PRI GW can't incoming call
bo liu
Level 4
Level 4
hi
i config a pri GW ,the GW connect to CUCM use H323
when i call a pstn phone ,is all right
but when i call the internal call from PSTN,i will receive next  signaling
Mar 17 11:17:10.848: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0F3A
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xE9808382
Exclusive, Interface 0, Channel 2
Calling Party Number i = 0x2181, '01059631079'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, '03167153777'
Plan:ISDN, Type:Subscriber(local)
*Mar 17 11:17:10.852: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x8F3A callID = 0x0002 switch = primary-net5 interface = User
*Mar 17 11:17:10.852: ISDN Se0/0/0:15 **ERROR**: CCPMSG_InCall: ChannelID IE invalid 100(0x64) rejecting call
*Mar 17 11:17:10.852: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8F3A
Cause i = 0x80E418 - Invalid information element contents
but when i change the GW protocol to MGCP the GW is all right
next is my GW  version
Cisco IOS Software, 3800 Software (C3845-ADVENTERPRISEK9-M), Version 12.4(24)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 25-Feb-09 23:13 by prod_rel_team
ROM: System Bootstrap, Version 12.3(11r)T1, RELEASE SOFTWARE (fc1)
baihegw uptime is 2 weeks, 5 days, 10 hours, 49 minutes
System image file is "flash:c3845-adventerprisek9-mz.124-24.T.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3845 (revision 1.0) with 746495K/39936K bytes of memory.
Processor board ID FHK1413F0PZ
2 Gigabit Ethernet interfaces
31 Serial interfaces
2 Channelized/Clear E1/PRI ports
2 Channelized (E1 or T1)/PRI ports
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
250880K bytes of ATA System CompactFlash (Read/Write)
kkoeper12
Level 3
Level 3
Can you post the config and a debug of an outgoing call that works?
I am facing this issue on MGCP router .I can call out to the PSTN but incoming calls gives the same error.
I am using E1 PRI and switch type is set to EURO
Could it be because of switch type ?
