Collaboration between CME with CUCM in BE6k
Hi All,
I have some problems with configuration when i want to add BE6k with CUCM. Currently i have one Cisco 2821 as my CME with many users registered on it. and now my companies buy a new one BE6k and my Boss said want to combine the existing with the new one. Is it possible ? or i have to migration all users into BE ?
thanks in advance
17 Replies 17
Dear, As I said in last post there are two options..you can put the same type of configuration in another router which is located at the location where CUCM/BE6K is. Or please contact your network team to do the same, just you need to tell the them one command "option 150 ip 10.10.10.99" they will do for you.
Suresh
Hi Suresh,
Thank you for helping me so far, fyi the router that i configure as CUCM gateway is the same router with CME, as i said first time, i have existing CME than i added a new BE6k as a new cluster with same infrastructure.
So i use same vlan also same POE switch, that's why i'm so confuse how could the BE6k users get the configuration on each ip phones.
Dear,
In that case, I think you need to assign TFTP IP address of CUCM or CME to IP phones manually.
Suresh
