I have integrated my CUCM 8.6 with the microsoft LYNC server for internal calling, which is working fine. But at the LYNC sever, we are getting warning and the warning is :
Log Name: Lync Server
Source: LS Mediation Server
Date: 5/1/2012 10:58:32 AM
Event ID: 25073
Task Category: (1030)
Level: Warning
Keywords: Classic
User: N/A
Computer:
Description:
The Mediation Server service has received a call that does not support comfort noise. This event is throttled after 5 calls from a single Gateway peer.
The Mediation Server service has received a call that does not support comfort noise from the Gateway peer, 172.29.58.151
Cause: The Gateway peer does not support comfort noise.
Resolution:
Please ensure the comfort noise option on the Gateway has been enabled.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="LS Mediation Server" />
<EventID Qualifiers="33798">25073</EventID>
<Level>3</Level>
<Task>1030</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2012-05-01T05:28:32.000000000Z" />
<EventRecordID>1074</EventRecordID>
<Channel>Lync Server</Channel>
<Security />
</System>
<EventData>
<Data>172.29.58.151</Data>
</EventData>
</Event>
172.29.58.151 is my CUCM IP address.
does call manger have any option like that?
Pawan Arora
