cme-srst feature license on C2911-CME-SRST-K9
qilin zhang
Dears,
I am setting up 2911 voice bundle cme with CME-SRST-25 right-to-use license, with the IOS version
c2900-universalk9-mz.SPA.152-1.T, and I received the CME 25 seats paper license notification.
When I do a 'sh license detail' I see the cme-srst feature has a license type of 'EvalRightToUse'. Evaluation period is 8 weeks 4 days. shown as below:
StoreIndex: 7   Feature: cme-srst                        Version: 1.0
       License Type: EvalRightToUse
       License State: Active, In Use
           Evaluation total period: 8 weeks 4 days
           Evaluation period left: 8 weeks 3 days
           Period used: 24 minutes 8 seconds
           Transition date: Sep 08 2011 14:05:43
       License Count: 82/0 (In-use/Violation)
       License Priority: Low
Can anybody tell me why the cme-srst license shows evaluation and how to install the cme-srst on the router as permanent license?
Kirin
Hi Folks,
Here's the answer from Cisco Licensing on this question. This was nicely
supplied by Ian in this thread we were working on
"Licensing functionality is working as per design here.  Cme-srst licenses are honor based
and hence you have to just accept the EULA.  After the 60 days of EvalRightToUse the
license will change to "right to use" for 12 years."
https://supportforums.cisco.com/thread/2075659?tstart=0
Cheers!
Rob
8 Replies 8
pmvillarama
Please read "Activating CME-SRST Feature License" section
http://www.cisco.com/en/US/docs/routers/access/sw_activation/SA_on_ISR.html#wp1155517
regards,
Paul
Please rate helpful posts
Hi! After activate license I don't see changes....
Router#sh license
Index 3 Feature: uck9
        Period left: Life time
        License Type: Permanent
        License Count: Non-Counted
        License Priority: Medium
Router(config)#^Z
Router#show license detail cme-srst
Feature: cme-srst                        Period left: 8  weeks 1  day
Index: 1        Feature: cme-srst                          Version: 1.0
            Evaluation period left: 8  weeks 1  day
            Period used: 2  days 19 hours
            Transition date: Oct 04 2011 19:08:28
        License Count: 50/0  (In-use/Violation)
        Store Index: 6
        Store Name: Built-In License Storage
Router#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#license accept end user agreement
Router(config)#exit
        Store Index: 6
kirin,
Did you get clarification on this issue. I have the same problem.
UKEAS-2911#show license
Index 1 Feature: ipbasek9
UKEAS-2911#show license det
UKEAS-2911#show license detail cme-srst
Feature: cme-srst                        Period left: 8  weeks 3  days
            Period used: 40 minutes 12 seconds
            Transition date: Nov 21 2011 08:12:12
        License Count: 58/0  (In-use/Violation)
        Store Index: 7
I read a document which idicates that the EvalRightToUse becomes a permanent license at the end of the eval period.
This is unclear and I dont want to take the chance?
thanks
Ian.
Hello! I wait when license period will come to an end. I will write when it will come to an end and I will show result.
G00-4800-01#sh clock
12:58:44.008 MSK Thu Sep 22 2011
G00-4800-01#sh license
Index 8 Feature: cme-srst
        Period left: 1  week  5  days
        Period Used: 6  weeks 5  days
Please, can you tell us what happened after the evaluation period
jonwoloshyn
Level 4
Level 4
Cisco either need to re-write (coherently) their ISR G2 licensing with respect to CUCME and newer IOS or fix whatever bug is causing this. There is no way I am leaving a potentially ticking time bomb of 8 weeks on someones mission critical communication system. I just roll the code back to a version that takes the acceptance of the EULA.
Hi Folks,
Cheers!
Rob
Adeel S Hussain
License Type: Evaluation
License State: Active, Not in Use, EULA accepted
Evaluation total period: 208 weeks 2 days
Evaluation period left: 0 minute 0 second
License Count: 5000/0/0 (Active/In-use/Violation)
Store Index: 23
Store Name: Evaluation License Storage
Index: 2 Feature: cme-srst
Can anyone help we have this system since 2011 and all of sudden it stopped and issue CME licensing (cme-srst) feature enabled with no license installed
