CME upgradation
purvrv
Hi Team,
We are having Cisco CME with OS version 15.3 and CME version 10.0 . Current version 10.0 is not supported with 78XX series phone with 15.3 OS and i need to upgrade the OS. I am planning to upgrade the same on 10.5.. Can someone help me with the procedure whether i need to upgrade only OS same as normal router or other steps are invovled?
Thanks is Adance..!!
Yes, just upgrade the IOS and you will get the corresponding CME version.
See the mapping matrix between IOS and CME
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/33matrix.html
@Syed
Level 3
Level 3
