Conference configuration assistance in CME
nrramos
I am configuring the CME to enable conferencing. I get <0-0> when I try to configure max sessions, which means I can't have conferencing. I have enough DSPs. Please see the below (truncated) config.
voice-card 0
dspfarm
dsp services dspfarm
no local-bypass
tftp-server flash:apps41.8-3-2-27.sbn
tftp-server flash:cvm41sccp.8-3-2-27.sbn
tftp-server flash:dsp41.8-3-2-27.sbn
tftp-server flash:jar41sccp.8-3-2-27.sbn
tftp-server flash:SCCP41.8-3-3S.loads
tftp-server flash:term41.default.loads
tftp-server flash:term61.default.loads
sccp local FastEthernet0/0.2
sccp ccm 10.4.3.1 identifier 1 version 4.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 2 register transcode
associate profile 1 register mtp001d70103e30
keepalive retries 5
dspfarm profile 2 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec ilbc
codec g723r63
codec g723r53
codec gsmamr-nb
maximum sessions 2
associate application SCCP
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
shutdown
telephony-service
sdspfarm units 1
Appreciate if someone could help me out.
Thanks.
Chad Stachowicz
Level 6
Level 6
I would tend to say you do not have enough DSP's. What DSP modules are in the router and what cards are in the router. sh tech please.
Chad
Chad Stachowicz
Level 6
Level 6
Chad
i have to agree with Chad most probably not enough DSPs, if possible also post the sh run.
rememember, conferencing takes a WHOLE dsp
ie: if you have 15 channels to spare... that won't do since you need the whole 16 channels
issue a sh voice dsp to see how many channels are already allocated
java
if this helps, please rate
java
