02-06-2013 08:52 AM - edited 03-16-2019 03:34 PM
Hello everyone, first time here, need a little help.
I'm having some trouble to find a solution to the following problem.
Recently I've installed CME 9.1 using the router 2921. Most of the phones are SIPs, model 3905 (around 20 of them), with the last firmware updated.
Some users are complaining one way audio issue in internal calls, from a extension to another (only in sip phones)
With Wireshark capture I could see that RTP packets are being sent and receive by the router and not directly trough the phones. Is this normal in CME? When a call with problems occours (one way audio) there is no audio in one way, but router still sends confort noise packets.
Here is my config.
Thanks for any help.
Martin
##################################################################################33
System restarted at 11:29:23 BR Tue Jan 29 2013
System image file is "flash0:c2900-universalk9-mz.SPA.152-4.M2.bin"
Last reload type: Normal Reload
Last reload reason: power-on
voice service voip
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server expires max 3600 min 120
voice register global
mode cme
source-address 10.3.245.1 port 5060
max-dn 60
max-pool 70
load ATA-187 ATA187.9-2-3-1
load 3905 CP3905.9-2-1-0
authenticate realm all
timezone 17
time-format 24
date-format D/M/Y
tftp-path flash:
file text
create profile sync 0094230880392697
network-locale U1
user-locale U1 load /CME-locale-pt_BR-Portuguese-8.8.2.5.tar
ntp-server 10.3.244.7 mode directedbroadcast
voice register dn 1
number 9006
name Sala_Reuniao_02
label Sala de Reuniao 2
voice register dn 2
number 9007
name Sala_Reuniao_03
voice register dn 3
number 9008
name Sala Reuniao 04
voice register pool 1
id mac 8478.ACE6.09A2
type 3905
number 1 dn 1
template 1
codec g711ulaw
voice register pool 2
id mac 8478.ACE6.0573
type 3905
number 1 dn 2
codec g711ulaw
voice register pool 3
id mac 5897.1ECD.8F8D
type 3905
number 1 dn 3
codec g711ulaw
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.220
encapsulation dot1Q 220
ip address 10.3.245.1 255.255.255.0
ip helper-address 10.3.244.71
h323-gateway voip bind srcaddr 10.3.245.1
telephony-service
max-ephones 5
max-dn 5 no-reg both
ip source-address 10.3.245.1 port 2000
timeouts interdigit 5
timeouts busy 12
system message XXXXXXXX
cnf-file location flash:
cnf-file perphone
user-locale U2 load CME-locale-pt_BR-Portuguese-8.8.2.5.tar
user-locale 2 PT
network-locale U2
load 7925 CP7925G-1.4.1SR1.LOADS
load 6941 SCCP69xx.9-2-1-0.loads
time-zone 17
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 1 dual-line
number 9001
ephone 1
mac-address D867.D9E6.F57F
ephone-template 1
type 6941
button 1:1
Solved! Go to Solution.
03-17-2013 01:25 PM
Hello Purna,
My guess is the phone is not finding the firmware file, did you put in some subdirectory of flash?
The phone tries to search the file in root flash, you could set alias with the command tftp-server to help the phone to find the firmware
In meantime do the following: debug tftp events and restart the phone, check the messages and post the results.
Mártin
03-17-2013 09:55 PM
yes actually I tried with debug tftp events but the debug shows nothing..seems the phoen even does not try to look for the firmware..actucally the firamware is in flash..not in a sub folder,
any thoughts would be really helpful ,
03-19-2013 10:50 PM
Was an issue with the TFTP IP address , we have upgraded the firmware .to ES2 , but still the issue is there even when calling within the LAN numbers....
03-20-2013 11:42 PM
Issue is still there actually..when i type
show voice register pool phone-load
it does not show the newly upgraded firmware..it is showing the previous load which was there...can i please have an advice on this ?
Purna
03-20-2013 11:55 PM
Hi ,
We have upgarded the the firmware to the 3905.9-2-2ES2 , but show voice register pool phone-load still shows the old firmware, but the phoen itself is showing the new upgraded version on the dsiplay ...any advice is highly appricated,
ADM-CME9#show voice register pool phone-load
Pool Device Name Current-Version Previous-Version
1 SEP7081053DE72F Cisco/SPA502G-7.4.8a
3 SEP34BDC8C6C412 Cisco-CP3905/9.2.1
4 SEP34BDC8C64561 Cisco-CP3905/9.2.1
5 SEP54781AE1F531 Cisco-CP3905/9.2.1
6 SEP54781AE171D2 Cisco-CP3905/9.2.1
10 SEP54781AE1F544 Cisco-CP3905/9.2.1
15 SEP1CE6C77323CD Cisco-CP3905/9.2.1
16 SEP58971E282A23 Cisco-CP3905/9.2.1
17 SEP58971E2822A8 Cisco-CP3905/9.2.1
19 SEP1CE6C77321F3 Cisco-CP3905/9.2.1
30 SEP54781AE171E2 Cisco-CP3905/9.2.1
31 SEP54781AE16FD4 Cisco-CP3905/9.2.1
32 SEP54781AE16F2F Cisco-CP3905/9.2.1
33 SEP54781A1C77FD Cisco-CP3905/9.2.1
34 SEP54781A1C77DC Cisco-CP3905/9.2.1
35 SEP54781AE17527 Cisco-CP3905/9.2.1
36 SEP54781AE17766 Cisco-CP3905/9.2.1
37 SEP54781AE1731A Cisco-CP3905/9.2.1
38 SEP54781AE08B8D Cisco-CP3905/9.2.1
39 SEP54781AE123B1 Cisco-CP3905/9.2.1
04-16-2013 11:08 AM
I know this may be a little late to respond but here it goes anyway.
If you check the phone page (put IP address of registered phone in the browser) you will see the firmware version. Like this:
In my router the print for the command "show voice register pool phone-load" is showing "Cisco-CP3905/9.2.1" too, so don't rely on this.
Mártin
