conference call
can any body explains this commands how it work and how to enable in router
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 3
associate application SCCP
dspfarm profile 2 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
ericdolton
That is part of the IOS based conference bridge configuration.  In short, cisco call manager software conference bridges can only do G.711ulaw, so in order to allow callers requiring G.729 or any other codec (see the list of codecs above) to join a conference call, you need to setup a hardware based conference bridge on a router with DSP's.   This hardware bridge will register with call manager and be assigned to mrg's and mrgl's. The max sessions will vary depending on how many DSP you have available in your router.
This link explains it in detail.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a008084fe1f.shtml
hi
we are using in these commands in srst router 2921 can you send link of these router
these configuration we can use srst router and call manger also
