06-16-2016 12:41 AM - edited 03-17-2019 07:15 AM
Hi all,
I'm trying to set up a lab just for testing and playing around and I need some help from you people.
In one end I have a CME configured with SCCP phones. In the other end I want to configure a CME as the SIP service provider.
That means that the first CME shall register the directory numbers on the second CME.
I think that I have figured out how the first CME should be configured with SIP-ua, but I have almost no idea on how to configure the second CME as a SIP service provider.
I do know how to configure SIP functionality on a CME and I can register local SIP phones on such, but when it comes to the service provider role, then I'm a bit lost....
Remember this is for fun and training.
All help is appreciated.
Thanks in advance
Kasper
Solved! Go to Solution.
06-16-2016 03:22 AM
Your CME cant perform the service provider role. If you want to just send sip calls over to the other CME, then just have your sip phones registered to it and have a sip trunk between CME1 and CME2
06-16-2016 03:22 AM
06-16-2016 04:49 AM
Thanks a lot for the information. :-)
