Compatibility check on DX80
Karthika
Hi All,
Good Day
I would need some assistance on checking the DX80 latest firmware compatibility for CUCM 10.5.2.
I would need to perform  the firmware upgrade for DX80 device.
CUCM version - 10.5.2SU4
And i can see  the latest firmware available on the Cisco site for DX80 is - " CE9.5.0 " .
Wanted to know if this is compatible with the device / also with the CUCM version .
Karthika
Based on the below release notes, the 9.5 firmware is both compatible with DX80 as well as CUCM version 10.5.2 and above.
https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/software/ce9/release-notes/ce-software-release-notes-ce9.pdf
Carlo
Please rate all helpful posts "The more you help the more you learn"
Carlo
