05-09-2012 02:55 AM - edited 03-16-2019 11:03 AM
Hi Guys
How does SIP trunking license for CME work.For a 3925 CME to have 25 SIP trunks should I order one unit of FL-CUBEE-25(Unified Border Element Enterprise License - 25 sessions)?
Rgds
Sumesh
05-09-2012 03:39 AM
Hi Sumesh,
You need CUBE license for SIP trunk connections to SP services, not for
connections internal to the enterprise, such as CME-CUE or CUCM-CUE.
Please refer to Pg 14 for an example:
Tere.
If you find this post helpful, please rate!
05-09-2012 05:00 AM
No licensing of any kind is needed for CME to use SIP trunk.
The license FL-CUBE mentioned by testeved, is only and exclusively for IP-to-IP connections for example with CUCM, not CME.
05-09-2012 05:04 AM
CME/CUCME is the same right- Communications Manager Express?
05-09-2012 05:54 AM
Thanks for pointing out, I have corrected post above.
