 dualtone disconnect
  frequency 420 435
  cadence 255 245
voice class custom-cptone SA-CUSTOM
 dualtone disconnect
  frequency 425
  cadence 250 250
voice class custom-cptone SA-TEST1
 dualtone disconnect
  frequency 406
  cadence 500 500
voice class custom-cptone Disconnect
 dualtone disconnect
  frequency 420 420
  cadence 251 255 245 250 249 250 250 250
voice register pool-type  8831
 description Conference  Phone 8831
 mode  cme
 source-address 192.168.20.5 port 5060
 max-dn 100
 max-pool 100
 load 7821 sip78xx.10-1-1SR1-4.loads
 timezone 31
 date-format D/M/Y
 hold-alert
 mwi stutter
 mwi reg-e164
 call-forward system redirecting-expanded
 tftp-path flash:
 create profile sync 2030695500558474
 camera
 video
voice register dn  1
 number 1001
 name Mahmoud Salama
voice register dn  2
 number 1002
 name Abdul Rauf
voice register dn  3
 number 1003
 name Saad
voice register dn  4
 number 1004
 name Syed Nehal Ahmed
voice register dn  5
 number 1005
 name Nasser Faramaway
voice register dn  6
 number 1006
 name Mohamed Kamran
voice register dn  7
 number 1007
 name Raheel Adeeb Bakhsh
voice register dn  8
 number 1008
 name Emad Mansour
voice register dn  9
 number 1009
 name Mohammad Nosser
voice register dn  10
 number 1010
 name Mohamed Gamal
voice register dn  11
 number 1011
 name Phone 11
voice register dn  12
 number 1012
 name Abdullah Khalifa
voice register dn  13
 number 1013
 name Ahmed Mohammad Sulaiman
voice register dn  14
 number 1014
 name Moataz Talaat
voice register dn  15
 number 1015
 name Salah Ghallab
voice register dn  16
 number 1016
 name Rayan AlOwedi
voice register dn  17
 number 1017
 name Sultan AL Jabri
voice register dn  18
 number 1018
 name Ahmed Abbas
voice register dn  19
 number 1019
 name Abbas Bawazeer
voice register dn  20
 number 1020
 name Adham AbuSarhad
voice register dn  21
 number 1021
 name Ahmed Al Sherbiny
voice register dn  22
 number 1022
 name Shafiq Ahmed
voice register dn  23
 number 1023
 name Abdul Moniem Mukhtar Ahmed
voice register dn  24
 number 1024
 name Phone24
voice register dn  25
 number 1025
 name Saif Ul Islam
voice register dn  26
 number 1026
 name Aboda AbdulAziz
voice register dn  27
 number 1027
 name Muhammad Shabana
voice register dn  28
 number 1028
 name Turki AbuRas
voice register dn  29
 number 1029
 call-forward b2bua all 1032
 name CS-4
voice register dn  30
 number 1030
 name Musaab Abdu Saeed
voice register dn  31
 number 1031
 name Elham AbuSarhad
voice register dn  32
 number 1032
 name CS-1
voice register dn  33
 number 1033
 name Anas Yehya Omar Aldawelah
voice register dn  34
 number 1034
 name Sultan Khudari
voice register dn  35
 number 1035
 name Hani Bin Anas
voice register dn  50
 number 1050
 name Conference Phone
voice register dn  51
 number 1051
 name Israa Muhammad
voice register dn  52
 number 1052
 name Leila Alothman
voice register dn  53
 number 1053
 name Shaimaa Salim
voice register dn  54
 number 1054
 name Alaa Elden Waheeb
voice register dn  55
 number 1055
 name Ahmed Hamdi
voice register dn  56
 number 1056
 name Loay Labani
voice register dn  57
 number 1057
 name Mehreen Tanveer
voice register dn  58
 number 1058
 name Israa Fatta
voice register dn  59
 number 1059
 name Abdul Rehman AL-Khaldi
voice register dn  60
 number 1060
 name Ali AbuSarhad
voice register dn  61
 number 1061
 name Ahmed Alwi
voice register dn  62
 number 1062
 name Ahmed Rafaai
voice register dn  63
 number 1063
 name Khalid Alamer
voice register dn  64
 number 1064
 name Ziyad Muhammad
voice register dn  65
 number 1065
 name Mohammad Rashed
voice register dn  66
 number 1066
 name Nayef Al Thaghafi
voice register dn  67
 number 1067
 name Rabee Saleem
voice register template  1
 pin 12345
 busy-trigger-per-button 1
 id mac 381C.1ABB.FFB6
 type 9951
 number 1 dn 1
 dtmf-relay rtp-nte
 username cisco1 password 1001
 description M.Salama
 codec g711ulaw
 conference add-mode creator
voice register pool  2
 id mac 381C.1ABB.FAE2
 type 9951
 number 1 dn 2
 dtmf-relay rtp-nte
 username cisco2 password 1002
 description A Rauf
 codec g711ulaw
voice register pool  3
 id mac 381C.1ABB.FADE
 type 9951
 number 1 dn 3
 dtmf-relay rtp-nte
 username cisco3 password 1003
 description Saad
 codec g711ulaw
voice register pool  4
 id mac 544A.0037.1350
 type 7821
 number 1 dn 4
 dtmf-relay rtp-nte
 username cisco4 password 1004
 description Syed Nehal
 codec g711ulaw
voice register pool  5
 id mac 544A.0037.3085
 type 7821
 number 1 dn 5
 dtmf-relay rtp-nte
 username cisco5 password 1005
 description N Faramaway
 codec g711ulaw
voice register pool  6
 id mac 544A.0037.1336
 type 7821
 number 1 dn 6
 dtmf-relay rtp-nte
 username cisco6 password 1006
 description M.Kamran
 codec g711ulaw
voice register pool  7
 id mac 544A.0037.302A
 type 7821
 number 1 dn 7
 dtmf-relay rtp-nte
 username cisco7 password 1007
 description Raheel
 codec g711ulaw
voice register pool  8
 id mac 544A.0037.13A8
 type 7821
 number 1 dn 8
 dtmf-relay rtp-nte
 username cisco8 password 1008
 description Emad
 codec g711ulaw
voice register pool  9
 id mac 544A.0037.13BE
 type 7821
 number 1 dn 9
 dtmf-relay rtp-nte
 username cisco9 password 1009
 description M Nosser
 codec g711ulaw
voice register pool  10
 pin 12345
 id mac 544A.0037.1339
 type 7821
 number 1 dn 10
 dtmf-relay rtp-nte
 username cisco10 password 1010
 description M-Gamal
 codec g711ulaw
voice register pool  11
 id mac 544A.0037.2FD8
 type 7821
 number 1 dn 11
 dtmf-relay rtp-nte
 username cisco11 password 1011
 description Phone 11
 codec g711ulaw
voice register pool  12
 id mac 544A.0037.12FC
 type 7821
 number 1 dn 12
 dtmf-relay rtp-nte
 username cisco12 password 1012
 description A Khalifa
 codec g711ulaw
voice register pool  13
 id mac 544A.0037.2FD9
 type 7821
 number 1 dn 13
 dtmf-relay rtp-nte
 username cisco13 password 1013
 description Ahmed
 codec g711ulaw
voice register pool  14
 id mac 544A.0037.131B
 type 7821
 number 1 dn 14
 dtmf-relay rtp-nte
 username cisco14 password 1014
 description Moataz
 codec g711ulaw
voice register pool  15
 id mac 544A.0037.133D
 type 7821
 number 1 dn 15
 dtmf-relay rtp-nte
 username cisco15 password 1015
 description S Ghallab
 codec g711ulaw
voice register pool  16
 id mac 544A.0037.1314
 type 7821
 number 1 dn 16
 dtmf-relay rtp-nte
 username cisco16 password 1016
 description Rayan
 codec g711ulaw
voice register pool  17
 id mac 544A.0037.3032
 type 7821
 number 1 dn 17
 dtmf-relay rtp-nte
 username cisco17 password 1017
 description Sultan
 codec g711ulaw
voice register pool  18
 id mac 544A.0037.1340
 type 7821
 number 1 dn 18
 dtmf-relay rtp-nte
 username cisco18 password 1018
 description Ahmed Abbas
 codec g711ulaw
voice register pool  19
 id mac 544A.0037.1560
 type 7821
 number 1 dn 19
 dtmf-relay rtp-nte
 username cisco19 password 1019
 description A Bawazeer
 codec g711ulaw
voice register pool  20
 id mac 544A.0037.1301
 type 7821
 number 1 dn 20
 dtmf-relay rtp-nte
 username cisco20 password 1020
 description Adham
 codec g711ulaw
voice register pool  21
 id mac 544A.0037.139B
 type 7821
 number 1 dn 21
 dtmf-relay rtp-nte
 username cisco21 password 1021
 description A Sherbiny
 codec g711ulaw
voice register pool  22
 id mac 544A.0037.3038
 type 7821
 number 1 dn 22
 dtmf-relay rtp-nte
 username cisco22 password 1022
 description Shafiq
 codec g711ulaw
voice register pool  23
 id mac 544A.0037.302E
 type 7821
 number 1 dn 23
 dtmf-relay rtp-nte
 username cisco23 password 1023
 description Abdulmoniem
 codec g711ulaw
voice register pool  24
 pin 1024
 id mac C472.95A8.A618
 type 7821
 number 1 dn 24
 dtmf-relay rtp-nte
 username cisco24 password 1024
 description Phone24
 codec g711ulaw
voice register pool  25
 id mac C472.95A8.A315
 type 7821
 number 1 dn 25
 dtmf-relay rtp-nte
 username cisco25 password 1025
 description Saif
 codec g711ulaw
voice register pool  26
 id mac C472.95A8.A5E0
 type 7821
 number 1 dn 26
 dtmf-relay rtp-nte
 username cisco26 password 1026
 description Aboda
 codec g711ulaw
voice register pool  27
 id mac C472.95A8.A5C7
 type 7821
 number 1 dn 27
 dtmf-relay rtp-nte
 username cisco27 password 1027
 description M Shabana
 codec g711ulaw
voice register pool  28
 id mac C472.95A8.A5E9
 type 7821
 number 1 dn 28
 dtmf-relay rtp-nte
 username cisco28 password 1028
 description Turki
 codec g711ulaw
voice register pool  29
 id mac C472.95A8.A560
 type 7821
 number 1 dn 29
 dtmf-relay rtp-nte
 username cisco29 password 1029
 description CS-4
 codec g711ulaw
voice register pool  30
 id mac C472.95A8.A2E6
 type 7821
 number 1 dn 30
 dtmf-relay rtp-nte
 username cisco30 password 1030
 description Musab
 codec g711ulaw
voice register pool  31
 pin 12345
 id mac C472.95A8.A57B
 type 7821
 number 1 dn 31
 dtmf-relay rtp-nte
 username cisco31 password 1031
 description ELHAM
 codec g711ulaw
voice register pool  32
 pin 12345
 id mac C472.95A8.A5AE
 type 7821
 number 1 dn 32
 dtmf-relay rtp-nte
 username cisco32 password 1032
 description CS-1
 codec g711ulaw
voice register pool  33
 id mac B07D.47D1.E0BF
 type 7821
 number 1 dn 33
 dtmf-relay rtp-nte
 username cisco33 password 1033
 description Anas Yehya
 codec g711ulaw
voice register pool  34
 id mac B07D.47D1.E35B
 type 7821
 number 1 dn 34
 dtmf-relay rtp-nte
 username cisco34 password 1034
 description Sultan
 codec g711ulaw
voice register pool  35
 id mac B07D.47D1.E366
 type 7821
 number 1 dn 35
 dtmf-relay rtp-nte
 username cisco35 password 1035
 description Hani
 codec g711ulaw
voice register pool  50
 busy-trigger-per-button 4
 id mac AC44.F210.F2A0
 type 8831
 number 1 dn 50
 dtmf-relay rtp-nte
 username 1050 password 1050
 codec g711ulaw
 no vad
 camera
 video
voice register pool  51
 id mac C472.95A8.A567
 type 7821
 number 1 dn 51
 dtmf-relay rtp-nte
 username cisco51 password 1051
 description Israa
 codec g711ulaw
voice register pool  52
 pin 1052
 id mac C472.95A8.A5DA
 type 7821
 number 1 dn 52
 dtmf-relay rtp-nte
 username cisco52 password 1052
 description Leila
 codec g711ulaw
voice register pool  53
 pin 1053
 id mac C472.95A8.A600
 type 7821
 number 1 dn 53
 dtmf-relay rtp-nte
 username cisco53 password 1053
 description Shaimaa
 codec g711ulaw
voice register pool  54
 pin 1054
 id mac C472.95A8.A5D5
 type 7821
 number 1 dn 54
 dtmf-relay rtp-nte
 username cisco54 password 1054
 description Alaa Elden
 codec g711ulaw
voice register pool  55
 pin 1055
 id mac C472.95A8.A5FB
 type 7821
 number 1 dn 55
 dtmf-relay rtp-nte
 username cisco55 password 1055
 description Ahmed Hamdi
 codec g711ulaw
voice register pool  56
 pin 1056
 id mac C472.95A8.A5F6
 type 7821
 number 1 dn 56
 dtmf-relay rtp-nte
 username cisco56 password 1056
 description Loay Labani
 codec g711ulaw
voice register pool  57
 pin 1057
 id mac C472.95A8.AEB7
 type 7821
 number 1 dn 57
 dtmf-relay rtp-nte
 username cisco57 password 1057
 description Mehreen
 codec g711ulaw
voice register pool  58
 pin 1058
 id mac C472.95A8.A2EA
 type 7821
 number 1 dn 58
 dtmf-relay rtp-nte
 username cisco58 password 1058
 description Israa Fata
 codec g711ulaw
voice register pool  59
 pin 1059
 id mac C472.95A8.A548
 type 7821
 number 1 dn 59
 dtmf-relay rtp-nte
 username cisco59 password 1059
 description AL-Khaldi
 codec g711ulaw
voice register pool  60
 pin 1060
 id mac C472.95A8.AC32
 type 7821
 number 1 dn 60
 dtmf-relay rtp-nte
 username cisco60 password 1060
 description A.AbuSarhad
 codec g711ulaw
voice register pool  61
 pin 1061
 id mac C472.95A8.A323
 type 7821
 number 1 dn 61
 dtmf-relay rtp-nte
 username cisco61 password 1061
 description Ahmed Alwi
 codec g711ulaw
voice register pool  62
 pin 1062
 id mac C472.95A8.A332
 type 7821
 number 1 dn 62
 dtmf-relay rtp-nte
 username cisco62 password 1062
 description Ahmed
 codec g711ulaw
voice register pool  63
 pin 1063
 id mac C472.95A8.A305
 type 7821
 number 1 dn 63
 dtmf-relay rtp-nte
 username cisco63 password 1063
 description Khalid
 codec g711ulaw
voice register pool  64
 pin 1064
 id mac C472.95A8.A599
 type 7821
 number 1 dn 64
 dtmf-relay rtp-nte
 username cisco64 password 1064
 description Ziyad
 codec g711ulaw
voice register pool  65
 pin 1065
 id mac C472.95A8.A8D0
 type 7821
 number 1 dn 65
 dtmf-relay rtp-nte
 username cisco65 password 1065
 description Rashed
 codec g711ulaw
voice register pool  66
 pin 1066
 id mac C472.95A8.AECB
 type 7821
 number 1 dn 66
 dtmf-relay rtp-nte
 username cisco66 password 1066
 description Nayef
 codec g711ulaw
voice register pool  67
 pin 1067
 id mac C472.95A8.A5E8
 type 7821
 number 1 dn 67
 dtmf-relay rtp-nte
 username cisco67 password 1067
 description Rabee Saleem
 codec g711ulaw
license udi pid CISCO2951/K9 sn FCZ1826605E
hw-module ism 0
hw-module pvdm 0/0
hw-module pvdm 0/1
username admin privilege 15 secret 5 $1$ZN2o$WJ.I1vAu1ZMY2oIO68RCh0
username mgamal privilege 15 secret 5 $1$th3a$T2f54GXWqI3ZTDwsZar570
username cisco4
username cisco52 password 7 0257540E59
username cisco35 password 7 1158495642
redundancy
interface Loopback0
 no ip address
interface Embedded-Service-Engine0/0
 no ip address
 description ****connected to LAN****
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/0.10
 description ***DATA SUBNET***
 encapsulation dot1Q 10
 ip address 192.168.10.5 255.255.255.0
interface GigabitEthernet0/0.20
 description ***VOICE SUBNET***
 encapsulation dot1Q 20
 ip address 192.168.20.5 255.255.255.0
interface GigabitEthernet0/0.50
 encapsulation dot1Q 50
 ip address 192.168.50.1 255.255.255.0
interface ISM0/0
 ip unnumbered GigabitEthernet0/0.20
 service-module ip address 192.168.20.10 255.255.255.0
 service-module ip default-gateway 192.168.20.5
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface ISM0/1
 description Internal switch interface connected to Internal Service Module
 no ip address
interface Vlan1
 no ip address
ip forward-protocol nd
ip http server
no ip http secure-server
ip http path flash:
ip nat inside source list 107 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 192.168.10.1
ip route 10.208.9.69 255.255.255.255 10.68.35.209
ip route 192.168.20.10 255.255.255.255 ISM0/0
nls resp-timeout 1
cpd cr-id 1
tftp-server flash:sip78xx.10-2-1-12SR1-4.loads
tftp-server flash:sboot78xx.10-2-1-12SR1-4.sbn
tftp-server flash:rootfs78xx.10-2-1-12SR1-4.sbn
tftp-server flash:kern78xx.10-2-1-12SR1-4.sbn
tftp-server flash:kern78xx.10-1-1SR1-4.sbn
access-list 107 permit ip 192.168.50.0 0.0.0.255 any
control-plane
voice-port 0/0/0
 trunk-group LOCAL
 cptone BR
 connection plar opx 1995
 caller-id enable
 caller-id alerting line-reversal
 caller-id alerting dsp-pre-allocate
voice-port 0/0/1
 trunk-group LOCAL
 supervisory disconnect dualtone mid-call
 cptone SA
 timeouts call-disconnect 1
 timeouts ringing 20
 timeouts wait-release 1
 timing hookflash-out 500
 caller-id enable
voice-port 0/0/2
 cptone SA
 timeouts ringing 20
 caller-id enable
voice-port 0/0/3
 cptone SA
 timeouts ringing 20
 caller-id enable
voice-port 0/1/0
 cptone SA
 timeouts ringing 20
 caller-id enable
voice-port 0/1/1
 cptone SA
 timeouts ringing 20
 caller-id enable
voice-port 0/1/2
 trunk-group LOCAL
 cptone SA
 timeouts ringing 20
 caller-id enable
voice-port 0/1/3
 cptone SA
 timeouts ringing 20
 caller-id enable
voice-port 0/2/0
 trunk-group LOCAL
 cptone SA
 timeouts ringing 20
 caller-id enable
voice-port 0/2/1
 cptone SA
 timeouts ringing 20
 caller-id enable
voice-port 0/2/2
 cptone SA
 timeouts ringing 20
 connection plar opx 1031
 caller-id enable
voice-port 0/2/3
 trunk-group LOCAL
 cptone SA
 timeouts ringing 20
 connection plar opx 1058
 caller-id enable
voice-port 0/3/0
 cptone SA
 timeouts ringing 20
 caller-id enable
voice-port 0/3/1
 cptone SA
 timeouts ringing 20
 description ** Mobile Call  **
 caller-id enable
voice-port 0/3/2
 cptone SA
 timeouts ringing 20
 caller-id enable
voice-port 0/3/3
 cptone SA
 timeouts ringing 20
 caller-id enable
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
 paramspace callsetup after-hours-exempt FALSE
 destination-pattern 9[2,6]......
 fax rate disable
 bandwidth maximum 0 minimum 0
 no digit-strip
 forward-digits 7
 prefix 168.20.164:5060
 no register e164
 preemption level flash-override
dial-peer voice 2 pots
 description ** International Call  **
 destination-pattern 900T
 port 0/0/2
 prefix 00
dial-peer voice 3 pots
 trunkgroup STC
 description ** national calls  **
 translation-profile outgoing to-old
 preference 1
 destination-pattern 901[123467].......
 forward-digits 10
dial-peer voice 4 pots
 trunkgroup STC
 destination-pattern 905........
 forward-digits 10
dial-peer voice 5 pots
 trunkgroup STC
 trunkgroup LOCAL
 description STC Service Numbers
 preference 10
 destination-pattern 990.
 forward-digits 3
dial-peer voice 6 pots
 trunkgroup STC
 trunkgroup LOCAL
 preference 10
 destination-pattern 9800.......
 forward-digits 10
dial-peer voice 7 pots
 trunkgroup LOCAL
 description 9200 numbers
 preference 10
 destination-pattern 99200.....
 forward-digits 9
dial-peer voice 1999 voip
 destination-pattern 199.
 session target ipv4:192.168.20.10
 codec g711ulaw
 no vad
dial-peer voice 10022 pots
 port 0/0/2
 prefix 00
dial-peer voice 10023 pots
 preference 1
 port 0/0/2
 forward-digits 10
dial-peer voice 10024 pots
 port 0/0/2
 forward-digits 10
dial-peer voice 10032 pots
 port 0/0/3
 prefix 00
dial-peer voice 10033 pots
 preference 1
 port 0/0/3
 forward-digits 10
dial-peer voice 10034 pots
 port 0/0/3
 forward-digits 10
dial-peer voice 10112 pots
 port 0/1/1
 prefix 00
dial-peer voice 10113 pots
 preference 1
 port 0/1/1
 forward-digits 10
dial-peer voice 10114 pots
 port 0/1/1
 forward-digits 10
dial-peer voice 10132 pots
 port 0/1/3
 prefix 00
dial-peer voice 10133 pots
 preference 1
 port 0/1/3
 forward-digits 10
dial-peer voice 10134 pots
 port 0/1/1
 forward-digits 10
dial-peer voice 10212 pots
 port 0/0/2
 prefix 00
dial-peer voice 10213 pots
 preference 1
 port 0/2/1
 forward-digits 10
dial-peer voice 10214 pots
 port 0/2/1
 forward-digits 10
dial-peer voice 10222 pots
 port 0/2/2
 prefix 00
dial-peer voice 10223 pots
 preference 1
 port 0/2/2
 forward-digits 10
dial-peer voice 10224 pots
 port 0/2/2
 forward-digits 10
dial-peer voice 10302 pots
 port 0/3/0
 prefix 00
dial-peer voice 10303 pots
 preference 1
 port 0/3/0
 forward-digits 10
dial-peer voice 10304 pots
 port 0/3/0
 forward-digits 10
dial-peer voice 10312 pots
 port 0/3/1
 prefix 00
dial-peer voice 10313 pots
 preference 1
 port 0/3/1
 forward-digits 10
dial-peer voice 10314 pots
 port 0/3/1
 forward-digits 10
dial-peer voice 10322 pots
 port 0/3/2
 prefix 00
dial-peer voice 10323 pots
 preference 1
 port 0/3/2
 forward-digits 10
dial-peer voice 10324 pots
 port 0/3/2
 forward-digits 10
dial-peer voice 10332 pots
 port 0/3/3
 prefix 00
dial-peer voice 10333 pots
 preference 1
 port 0/3/3
 forward-digits 10
dial-peer voice 10334 pots
 port 0/3/3
 forward-digits 10
dial-peer voice 1222551 voip
 description ** STC to call Center  **
 destination-pattern 1222.....
 session target ipv4:192.168.50.56
dial-peer voice 122251 voip
 destination-pattern 01222.....
dial-peer voice 10335 pots
 description ** Test  **
 preference 1
 port 0/3/3
 forward-digits 9
dial-peer voice 10336 pots
 preference 1
 port 0/0/0
 forward-digits 9
dial-peer voice 10337 pots
 preference 1
 port 0/0/1
 forward-digits 9
dial-peer voice 10338 pots
 preference 1
 port 0/0/2
 forward-digits 9
dial-peer voice 11330 pots
 preference 1
 port 0/0/2
 forward-digits 10
dial-peer voice 11331 pots
 preference 1
 port 0/0/0
 forward-digits 10
dial-peer voice 11332 pots
 preference 1
 port 0/0/1
 forward-digits 10
dial-peer voice 1129 pots
 preference 1
 port 0/1/3
 forward-digits 10
dial-peer voice 1139 pots
 preference 1
 port 0/1/2
 forward-digits 10
dial-peer voice 1140 pots
 preference 1
 port 0/1/2
 forward-digits 3
dial-peer voice 1141 pots
 preference 1
 port 0/1/2
 forward-digits 9
gatekeeper
 shutdown
credentials
telephony-service
 conference hardware
 no auto-reg-ephone
 max-ephones 51
 max-dn 51
 ip source-address 192.168.10.5 port 2000
 auto assign 1 to 51
 keepalive 40
 max-conferences 10 gain -6
 web admin system name alfuzail secret 5 $1$tmMP$OLz5DlOnShyddHE/ZLqA4/
 dn-webedit
 time-webedit
 transfer-pattern 9.T
 after-hours day Sun 00:01 23:59
 after-hours day Mon 00:01 23:59
 after-hours day Tue 00:01 23:59
 after-hours day Wed 00:01 23:59
 after-hours day Thu 00:01 23:59
 after-hours day Fri 00:01 23:59
 after-hours day Sat 00:01 23:59
 create cnf-files version-stamp 7960 Dec 30 2015 13:06:21
ephone-dn-template  4
ephone-template  1
ephone-template  2
ephone-dn  4
ephone-dn  8
 number 1008
 name Yasir
ephone-dn  24
ephone-dn  51
 number 1051
ephone  4
ephone  51
 mac-address C472.95A8.A567
 button  1:51
line con 0
 login local
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line 195
 no exec
 transport input all
 stopbits 1
line vty 0
 privilege level 15
 password 7 070E315F49584B5643
 login local
 no domain-lookup
 transport input all
line vty 1
 login local
 no domain-lookup
 transport input all
line vty 2
 login local
 no domain-lookup
 transport input all
line vty 3 4
 login local
 no domain-lookup
 transport input all
line vty 5 15
 login local
 no domain-lookup
 transport input all
scheduler allocate 20000 1000
ntp master 1
end
hey nehal,
plz go to config command and run this command insha allah fix the problem plz try it,,,,,,,,,,,,,
no create profile
create profile
Best Regards
hi zaidy
i already did the same,but still not working
my issue is phone got register but not making any calls after register
this is earlier command in show flash
and recenty showing this command in my router
233 104134844 Dec 2 2015 14:40:34 +03:00 c2900-universalk9-mz.SPA.154-3.M2.bin
234 596536 Nov 19 2015 15:49:24 +03:00 sboot2.78xx.10-3-1-12.sbn
235 370348 Nov 19 2015 15:49:46 +03:00 sboot78xx.10-3-1-12.sbn
236 1206 Nov 19 2015 15:50:06 +03:00 sip78xx.10-3-1-12.loads
237 41419092 Dec 2 2015 14:49:10 +03:00 rootfs2.78xx.10-3-1-12.sbn
238 824 Dec 3 2015 10:35:58 +03:00 its/featurePolicyDefault.xml
239 3855 Dec 3 2015 10:35:58 +03:00 its/SEP204C9EB32881.cnf.xml
240 4748 Dec 3 2015 10:35:58 +03:00 its/softkeyDefault_kpml.xml
241 4782 Dec 3 2015 10:35:58 +03:00 its/softkeyDefault.xml
242 1947 Dec 3 2015 10:35:56 +03:00 its/SIPDefault.cnf
243 69 Dec 3 2015 10:35:56 +03:00 its/syncinfo.xml
244 3861 Dec 3 2015 10:35:58 +03:00 its/SEP204C9EB3288C.cnf.xml
and 1 file is missing in recently command
(rootfs78xx.10-3-1-12.sbn)
if this is not exist then it would be any issue please assist me ...........
Note that every change you do must do this...
no create profile
create profile
Best Regards
ART
this command i used but same error in phone 7821  error (Registering)
no create profile
create profile
Best Regards
It's help me a lot: its solved the same issue I'd encounter.
Mine router version is:
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.4(3)M1
and CME version:
Version 10.5
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
The command about is working in my side and it's working: Except for this commands:
voice register pool-type 7821
xml-config maxNumCalls 6
xml-config busyTrigger 6
xml-config custom sshAccess 0
num-lines 2
description Cisco IP Phone 7821
reference-pooltype 6921
Weird but it fine with it.. I already registered my two (2) 7821 Phone and I can give call to each other.
sample configs to boot 7821 on C29xx Routers
mode cme
source-address x.x.x.x port 5060
max-dn 150
max-pool 10
load 7821 sip78xx.10-2-1-12SR1-4
timezone 31
time-format 24
hold-alert
voicemail xxxx
tftp-path flash:
file text
create profile sync 0609704072092917
network-locale GB
voice register dn 1
number 1001
name X
Label X
type 7821
number 1 dn 1
codec g711ulaw
dtmf-relay rtp-nte
username xxxx password xxxx
Dear,
I have CME has 7821 phones has been registered and working fine. I want to add new 7821 but I am not able. So After I add the new phone I should do
No create profile.
Create Profile
After I add the new 7821 I did the
Reset command and there was an error message
No contact info available for pool xx. What does this message mean ?
If did not use this command the phone will not register. What about factory reset Is it compensatory. I will try to do the commands above by next Sunday and I will update you I hope it will work.
Zadjali
