CME with PRI
j.huizinga
Level 6
Level 6
I have a very weird thing
CME 2811 with a PRI line. When the CME is called from a mobile or land line (within the country) everything works fine.
When the originator is from abroad the call is not successful. What I see is that when a call is coming from abroad, the ISDN message TX -> ALERTING is missing.
Example from a land line within the country calling the customer:
Jul 14 14:55:20.345: ISDN Se0/3/0:15 Q931: RX <- SETUP pd = 8  callref = 0x000F
    Sending Complete
    Bearer Capability i = 0x8090A3
        Standard = CCITT
        Transfer Capability = Speech
        Transfer Mode = Circuit
        Transfer Rate = 64 kbit/s
    Channel ID i = 0xA98386
        Exclusive, Channel 6
    Calling Party Number i = 0x0180, '*** Land Line number ****'
        Plan:ISDN, Type:Unknown
    Called Party Number i = 0x81, '*** Customer number ***'
Jul 14 14:55:20.381: ISDN Se0/3/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x800F
 Jul 14 14:55:20.393: ISDN Se0/3/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x800F
    Progress Ind i = 0x8188 - In-band info or appropriate now available
Jul 14 14:55:24.701: ISDN Se0/3/0:15 Q931: TX -> CONNECT pd = 8  callref = 0x800F
Jul 14 14:55:24.705: ISDN Se0/3/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x000F
Example from a international number calling the customer:
Jul 14 14:48:34.800: ISDN Se0/3/0:15 Q931: RX <- SETUP pd = 8  callref = 0x000B
    Sending Complete
        Standard = CCITT
    Channel ID i = 0xA98384
        Exclusive, Channel 4
    Calling Party Number i = 0x0180, '*** International Number ***'
Jul 14 14:48:34.820: ISDN Se0/3/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x800B
Jul 14 14:48:34.820: ISDN Se0/3/0:15 Q931: TX -> CONNECT pd = 8  callref = 0x800B
Jul 14 14:48:34.828: ISDN Se0/3/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x000B
The ISDN message are going from TX->CALL_PROC directly to TX->CONNECT, skips the TX -> ALERTING
Behind this is a provider with a SIP trunk, and they say because of this they miss the SIP 180 RINGING, and call fails.
I have never seen this, any idea?
JH
Nadeem Ahmed
What is the IOS version? secondly  alerting are optional without this call be setup, Yes certainly with alerting message you will see this behavior and corresponding inter-operability message would missed that.
can you please provide us the exact call-flow. assuming this is incoming call
Users-----PSTN-------PRI------GW--SIP--CUCM----Phone
Br,
nadeem
Br, Nadeem Please rate all useful post.
Hello Nadeem,
The configuration is like this:
Provider-----E1 PRI--------CME
For the CME there is only a PRI, and SCCP phones. This configuration has worked for at least 7 years with another provider.
IOS version: c2800nm-ipvoicek9-mz.124-15.T7.bin
Only when the CME receives a call from abroad, the CME doesn't send back an ALERTING
Jan
This is strange behavior for me as well. Try to configure the global command "voice call send-alert" and the command "progress_ind alert enable 8" under your pots dialpeer.
Hi Jan,
I have always had some tweaking required with various International Callers / International Calling.
I would request you to try changing the Incoming Calls with International (calling number) to
        Plan:Unknown, Type:Unknown
