CMR output does not match CMR definition V10 and V11
dcomber76
I'm working with importing CMR files into a DB for later processing. I created all the tables based on CMR definitions found here
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/service/10_0_1/cdrdef/CUCM_BK_CBB143DE_00_cucm-cdr-administration-guide-100/CUCM_BK_CBB143DE_00_cucm-cdr-administration-guide-100_chapter_0111.html
and
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/service/11_0_1/cdrdef/CUCM_BK_RFDE0054_00_cucm-cdr-administration-guide-1101/cisco_call_management_record_field_descriptions.html
Then I noticed that the fields do not match at all... I mean at all. I've obtained 3 sample CMR's from 3 different systems (3 client builds) and all have the exact same CMR fields.
The CMR definitions have loads about video but in reality the output has nothing at all.
Is there anything we are missing on the CUCM config side? Samples are obtained on the CAR portal.
Sample Definition
cdrRecordType cdrRecordType
globalCallID_callManagerId globalCallID_callManagerId
globalCallID_callId globalCallId_callId
orignodeId nodeId
destnodeId directoryNumber
origlegcallIdentifier callIdentifier
destlegidentifier dateTimeStamp
orignumberPacketsSent numberPacketsSent
orignumberOctetsSent numberOctetsSent
orignumberPacketsReceived numberPacketsReceived
orignumberOctetsReceived numberOctetsReceived
orignumberPacketsLost numberPacketsLost
destnumberPacketsSent jitter
destnumberOctetsSent latency
destnumberPacketsReceived pkid
destnumberOctetsReceived directoryNumberPartition
destnumberPacketsLost globalCallId_ClusterId
origjitter deviceName
destjitter varVQMetrics
origlatency duration
destlatency videoContentType
pkid videoDuration
origdeviceName numberVideoPacketsSent
destdeviceName numberVideoOctetsSent
origvarVQMetrics numberVideoPacketsReceived
destvarVQMetrics numberVideoOctetsReceived
globalCallId_ClusterID numberVideoPacketsLost
callingPartyNumber videoAverageJitter
finalCalledPartyNumber videoRoundTripTime
callingPartyNumberPartition videoOneWayDelay
finalCalledPartyNumberPartition videoTransmissionMetrics
  videoReceptionMetrics
  videoContentType_channel2
  videoDuration_channel2
  numberVideoPacketsSent_channel2
  numberVideoOctetsSent_channel2
  numberVideoPacketsReceived_channel2
  numberVideoOctetsReceived_channel2
  numberVideoPacketsLost_channel2
  videoAverageJitter_channel2
  videoRoundTripTime_channel2
  videoOneWayDelay_channel2
  videoReceptionMetrics_channel2
  videoTransmissionMetrics_channel2
Manish Gogna
Can you check if the following service parameter is set to "Enabled Regardless of CDR Enabled Flag" on cucm
Clusterwide Parameters (Device - General)
Manish
Thanks Manish,
That flag was off, I have enabled it.
Do I need to restart any services to see a change in the file. how long do I need to wait to see the extra details..
assuming as this was off I will need to make some test calles or wait til tomorrow for the extra data to come through, unless by magic Cisco has the details cached
This will only apply to the new calls now. No services need to be restarted. You should be able to see the results tomorrow if CDR Load happens at midnight. If it is 24*7 then you can check it today as well after an hour or so.
Manish
ok many thanks.. will see how it goes
