Conference List Error phone 8945, 9971
mrmhar1408
Level 4
Level 4
Hi guys,
I have a problem in phone models 8945 and 9971 that when they establish a conference and i want to see the conference list
I press the "View Details" button but it gives me "Telephone Server Unavilable"
Any idea why i get this error althoug i configured the feature control policy and assign it to 9971
Do these phone models have any locale installed on them? If yes, can you share the detailed ccm trace for a test call with details of parties involved in the call and time stamp. I have seen similar issue where the locale file installed was corrupted and had to be reinstalled. The traces will show if its an issue with locale or something else.
Manish
11 Replies 11
Joseph Martini
What firmware version is running on the 8945 and 9971?
I have this firmware for 8945 ----> SCCP8941_8945.9-3-2-11
firmware for 9971 -----> sip9971.9-3-2-10
What kind of conference is this??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
mrmhar1408
Level 4
Level 4
I do ad hoc conference
Sent from Cisco Technical Support Android App
There are a couple of bugs for 89XX and 99XX series IP phones like the one below
https://tools.cisco.com/bugsearch/bug/CSCuj82851/?reffering_site=dumpcr
894x Phones[Call Initiator]does not display Participant's list in Conf
Can you try the workaround listed in the bug and see if the issue goes away.
Manish
Dear Manish,
Thanks for your help but i already have the service parameter "Always display Original Dialled Number" is disabled.
Can you share the 'exact' error message that appears on the phone display?
Manish
once i press "View Details" on phone model 8945 which is the initiator of the conference
it gives message " Telephone service is unavailable"
Note: i can view the list if i press view details on phone 6921, i have this prob. only with phone models 9971 & 8945
Manish
Yes Manish, you are great i have two locale one is the default "English" and the one i installed is "arabic"
the phone was on the installed locale one "Arabic" when i changed to default "English" the phone now shows the details and the participants
So what the required Action to do it with "Arabic" Locale ??
Manish Gogna
I'm glad that it helped. I would suggest a reinstall of Arabic locale, restart TFTP service and reset the phones. It should take care of the issue.
Manish
