11-27-2023 08:41 AM
We came across weird issues. Computers connected to Switch are not working correctly when connected via cisco desk phone - showing unidentified network. Without desk phone computers working fine. Issue started +- a week ago.
port config
interface GigabitEthernet1/0/22
switchport access vlan 20
switchport mode access
switchport nonegotiate
switchport voice vlan 40
switchport port-security maximum 2
switchport port-security violation restrict
switchport port-security aging time 2
switchport port-security aging type inactivity
spanning-tree portfast
spanning-tree bpduguard enable
Phone type: CP-8841
More than one computer & desk phone is impacted.
switch - cisco WS-C3850-48P - 16.12.07
CUCM - System version: 14.0.1.12900-161
Any suggestion's will be highly appreciated. Thank you
11-27-2023 09:24 AM
You have tried removing the Phone the PC works, Have you tried Phone alone without PC ? is the phone works.
For testing remove the Security configuration and test it or increase the maximum to 5 and age timing to higher.
11-28-2023 01:28 AM
Phone connected on its own is working fine. Tested with internal and external calls.
Port-security was changed.
switchport port-security maximum 5
switchport port-security aging time 5
11-28-2023 08:32 AM
So by changing to 5 is that fixed or still have issue.
if that is resolved make this as solution.
11-28-2023 08:33 AM
Still the issue.
11-28-2023 08:50 AM
ok can you post show interface configuration again.
other question in week time what was changed ? any DHCP changes ?
PC get IP address from right VLAN ? are you able to ping Local Gateway and 8.8.8.8 ?
11-28-2023 10:20 AM
No changes to the network.
Stack of 4 switches. Only one switch is impacted (*1 Active).
Switch# Role Mac Address Priority Version State
*1 Active 12 V05 Ready
2 Standby 11 V07 Ready
3 Member 10 V07 Ready
4 Member 9 V07 Ready
11-28-2023 12:07 PM
Please reload switch 1 than send the output of a show port security and a show version
Carlo
11-29-2023 03:00 AM - edited 11-29-2023 03:02 AM
Port security was disabled but the same issue present:
sh port-security int g1/0/22
Port Security : Disabled
Port Status : Secure-down
Violation Mode : Shutdown
Aging Time : 0 mins
Aging Type : Absolute
SecureStatic Address Aging : Disabled
Maximum MAC Addresses : 1
Total MAC Addresses : 0
Configured MAC Addresses : 0
Sticky MAC Addresses : 0
Last Source Address:Vlan : 682c.7b40.7401:640
Security Violation Count : 12
11-29-2023 03:07 AM
As I can see now the port config has maximum mac set to 1
Please increase the value and perform a shutdown no shutdown for that port
Please let us know
Carlo
11-29-2023 03:20 AM
Port security is disabled:
port config
11-27-2023 11:16 AM - edited 11-27-2023 11:17 AM
To verify the correct behavior of the switch side, you can issue the show port-security command and see if the count of Security Violations increases.
Please let us know.
Carlo
11-28-2023 01:28 AM
Port Security : Enabled
Port Status : Secure-up
Violation Mode : Restrict
Aging Time : 5 mins
Aging Type : Inactivity
Maximum MAC Addresses : 5
Total MAC Addresses : 2
Security Violation Count - doesn't increases
11-28-2023 02:46 AM
Select one pc and check it mac
The do
Show mac address <pc mac>
Show port-secuirty mac
Check if pc show in other ports.
11-28-2023 08:57 AM
Do you check points I ask?
The show port security show two mac connect
Can I see
Show mac interface x
I need to see which vlan assign for both mac
