04-20-2018 12:13 PM - edited 03-17-2019 12:40 PM
Hello Guys,
I want to setup conference call system in my office using CUCM. This will allow us to call vendors or they can call our line during a conference meeting.
Currently we have a Cisco ISR 4321 with a 1MFT-T1/E1 module and a PVDM4-32 module
We also got a 10 channel E1-PRI trunk from our provider.
I want to know if conference call will work using CUCM and other components we have and how i can achieve this.
Really need your assistance guys.
Solved! Go to Solution.
04-23-2018 05:18 AM
04-21-2018 12:39 AM
04-23-2018 02:14 AM
We have a PVDM4-32 (32-channel DSP module). Currently i just need the processes on how to get this working. Done a lot of research but i need a step by step process to help my research.
04-21-2018 04:07 AM
Mate, I am with Nipun on this one, sure you can add additional PVDMs to your ISR or add an ISR solely for CFB resources, but the options are very limited.
Break down options to your decsiion makers on CMS and webex. these are more suted and allow scheduling as well.
04-21-2018 08:00 AM
Are you looking for ability to have scheduled conferences or just ad-hoc conferencing initiated by internal phones?
If scheduled then you'll need conferencing solution such as CMS, if ad-hoc you can utilize either PVDM based conferencing or CUCM based (G711 only). If you are on version 11.0+ you can implement "Conference-Now" feature which is basically "poor man's conference bridge" i.e. enhanced MeetMe.
04-23-2018 02:21 AM
We want to initiate conference calls via our cisco 4321 ISR gateway to a PSTN.
The voice gateway has a NIM-1MFT-T1/E1 module and a PVDM4-32 module.
We have CUCM 11.5 so we just want to initiate conference calls with clients and need process to go about it.
04-23-2018 05:18 AM
04-23-2018 05:36 AM
Hello Nipun, I made a mistake with that.
Kindly find below a list of what we have
*cisco 4321 ISR
*NIM-1MFT-T1/E1 module - installed on the ISR
*PVDM4-32 module. - - installed on the ISR
*CUCM 11.5
We are getting a E1-PRI line from our provider with 10 channels which is our connection to the pstn
04-23-2018 05:37 AM
04-27-2018 06:50 AM
04-27-2018 09:47 AM - edited 04-27-2018 09:47 AM
The PVDM is on the NIM itself -
NAME: "NIM subslot 0/1", DESCR: "NIM-1MFT-T1/E1 - T1/E1 Serial Module"
PID: NIM-1MFT-T1/E1 , VID: V05 , SN: FOC21506B0X
NAME: "subslot 0/1 db module 0", DESCR: "PVDM4-32 Voice DSP Module"
PID: PVDM4-32 , VID: V02 , SN: FOC2203694S
I would suggest getting another PVDM for your media resources that will go on the chassis itself.
