Conference call
ermionline
HI all
I have cucm 9.1 which is working properly. how can i make someone call and connect to conference call from his/her mobile phone.
please help
thanks
Brandon Pierce
Level 4
Level 4
There are several methods to doing this, most involve more than just a CUCM.  First, you could setup a Meet-Me and have a primary DID inbound forwarded to the Meet-Me. (Privileges with forwarding assumed here) Second, you could have them dial you directly and then forward them into the meet-me number.  Third, you could start an ad-hoc conference and bridge everyone in manually.  What you are looking for I think, is a 1-800 number solution in which WebEx would be your best bet.
Thanks Brandon for your quick reply, that was so helpful. but can i make external calls to be directly forwarded to my meet me number
Yes, either you assign a DID to the meet-me, or simply configure a call forward behavior from a PSTN reachable number to meet-me
java
if this helps, please rate
Thanks but i couldnt forward a PSTN reachable number to my meet-me number.
