CME SpeedDial softkey for 9951
CHRIS KAM
Hi All,
I have several 9951's that I've added to CME 9.0.  Users of SCCP phones are used to use the Speed Dial softkey.  I need this same functionality for these SIP phones.
I've read the Feature Policy Soft Key Control section in the Administation Guide and haven't been able to figure out how to enable the Speed Dial softkey.  I was able to manually modify the featurePolicy1.xml file which enable the Speed Dial button.  Unfortunatly once I entered the command Create Profile the file was overwritten an dresorted back to the default which removed the Speed Dial button.
What step am I missing??
Thanks in advance for your assistance!!!
Below is a portion of the relavent configuration.
voice register template  1
button-layout 1 line
button-layout 2-3 speed-dial
button-layout 4 blf-speed-dial
softkeys hold  Newcall Resume iDivert
softkeys idle  Newcall Cfwdall DND Redial
softkeys ringIn  Answer DND iDivert
softkeys seized  Endcall Meetme Cfwdall Redial Pickup Gpickup
softkeys connected  Endcall Confrn Hold Park Trnsfer iDivert
softkeys remote-in-use  Newcall Barge cBarge
conference drop-mode creator
voice register pool  5
fastdial 1 8008 name 8008
id mac 001D.70FB.4B72
type 9951
number 1 dn 5
template 1
dtmf-relay sip-notify
username C9951 password 12345
codec g711ulaw
no vad
paging-dn 25
camera
video
no keep-conference
paolo bevilacqua
Can be a bug, in which case you will have to contact Cisco TAC.
