CME/SRST Need to ring 50+ phones simultaneously
mario_ees
Need a push in the right direction.
Have a CUCM environment that’s works as we want.  But  when in CME/SRST mode having an issue needing to simultaneously ring 50+  phones with a full PRI normally but 8 POTS line worst case.
Each  phone has their own extension (ephone-dn) and I was trying to ring that  extension using a parallel “voice hunt-group “but of course that has a  limit of 32 extensions in the list and nesting voice hunt-groups doesn’t  appear to be supported.
Anyone have an idea on how to  do this neatly? Phones are 7965 and have 3 buttons left to play with for  shared lines and such. Any ideas or direction are greatly appreciated.  Thank you
To better answer your question please describe the current setup in CUCM for this specific use case in as much detail as possible.
First thing that pops up in my head is the use of shared line. But that might change after you describe your setup in CUCM.
Please rate all useful posts.
Response Signature
Nested hunt groups should be supported in CME. Set the final destination to point at the pilot of the next hunt pilot. See more in this post, https://supportforums.cisco.com/thread/2130704
Response Signature
