CME SIP Phone Calls in one-way (inside local network)
Martin Bauer
Hello everyone, first time here, need a little help.
I'm having some trouble to find a solution to the following problem.
Recently I've installed CME 9.1 using the router 2921. Most of the phones are SIPs, model 3905 (around 20 of them), with the last firmware updated.
Some users are complaining one way audio issue in internal calls, from a extension to another (only in sip phones)
With Wireshark capture I could see that RTP packets are being sent and receive by the router and not directly trough the phones. Is this normal in CME? When a call with problems occours (one way audio) there is no audio in one way, but router still sends confort noise packets.
Here is my config.
Thanks for any help.
Martin
##################################################################################33
System restarted at 11:29:23 BR Tue Jan 29 2013
System image file is "flash0:c2900-universalk9-mz.SPA.152-4.M2.bin"
Last reload type: Normal Reload
Last reload reason: power-on
voice service voip
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  registrar server expires max 3600 min 120
voice register global
mode cme
source-address 10.3.245.1 port 5060
max-dn 60
max-pool 70
load ATA-187 ATA187.9-2-3-1
load 3905 CP3905.9-2-1-0
authenticate realm all
timezone 17
time-format 24
date-format D/M/Y
tftp-path flash:
file text
create profile sync 0094230880392697
network-locale U1
user-locale U1 load /CME-locale-pt_BR-Portuguese-8.8.2.5.tar
ntp-server 10.3.244.7 mode directedbroadcast
voice register dn  1
number 9006
name Sala_Reuniao_02
label Sala de Reuniao 2
voice register dn  2
number 9007
name Sala_Reuniao_03
voice register dn  3
number 9008
name Sala Reuniao 04
voice register pool  1
id mac 8478.ACE6.09A2
type 3905
number 1 dn 1
template 1
codec g711ulaw
voice register pool  2
id mac 8478.ACE6.0573
type 3905
number 1 dn 2
codec g711ulaw
voice register pool  3
id mac 5897.1ECD.8F8D
type 3905
number 1 dn 3
codec g711ulaw
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.220
encapsulation dot1Q 220
ip address 10.3.245.1 255.255.255.0
ip helper-address 10.3.244.71
h323-gateway voip bind srcaddr 10.3.245.1
telephony-service
max-ephones 5
max-dn 5 no-reg both
ip source-address 10.3.245.1 port 2000
timeouts interdigit 5
timeouts busy 12
system message  XXXXXXXX
cnf-file location flash:
cnf-file perphone
user-locale U2 load CME-locale-pt_BR-Portuguese-8.8.2.5.tar
user-locale 2 PT
network-locale U2
load 7925 CP7925G-1.4.1SR1.LOADS
load 6941 SCCP69xx.9-2-1-0.loads
time-zone 17
time-format 24
date-format dd-mm-yy
max-conferences 8 gain -6
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1  dual-line
number 9001
ephone  1
mac-address D867.D9E6.F57F
ephone-template 1
type 6941
button  1:1
paolo bevilacqua
You may want to save yourself further time and go straight to the TAC with this.
The 3905 phones have already a poor reputation, if there is someone that has to get them working, that is Cisco, not the partner (or integrator).
By the way, media should not go to router in first place.
20 Replies 20
paolo bevilacqua
Looks like 3905 has some problems indeed..
Cisco TAC has provide a new firmware to SIP 3905 (3905.9-2-2ES2) that in my case solved the problem. Unfortunelly the firmware is not available to direct download.
Thanks to everyone.
Tagir Temirgaliyev
you need probably to do
voice service voip
sip
bind control source-interface  GigabitEthernet0/0.220
bind media source-interface  GigabitEthernet0/0.220
how many SIP phones possible ?
max-dn ?
max-pool ?
and how many phones possible under
telephony-service
max-ephones ?
Hi there, thanks for replys.
We are about to open a TAC to Cisco, but still trying to figure this out...
I'll try the bind command in sip and check the results.
telephony-service
max-ephones 5
max-dn 60
max-pool 70
I had a similar problem and I upgrade firmware on CP3905.9-2-2-0
  But the problem remains external call.
Hi ,
We are facing the exact same issue , and we dont find  3905.9-2-2ES2 to download in the cisco portal , please let us know if you have solved this issue with upgrade or any other chanegs that you made it working would be highly appriciated ,
Purna
Purna..
You need to open a TAC case to get the firmware...Its not available for download
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Hi ,
Yep, I got the firmaware from TAC and hoping to upgrade the firmaware tonight , will update you if there the issue is sorted completely after this
Purna
Hi Purna!
Could you, please, send me (dsoloviov@gmail.com) that great firmware for 3905?
Hello Dmytro
Cisco has a new firnware available at the download page. I believe this firmware has already the necessary correction for this problem.
You may download direct from cisco.com/download, look for the firmware cmterm-3905.9-4-1-0.cop.sgn.
Martin
  points
Hi Martin,
I'll try the official firmware version 3905.9-4-1-0 next week. But I don't see any resolved caveat regarding one-way audio in the release notes... We'll see.
Nevertheless, thanks for recommendation.
Dmytro
Ooops... I've missed some resolved caveats in the release notes:
CSCtw59242  Calls established with no audio on IP Phones 3905
CSCuc17539  3905 Phone - No audio
I think I should try 3905.9-4-1-0 ASAP
Thank you guys!
In the phone config you could insert the command "no vad" (if not yet set) in voice register pool, this doesn't help me to solved the problem, but it was a indication from Cisco TAC.
Only after firmware upgrade the issue was solved.
Godd luck at your task and let us know if it helped.
Mártin
Hi ,
I am having a real hard time upgrading these phones :I have uploaded the firmaware to flas and ,set the tftp path , and create cnf profiles and unplug the 3905 phones and plugged ..but still the 3905 phoens are not upgraded..any advice is really appricated :
voice service voip
sip
  registrar server expires max 1200 min 300
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
codec preference 6 g722-64
codec preference 7 g728
codec preference 8 g726r24
codec preference 9 g726r16
snmp-server group sla_snmp v3 auth
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps entity-sensor threshold
snmp-server host 10.236.74.91 version 3 auth sla_snmpUser1
tftp-server flash:P0030801SR02.sbn
tftp-server flash:P0030801SR02.loads
tftp-server flash:P0030801SR02.sb2
tftp-server flash:P0030801SR02.bin
tftp-server flash:P00307020200.sbn
tftp-server flash:P00307020200.loads
tftp-server flash:P00307020200.sb2
tftp-server flash:P00307020200.bin
tftp-server flash:OS79XX.txt
tftp-server flash:APP3905.9-2-2ES2.zz
tftp-server flash:CP3905.9-2-2ES2.loads
tacacs-server host 10.236.74.87 key Ulsw@2960
tacacs-server host 10.236.74.86 key Ulsw@2960
tacacs-server directed-request
mode cme
source-address 20.195.59.14 port 5060
max-dn 50
max-pool 50
load 3905 CP3905.9-2-2ES2
authenticate register
tftp-path flash:
create profile sync 0408573470766788
voice register pool  30
id mac 5478.1AE1.71E2
type 3905
number 1 dn 30
dtmf-relay rtp-nte
username 4990 password 1
description TktOffice_1
codec g711ulaw
above is my config , Please advice...
