CME SIP signalling source port
network_user
How can I change the port CME is using with UDP packets for SIP signalling? I see that the SIP packet is using source port as 5060, but after it gets encapsulated with UDP, it is using some higher port eg: 58729 and the voice provider seems to have an issue with that.
CME <IP-ADDRESS><UDP/58729>  --- SIP provider <IP-ADDRESS><5060>
SIP provider wants us to source the UDP with port 5060. How can we configure that on CME?
Thanks!
bernhardczapp
Level 4
Level 4
The command is
sip-ua
connection-reuse
You may need to restart registration after coniguring this.
