09-03-2016 01:07 AM - edited 03-17-2019 08:01 AM
hi alll
I have configured conference now on cucm 11.0. it is working fine from the inside network. But outside people cannot join the conference even if i make the did publicly reachable no. can anyone help me with this problem????????????????
09-03-2016 06:07 AM
can you describe what happens in detail, try calling the number from your cell phone and see if you are hearing any error announcements, also what is the call flow, example ITSP -- SIP Trunk -- CUBE --- SIP Trunk -- CUCM
JB
09-04-2016 12:32 AM
The message i hear if i configure the DID with pubic no. is a voice "the network is busy now. please try later". which is from the SP.
the flow is SERVICE PROVIDER ISDN NTK > CODEC > GATEWAY ROUTER > CUCM
09-03-2016 12:44 PM
What troubleshooting have you done? and what codec are you trying to use from the PSTN??
09-04-2016 12:30 AM
First it is not PSTN on the other end it is ISDN. about the codec, since it is in a client's premises i will check tomorrow and let you know.
The message i hear if i configure the DID with pubic no. is a voice "the network is busy now. please try later". which is from the ISP.
as per tried troubleshooting
1. I created a new cti route and forwarded to the conference now DID. but this dznt work. though the route is working when i change the forwared DN to another DN
2. I created a translation pattern.. it wont work either.
09-04-2016 09:39 AM
Start by runnings debugs at the GW to find out if the call is making it that far, you should see a disconnect reason to get some more clues.
If you're getting a message from the telco, the call might not be even making it to CUCM or your GW.
