IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6147 Views
  • 14 replies
Most of our sites make use of Shared lines for incoming calls from the public which works great when all the phones are registered to our CUCM but when we loose our WAN and drop into E-SRST not all the phones configured with the Shared Lines will rin...
I recently acquired 2 8841s and 1 8851 and have noticed an issue:   On the 8841s, when the screen turns off due to inactivity, it is completely dark - like it would be if no power was supplied to the phone.   One the 8851 though, when the screen turn...
cbpapi by Level 1
  • 485 Views
  • 2 replies
We have 2 presence servers, HQ-PRESENCE1 and HQ-PRESENCE2, in different locations.  There are expired certs on each that expired in Dec 2017.  I havent been able to find any reliable docs on what certs need to be regenerated in what order and then wh...
mramirez-t by Level 1
  • 6777 Views
  • 12 replies
Having an issue with an existing setup.  4 analog lines into an FXO with a SIP connection back to Call Manager.   PSTN --> FXO --> SIP --CUCM The four lines are setup by the carrier as a hunt group.  The main line can no longer ring in.  When dialed,...
Hi all,    Wonder if someone could help me.  I have an issue where external calls through CUCM across a SIP T to 3rd party IVR.  Call ends up at a Cisco phone.  When the agent hits the transfer button, the call drops.  Message on Cisco phone is "Tran...
Stuart C by Level 1
  • 4174 Views
  • 7 replies
