Compatability Check of any IP Phone with CallManager Versions
Jeylinux4Cisco
Hello There,
May i know, where do we check the Compatability of day-by-day New versions of Phone with all generations of CUCM's?
For example, I want to check if the Cisco 9971 Phon will work with Old CallManager 4.0 or not..
Bala
Anas Abueideh
Level 9
Level 9
kindly find the below link
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_device_support_tables_list.html
you can find the compatability information for each CME version.
for 9971 it is supported starting from CME 8.5
Anas
please rate if it is helpful
Aaron Harrison
See the data sheet for whatever phone you are interested in, e.g.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps10453/ps10512/data_sheet_c78-565717.html
Halfway down you'll see:
Unified Communications Manager Support
• Cisco Unified Communications Manager version 7.1(3a)SU1 or later
– Some features require more recent version of UC Manager and Dev Pack support. Please check the release notes for more information
• Survivable Remote Site Telephony (SRST) version 4.3 or later
• CME 8.6 or later
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Rob Huffman
Hi Bala,
In addition to the great tips from Anas & Aaron (+5 each)
I've attached a pretty good doc below that has these details
Cheers!
Rob
"What you don't have you don't need it now"
- U2
