Communication Manager 6.1.2 - Multiple File Upload
Adam Stauffer
Is there no way to upload multiple files to the TFTP server in version 6? Have to add all my ringtones and background images to all 4 of my servers, ouch.
gogasca
Level 10
Level 10
Mmm...the only workaround I can think of is to get root access and use an application like WinSCP...
axg85429
From TAC:
Limitation is due to that fact that every time you upload a file into CUCM that file is checked to see that it is not a hazard for the system integrity. That’s why the “PUT” command for TFTP has been disabled with clients and CLI.
Product Request for Enhancement Number CSCtb11452. Which is not yet implemented
You may save it in your profile to be notfied when it is implemented.
