SIP-Incoming Call Fail
ilana_ilana
Hello all,
One of our client is having CUCM with H.323 GW.
Recently they got SIP trunk from service provider. SIP trunk will be used only for incoming calls.
Currently Incoming calls are failing with error " SIP/2.0 488 Not Acceptable Media ".
From search I found, this error relates to codec mismatch, I have configured codecs but not able to find out where is the issue:
Following is the output of debug voice ccapi inout and ccsip messages output and attached is show run.
Router#
*Sep 4 13:47:00.115: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:0135109595@192.168.3.2:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 94.77.211.70:5060;branch=z9hG4bKbjimje00do6g75jrv1p1.1
Call-ID: 5NAln2qVnY05QvIaesjSB2vthp2VQe9LKhQjfY5LiRn08lN2iarKjWM0ijac@zteims
From: <sip:0115111262@ims.go.net.sa;user=phone>;tag=ztesipERZbsFRE-t5K4dfbg.4
To: <sip:0135109595@172.26.32.40;user=phone>
CSeq: 1000 INVITE
P-Asserted-Identity: <sip:0115111262@ims.go.net.sa;user=phone>
Privacy: none
Allow: INVITE,PRACK,ACK,CANCEL,BYE,UPDATE,OPTIONS
Max-Forwards: 69
P-Charging-Vector: icid-value=004-18e5a9c8-923-172.26.32.130
Content-Type: application/sdp
Content-Length: 211
Content-Disposition: session
Supported: 100rel, early-session
Contact: <sip:0115111262@94.77.211.70:5060;zte-did=4-0-560-J;transport=udp>
v=0
o=- 526323468 526323468 IN IP4 94.77.211.70
s=-
c=IN IP4 94.77.211.70
t=0 0
m=audio 23388 RTP/AVP 18 96
a=rtpmap:18 G729/8000
a=rtpmap:96 telephone-event/8000
a=fmtp:96 0-15
a=sendrecv
a=ptime:20
*Sep 4 13:47:00.115: %VOICE_IEC-3-GW: SIP: Internal Error (INVITE, codec mismatch): IEC=1.1.278.7.110.0 on callID 59
*Sep 4 13:47:00.119: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:0135109595@172.26.32.40;user=phone>;tag=2FF708-2EA
Date: Sun, 04 Sep 2016 13:47:00 GMT
CSeq: 1000 INVITE
Allow-Events: telephone-event
Warning: 304 192.168.3.2 "Media Type(s) Unavailable"
Reason: Q.850;cause=65
Server: Cisco-SIPGateway/IOS-15.2.4.M4
Content-Length: 0
*Sep 4 13:47:00.131: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:0135109595@192.168.3.2:5060;user=phone SIP/2.0
CSeq: 1000 ACK
Max-Forwards: 69
Content-Length: 0
Router#
Can any body advise where is the issue ?
Manish Gogna
Hi Ilana,
You may try the following:
Set the codec on dial-peers for these incoming calls from the provider to G711  and on cucm, set the region setting between IP phones and this gateway to G711 as well. You may use G729 as well but please ensure the codec is the same throughout the call flow. Reset the SIP trunk after any changes and try again. If the call fails please post complete "debug ccsip messages" output for a failed call
6 Replies 6
Manish Gogna
Hi Ilana,
Hi Manish,
How to reset SIP Trunk in VG? There is no SIP Trunk between CUCM & VG
Call Manager & GW are configured as H323. Gateway is having SIP - PRI from Telco provider.
Debugs shared above are complete output of "debug ccsip messages" and "debug voice ccapi inout".
From incoming call logs (PSTN to Call Manager) and show run shared above, can you confirm the incoming dial-peer and codecs are configured proper in voice gateway ?
Received:
CSeq: 1000 INVITE
Privacy: none
Max-Forwards: 69
Content-Length: 211
v=0
s=-
t=0 0
a=fmtp:96 0-15
a=sendrecv
a=ptime:20
Sent:
CSeq: 1000 INVITE
Content-Length: 0
Received:
CSeq: 1000 ACK
Max-Forwards: 69
Content-Length: 0
If the gateway is added as H323 on cucm then reset the h323 gateway on cucm after making any changes. As per the SIP INVITE the call is being requested to be set up on G729 codec, so try setting the G729 codec on the dial-peers on gateway and on region settings between IP phones and H323 gateway on cucm. You may also add transcoders in the MRGL of IP phones and H323 gateway so that it can be allocated depending on which side requests the transcoder.
One more thing that you can check o gateway is if the following is added:
voice service voip
allow-connections sip to h323
allow-connections h323 to sip
allow-connections sip to sip
Manish
Manish
Emanuel
Hi Team
Please can you support me see my configuration
ACRouter#sh run
ACRouter#sh running-config
Building configuration...
Current configuration : 36314 bytes
! No configuration change since last restart
version 15.5
hostname ACRouter
boot-start-marker
boot-end-marker
enable password jxxxxxxxx
aaa new-model
aaa accounting connection h323 start-stop group radius
--More--  !
aaa session-id common
ethernet lmi ce
ip dhcp excluded-address 10.10.10.1
ip domain name Cisco.local
ip name-server 8.8.8.8
ip name-server 8.8.4.4
no ip mfib
--More--  ip cef
ipv6 multicast rpf use-bgp
no ipv6 cef
template 1
crypto pki trustpoint TP-self-signed-2092191672
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2092191672
revocation-check none
rsakeypair TP-self-signed-2092191672
crypto pki certificate chain TP-self-signed-2092191672
certificate self-signed 01
--More--   3082024D 308201B6 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32303932 31393136 3732301E 170D3137 31313239 31363131
32335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 30393231
39313637 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100CA4A 8CD81DFA 0DB29A36 A8B0B597 DCDEA3BC 67821C09 97710D04 CD77CBA3
DBA12908 FF3A3937 5412AEB7 CAACF992 4F9CBDD4 B0003142 0C621DF5 64267011
FBC9D216 EE287B32 40767958 173EDE05 3F82B082 07CF4570 B39FC01A CD18C0F3
A3A4301D 32A4A1D1 442D7254 CED776E8 49E4D52A B551944A 860D8156 7EED3D7D
250D0203 010001A3 75307330 0F060355 1D130101 FF040530 030101FF 30200603
551D1104 19301782 15526F75 7465722E 796F7572 646F6D61 696E2E63 6F6D301F
0603551D 23041830 16801410 3AA052E0 80BB6AD1 74BFDCCA F4F09498 0669B630
1D060355 1D0E0416 0414103A A052E080 BB6AD174 BFDCCAF4 F0949806 69B6300D
06092A86 4886F70D 01010405 00038181 003891EB 2DD65324 E7305D75 FC3DCD42
09E6F908 3421FC84 E1653E71 46404D09 14E35001 6BD504C7 3AEE4C77 A820EB8C
43D24E36 547CACE8 3F470258 E7792913 60EC751F 99BE34F7 44A314A6 96E3AA90
7E103649 FC5CA1AE F6A93C4A F50F1E15 4AB46E7A 0D4B305E 40751049 A31DA513
B91DE126 30D57ACD 46D838C4 48749DFA B0
quit
voice-card 0
--More--  !
voice service voip
ip address trusted list
no ip address trusted authenticate
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
sip
session transport tcp
registrar server
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
--More--  !
voice class e164-pattern-map 1
e164 027251051[0-9]
voice register global
mode cme
source-address 192.168.5.1 port 5060
timeouts interdigit 3
max-dn 30
max-pool 30
timezone 18
date-format D/M/Y
tftp-path flash:
create profile sync 000554821263375A
voice register dn 2
number 5325
pickup-call any-group
pickup-group 1
name Jean Akunyo
--More--   label Jean x 5325
voice register dn 3
number 5332
pickup-group 1
name Deo
label Deo x 5332
voice register dn 5
number 5456
pickup-group 1
name Ndo
label Ndo x 5456
voice register dn 6
number 5361
pickup-group 1
name IT Support
label IT Support x 5361
--More--  voice register dn 7
number 5316
pickup-group 1
name Janet
label Janet x 5316
voice register dn 8
number 5455
pickup-group 1
name Anipha
label Anipha x 5455
voice register dn 10
number 5400
pickup-group 1
name Office of Registrar
label Office of Registrar x 5400
voice register dn 11
number 5482
--More--   pickup-call any-group
pickup-group 1
name DATA ENTRY
label DATA ENTRY x 5482
voice register dn 12
number 5322
pickup-group 1
name George Zziwa
label George x 5322
voice register dn 13
number 5481
pickup-group 1
name John Bayo
label John x 5481
voice register dn 14
number 5300
pickup-group 1
--More--   name Reception
label Reception x 5300
voice register dn 16
number 5458
pickup-group 1
name Fatma Sefsaf
label Fatma x 5458
voice register dn 17
number 5303
pickup-group 1
name Leon Kpaossou
label Leon x 5303
voice register dn 18
number 5450
pickup-group 1
name Victor Lowilla
label Victor x 5450
--More--  !
voice register dn 19
number 5462
pickup-group 1
name Legal Interns
label Legal Interns x 5462
voice register dn 20
number 5380
pickup-group 1
name Julius Onesmo 5380
label Dr Julius x 5380
voice register dn 21
number 5330
pickup-group 1
name Saif Rouis
label Saif Rouis x5330
voice register dn 23
--More--   number 5461
pickup-group 1
name Micha Wiebusch
label Micha x 5461
voice register dn 24
number 5460
pickup-group 1
name Raymond Diouf
label Raymond x 5460
voice register dn 25
number 5350
pickup-group 1
name Gate 1
label Gate 1 x 5350
voice register dn 26
number 5451
--More--   pickup-group 1
name Aliou Diallo
label Aliou x 5451
voice register dn 27
number 5431
pickup-group 1
name Abu E. Suleiman 5431
label Abu x 5431
voice register dn 28
number 5438
pickup-group 1
name Simon Adon 5438
label Simon x 5438
voice register pool 2
busy-trigger-per-button 2
id mac 00CC.FC17.BB5D
session-transport tcp
type 7821
--More--   number 1 dn 2
dtmf-relay rtp-nte sip-kpml
voice-class codec 1
voice register pool 3
id mac 00CC.FC17.A7E5
type 7821
number 1 dn 3
voice-class codec 1
voice register pool 5
id mac 00CC.FC17.E070
type 7821
number 1 dn 5
voice-class codec 1
voice register pool 6
--More--   busy-trigger-per-button 2
id mac 00CC.FC17.B95A
type 7821
number 1 dn 6
cor incoming MidUser default
voice-class codec 1
voice register pool 7
id mac 00CC.FC17.BB3F
type 7821
number 1 dn 7
voice-class codec 1
voice register pool 8
id mac 00CC.FC17.E0A1
type 7821
--More--   number 1 dn 8
voice-class codec 1
voice register pool 10
id mac D0EC.3585.B241
type 7821
number 1 dn 10
voice-class codec 1
voice register pool 11
id mac 00CC.FC17.B99B
type 7821
number 1 dn 11
voice-class codec 1
--More--  voice register pool 12
id mac 00CC.FC17.E05A
type 7821
number 1 dn 12
voice-class codec 1
voice register pool 13
id mac 00CC.FC17.E0A9
type 7821
number 1 dn 13
voice-class codec 1
voice register pool 14
id mac 00CC.FC17.BB54
--More--   type 7821
number 1 dn 14
cor incoming Reception default
voice-class codec 1
voice register pool 16
id mac 00CC.FC17.E089
type 7821
number 1 dn 16
voice-class codec 1
voice register pool 17
id mac 00CC.FC17.E019
type 7821
number 1 dn 17
--More--   voice-class codec 1
voice register pool 18
id mac 00CC.FC17.E04A
type 7821
number 1 dn 18
voice-class codec 1
voice register pool 19
id mac 00CC.FC17.B960
type 7821
number 1 dn 19
voice-class codec 1
voice register pool 20
--More--   id mac 00CC.FC17.E025
type 7821
number 1 dn 20
cor incoming giz default
voice-class codec 1
dnd
voice register pool 21
id mac 00CC.FC17.E093
type 7821
number 1 dn 21
voice-class codec 1
voice register pool 23
id mac D0EC.3585.B18C
--More--   type 7821
number 1 dn 23
voice-class codec 1
voice register pool 24
id mac D0EC.3585.B4A0
type 7821
number 1 dn 24
voice-class codec 1
voice register pool 25
id mac D0EC.3585.B44F
type 7821
number 1 dn 25
--More--   dtmf-relay rtp-nte sip-kpml
voice-class codec 1
voice register pool 26
id mac D0EC.3585.B243
type 7821
number 1 dn 26
voice-class codec 1
voice register pool 27
id mac D0EC.3585.B2F1
type 7821
number 1 dn 27
voice-class codec 1
--More--  voice register pool 28
id mac 00CC.FC17.B957
type 7821
number 1 dn 28
voice-class codec 1
voice logout-profile 1
pin 1687
user cisco password cisco
number 2301 type normal
voice user-profile 1
pin 1687
user 2301 password 2301
voice translation-rule 1
rule 1 /^88\(.........\)/ /\1/
--More--  !
voice translation-profile SIP_1
translate calling 1
license udi pid CISCO2951/K9 sn FTX1431AHLU
license boot module c2951 technology-package uck9
hw-module ism 0
hw-module pvdm 0/0
hw-module pvdm 0/1
object-group service RDP
description rdp
dial-control-mib retain-timer 35791
dial-control-mib max-size 500
username admin privilege 15 secret 5 $1$Zizm$4L3HHmMTIGPAVC3hMJoTv1
--More--  username gael privilege 15 secret 5 $1$Xm26$sefkTpHU2635StmLQ.efd0
username juka001 privilege 15 secret 5 $1$uMY3$hKi01usUyoPFn/vj0A.eF0
username Cisco password 0 jkEAC123
redundancy
gw-accounting aaa
acct-template callhistory-detail
gw-accounting syslog
gw-accounting file
primary ftp 10.201.0.3 username african-court\juka001 password bananarrow700
maximum buffer-size 15
maximum retry-count 3
maximum fileclose-timer 300
maximum cdrflush-timer 245
cdr-format compact
interface Embedded-Service-Engine0/0
--More--   no ip address
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface ISM0/0
no ip address
!Application: CUE Running on ISM
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.1
description DATA
encapsulation dot1Q 2
ip address 10.201.0.3 255.255.0.0
no ip redirects
no ip unreachables
no ip proxy-arp
--More--   ip flow egress
ip nat inside
ip virtual-reassembly in
interface GigabitEthernet0/1.2
description VOICE
encapsulation dot1Q 3
ip address 192.168.5.1 255.255.255.0
ip helper-address 10.201.1.1
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow egress
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.5.1
interface GigabitEthernet0/1.3
encapsulation dot1Q 1 native
interface GigabitEthernet0/1.4
interface GigabitEthernet0/1.5
--More--   description SAP
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow egress
ip nat inside
interface GigabitEthernet0/2
ip address 10.70.97.46 255.255.255.252
duplex auto
speed auto
interface ISM0/1
description Internal switch interface connected to Internal Service Module
no ip address
interface Vlan1
no ip address
router rip
network 192.168.0.0
no auto-summary
--More--  !
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
ip flow-top-talkers
top 50
sort-by packets
cache-timeout 30000
match source address 10.201.0.0 255.255.0.0
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip nat inside source list 2 interface GigabitEthernet0/1 overload
ip nat inside source list 101 interface GigabitEthernet0/0 overload
ip nat inside source list 102 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 41.220.138.1
ip route 10.2.0.0 255.255.0.0 10.201.0.10
ip route 10.7.8.193 255.255.255.255 10.70.97.45
ip route 10.7.8.194 255.255.255.255 10.70.97.45
--More--  ip route 10.7.8.195 255.255.255.255 10.70.97.45
ip route 10.10.0.0 255.255.0.0 10.201.0.10
ip route 10.21.0.0 255.255.0.0 10.201.0.10
ip route 10.70.97.0 255.255.255.0 10.70.97.45
ip route 10.101.0.0 255.255.0.0 10.201.0.10
ip route 10.102.0.0 255.255.0.0 10.201.0.10
ip route 10.103.0.0 255.255.0.0 10.201.0.10
ip route 10.104.0.0 255.255.0.0 10.201.0.10
ip route 10.105.0.0 255.255.0.0 10.201.0.10
ip route 10.110.0.0 255.255.0.0 10.201.0.10
ip ssh rsa keypair-name sshkey
ip ssh version 2
logging trap debugging
logging host 192.168.0.13
nls resp-timeout 1
cpd cr-id 1
snmp-server community public RO
tftp-server flash:sip78xx.12-0-1-11.loads
tftp-server flash:rootfs78xx.12-0-1-11.sbn
tftp-server flash:rootfs2.78xx.12-0-1-11.sbn
--More--  tftp-server flash:kern78xx.12-0-1-11.sbn
tftp-server flash:kern2.78xx.12-0-1-11.sbn
tftp-server flash:sboot2.78xx.12-0-1-11.sbn
radius server cas
address ipv4 10.201.1.3 auth-port 1645 acct-port 1646
key 9876543210
control-plane
voice-port 0/0/0
connection plar opx 1102
caller-id enable
voice-port 0/0/1
connection plar opx 1100
caller-id enable
voice-port 0/0/2
connection plar opx 1201
--More--   caller-id enable
voice-port 0/0/3
caller-id enable
voice-port 0/1/0
caller-id enable
voice-port 0/1/1
caller-id enable
voice-port 0/1/2
connection plar opx immediate 1100
caller-id enable
voice-port 0/1/3
caller-id enable
voice-port 0/2/0
--More--   connection plar opx 1814
caller-id enable
voice-port 0/2/1
voice-port 0/3/0
voice-port 0/3/1
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
--More--  dial-peer cor custom
name emerg
name national
name international
name giz
name Registrar
name Reception
name President
dial-peer cor list national
member national
dial-peer cor list international
member international
dial-peer cor list emerg
member emerg
dial-peer cor list giz
member giz
dial-peer cor list basic
--More--  !
dial-peer cor list basicUser
member emerg
dial-peer cor list MidUser
member emerg
member national
dial-peer cor list supperuser
member emerg
member national
member Reception
dial-peer cor list Registrar
member Registrar
dial-peer cor list Reception
member emerg
member national
member Reception
--More--  dial-peer cor list President
member President
dial-peer voice 1 pots
paramspace callsetup after-hours-exempt FALSE
fax rate disable
no digit-strip
no register e164
preemption level flash-override
dial-peer voice 2 pots
corlist outgoing national
description TTCL
preference 4
destination-pattern 90[2-9]........$
port 0/0/3
prefix 0
dial-peer voice 3 pots
corlist outgoing Reception
description Reception 0732979509
preference 2
--More--   destination-pattern 190T
port 0/0/1
prefix 0
dial-peer voice 5 pots
corlist outgoing Registrar
description Registrar 0732979506
destination-pattern 1230T
port 0/0/2
prefix 0
dial-peer voice 6 pots
description TTCL
destination-pattern 90[1-9]........$
port 0/1/0
prefix 0
dial-peer voice 7 pots
description TTCL
port 0/1/1
--More--   prefix 0
dial-peer voice 8 pots
description Airtel Line
destination-pattern 9078........$
port 0/1/2
prefix 078
dial-peer voice 4 pots
corlist outgoing President
description President 0732979553
port 0/0/0
prefix 0
dial-peer voice 10 pots
corlist outgoing giz
description GIZ 0736500423
destination-pattern 90T
port 0/2/0
prefix 0
--More--  dial-peer voice 11 voip
description AFRICAN_UNION_HQ_ASTERISK
destination-pattern 4...
session protocol sipv2
session target ipv4:10.110.20.61
session transport udp
voice-class codec 1
dtmf-relay sip-notify sip-kpml sip-info rtp-nte
no vad
dial-peer voice 9 voip
destination-pattern 2...
voice-class codec 1
no vad
dial-peer voice 13 voip
destination-pattern 5...
voice-class codec 1
--More--   dtmf-relay sip-notify sip-kpml sip-info rtp-nte
no vad
dial-peer voice 14 voip
destination-pattern 7...
voice-class codec 1
no vad
dial-peer voice 20 voip
description Incoming Call from SIP Trunk TTCL
destination-pattern 5360
session target ipv4:10.7.8.193
incoming called-number 027251051[0-9]$
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte sip-notify sip-kpml
no vad
dial-peer voice 21 voip
--More--   description **Outgoing Call to SIP Trunk TTCL**
destination-pattern 0[1-9]........$
signaling forward none
voice-class codec 1
voice-class sip url tel
voice-class sip rel1xx supported "100rel"
no voice-class sip pass-thru content unsupp
dial-peer voice 25 voip
description **outgoing TTCL trunk test**
translation-profile outgoing SIP_1
preference 1
destination-pattern 88T
voice-class codec 1
dtmf-relay rtp-nte
no vad
--More--  !
sip-ua
retry invite 3
retry response 3
retry bye 3
retry cancel 3
timers trying 1000
registrar dns:10.7.8.193 expires 3600
sip-server dns:10.7.8.193
presence enable
gatekeeper
no shutdown
telephony-service
authentication credential juka001 jk@EAC123
em keep-history
em logout 20:0 23:0
fxo hook-flash
--More--   max-ephones 80
max-dn 100
ip source-address 192.168.5.1 port 2000
system message African Court
url directories http://192.168.5.1/localdirectory
url services http://192.168.5.1/CCMUser.html
url authentication http://192.168.5.1/CCMCIP/authenticate.asp juka001 jk@EAC123
time-zone 18
max-conferences 8 gain -6
web admin system name juka001 password jk@EAC123
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
login timeout 120 clear 23:00
after-hours block pattern 2 90T
after-hours day Sun 19:00 23:59
after-hours day Mon 19:00 23:59
after-hours day Tue 19:00 23:59
after-hours day Wed 19:00 23:59
after-hours day Thu 19:00 23:59
after-hours day Fri 19:00 23:59
after-hours day Sat 19:00 23:59
--More--   night-service day Sun 08:00 07:59
night-service day Mon 17:00 07:59
night-service day Tue 17:00 07:59
night-service day Wed 17:00 07:59
night-service day Thu 17:00 07:59
night-service day Fri 16:00 07:59
night-service day Sat 08:00 07:59
directory entry 4 1402 name Henry Innocent
directory entry 5 1403 name George Zziwa
create cnf-files version-stamp 7960 Nov 27 2024 11:54:48
ephone-template 1
softkeys idle Redial Newcall Cfwdall Pickup Gpickup Dnd
softkeys ringing Answer Dnd
after-hours exempt
type 6921
ephone-dn 1 dual-line
number 2701
label Conf1 x 2701
name Conference 1
--More--   corlist incoming supperuser
ephone-dn 2 dual-line
number 2702
label Conf2 x 2702
name Conference 2
ephone-dn 3 dual-line
number 5320
label Mathias x 5320
description Mathias Bakareke 5320
name Mathias Bakareke
corlist incoming MidUser
ephone-dn 4 dual-line
number 5321
label Henry x 5321
description Henry Innocent 5321
name Henry Innocent
ephone-dn 5 dual-line
number 5420
label Adjei x 5420
description Justice Adjei 5420
name Dennis Adjei
ephone-dn 6 dual-line
number 5323
label Ahmed x 5323
description Ahmed Isse 5323
name Ahmed Isse
ephone-dn 7 dual-line
number 5431
label Abu x 5431
description Abu E. Suleiman 5431
--More--   name Abu Suleiman
ephone-dn 8 dual-line
number 5452
label Dr Horace x 5452
description Horace Adjolohoun 5452
name Horace Adjolohoun
ephone-dn 11 dual-line
number 5312
label Ngarhasta x 5312
description Ngarhasta Neldjingar 5312
name Ngarhasta Neldjingar
ephone-dn 12 dual-line
number 5314
label Elizabeth x 5314
--More--   description Elizabeth Mupako 5314
name Elizabeth Mupako
ephone-dn 13 dual-line
number 5410
label Faraji x 5410
description Faraji Mtolela 5410
name Faraji Mtolela
corlist incoming basicUser
ephone-dn 14 dual-line
number 5315
label Florence x 5315
description Florence Ayuma 5315
name Florence Ayuma
ephone-dn 15 dual-line
number 5439
--More--   label Kuto x 5439
description Dr Kuto 5439
name Emmanuel Kuto
ephone-dn 16 dual-line
number 5313
label Winfield x 5313
description Winfield Musiime 5313
name Winfield Musiime
ephone-dn 17 dual-line
number 5370
label Chipiliro x 5370
description Chipiliro Kansilanga 5370
name Chipiliro Kansilanga
ephone-dn 18 dual-line
--More--   number 5463
label Serge x 5463
description Prof. Serge 5463
name Prof. Serge Fred
ephone-dn 19 dual-line
number 1999
label Leon x 1999
description Office 99 1999
name Office 99
ephone-dn 20 dual-line
number 5301
label President x 5301
description Court President 5301
name President
--More--  ephone-dn 21 dual-line
number 5426
label Ondo x 5426
description Justice Ondo 5426
name Justice Ondo
ephone-dn 22 dual-line
number 5422
label Chizumila x 5422
description Justice Tujilane Chizumila 5422
name Tujilane Chizumila
ephone-dn 23 dual-line
number 5427
label Anukam x 5427
description Justice Anukam 5427
name Stella Anukam
ephone-dn 24 dual-line
number 1505
--More--   label yy x 1505
description yy ww 1505
name yy ww
ephone-dn 25 dual-line
number 5421
label Ben Kioko x 5421
description Justice Ben Kioko 5421
name Ben Kioko
ephone-dn 26 dual-line
number 1507
label Gerald x 1507
description Justice Gerard Niyungeko 1507
name Gerard Niyungeko
ephone-dn 27 dual-line
number 5429
label Dumisa x 5429
description Justice Dumisa Buhle Ntsebeza 5429
--More--   name Dumisa Ntsebeza
ephone-dn 28 dual-line
number 5425
label Rafaa x 5425
description Justice Rafaa Achour 5425
name Rafaa Achour
ephone-dn 29 dual-line
number 5428
label Modibo x 5428
description Justice Modibo Sacko 5428
name Modibo Sacko
ephone-dn 30 dual-line
number 5430
label Emmanuel x 5430
description Emmanuel Agbor 5430
name Emmanuel Agbor
--More--  !
ephone-dn 31 dual-line
number 5431
label Abu x 5431
name Abu Suleiman
ephone-dn 32 dual-line
number 5433
label Alfred x 5433
description Alfred Fang 5433
name Alfred Fang
ephone-dn 33 dual-line
number 5434
label Balbina x 5434
description Balbina Varela 5434
name Balbina Varela
--More--   corlist incoming MidUser
ephone-dn 34 dual-line
number 5435
label Eileen x 5435
description Eileen A. Ongeso 5435
name Eileen Ongeso
ephone-dn 35 dual-line
number 5436
label Khaled x 5436
description Khaled Salem 5436
name Khaled Salem
ephone-dn 36 dual-line
number 5437
label Manuelina x5437
description Manuelina Calima 5437
--More--   name Manuelina Calima
ephone-dn 37 dual-line
number 5432
label Aboudou x 5432
description Aboudou Akouba 5432
name Aboudou Akouba
ephone-dn 38 dual-line
number 5371
label Romaric x 5371
description Romaric Bi 5371
name Romaric Bi
ephone-dn 39 dual-line
number 5402
label Grace x 5402
--More--   description Grace Wakio 5402
name Grace Wakio
corlist incoming Registrar
ephone-dn 40 dual-line
number 5311
label Martha x 5311
description Martha Asante 5311
name Martha Asante
ephone-dn 41 dual-line
number 5411
label Nailejileji x 5411
description Nailejileji Mollel 5411
name Nailejileji Mollel
ephone-dn 42 dual-line
number 5459
--More--   label Mwiza x 5459
description Mwiza Nkhata 5459
name Mwiza Nkhata
ephone-dn 43 dual-line
number 5470
label Fidelis x 5470
description Fidelis Katonga 5470
name Fidelis Katonga
ephone-dn 44 dual-line
number 5480
label Milka x 5480
description Milka Mkemwa 5480
name Milka Mkemwa
ephone-dn 45 dual-line
--More--   number 1999
label Office99 x 1999
name Office 99
ephone-dn 46 dual-line
number 5471
label Levina x5471
description Levina Mosha 5471
name Levina Mosha
ephone-dn 47 dual-line
number 5472
label Haule x 5472
description Haule Augustino 5472
name Haule Augustino
--More--  ephone-dn 48 dual-line
number 5381
label Elline M x 5381
description Elline Magohe 5381
name Elline Magohe
ephone-dn 49 dual-line
number 5302
label Germaine x 5302
description Germaine Nzimpora 5302
name Germaine Nzimpora
ephone-dn 50 dual-line
number 5324
label Kipturu x 5324
description Kipturu Lopunei 5324
name Kipturu Lopunei
--More--  !
ephone-dn 51 dual-line
number 5401
label Dr.Robert x 5401
description Dr. Robert 5401
name Dr Robert
ephone-dn 53 dual-line
number 5400
description Office of Registrar 5400
corlist incoming Reception
ephone-dn 54 dual-line
number 5360
label Julius x 5360
description Julius Kamya 5360
name Julius Kamya
--More--  !
ephone-dn 55 dual-line
number 5424
label Tchikaya x 5424
description Blaise Tchikaya 5424
name Blaise Tchikaya
ephone-dn 56 dual-line
number 5331
label Kenneth x 5331
description kenneth Mwaine 5331
name Kenneth Mwaine
ephone-dn 57 dual-line
number 5441
label Simba x 5441
description Simba Tamambele 5441
name Simba Tamambele
ephone-dn 58 dual-line
number 5352
label Stephen x 5352
description Stephen Makule 5352
name Stephen Makule
ephone-dn 59 dual-line
number 5350
label Gate 1 x 5350
description Gate 1 5350
name Gate 1
ephone-dn 60 dual-line
number 5440
label Niyonkuru x 5440
description Emmanuel Niyonkuru 5440
--More--   name Emmanuel Niyonkuru
ephone-dn 61 dual-line
number 5453
label Meredith x 5453
description Meredith Lwanga 5453
name Meredith Lwanga
ephone-dn 62 dual-line
number 5351
label Kwame x 5351
description Keddey Kwame 5351
name Keddey Kwame
ephone-dn 63 dual-line
number 5457
label Cheikhna L x 5457
--More--   description Cheikhna Lefghih 5457
name Cheikhna Lefghih
ephone-dn 64 dual-line
number 5317
label Douglas T x 5317
description Douglas Tholo 5317
name Douglas Tholo
ephone-dn 65 dual-line
number 5423
label Chafika x 5423
description Justice Chafika 5423
name Chafika Bensaoula
ephone-dn 66
number 2230
--More--   label willbard
name Willbard
ephone 1
mac-address 0004.F2F5.6444
ephone-template 1
type 7937
button 1:1
ephone 2
mac-address 0004.F2F5.7DC8
ephone-template 1
type 7937
button 1:2
ephone 3
mac-address 20BB.C0DD.E59A
ephone-template 1
--More--   after-hours exempt
type 6921
button 1:3
ephone 4
mac-address 20BB.C0DD.E6EA
ephone-template 1
type 6921
button 1:4
ephone 5
mac-address 20BB.C0DD.E72A
ephone-template 1
type 6921
button 1:5
ephone 6
--More--   mac-address 20BB.C0DD.E1E4
ephone-template 1
type 6921
button 1:6
ephone 7
mac-address 20BB.C0DD.E4A2
ephone-template 1
type 6921
ephone 8
mac-address 20BB.C0DD.E56E
ephone-template 1
type 6921
button 1:8
ephone 9
--More--   mac-address 20BB.C0DD.E773
ephone-template 1
type 6921
ephone 11
mac-address 20BB.C0DD.E1C1
ephone-template 1
after-hours exempt
type 6921
button 1:11
ephone 12
mac-address 20BB.C0DD.E1AB
ephone-template 1
after-hours exempt
type 6921
button 1:12
--More--  !
ephone 13
mac-address 20BB.C0DD.DA6B
ephone-template 1
type 6921
button 1:13
ephone 14
mac-address 20BB.C0DD.E17D
ephone-template 1
type 6921
button 1:14
ephone 15
mac-address 20BB.C0DD.E177
ephone-template 1
after-hours exempt
type 6921
button 1:15
--More--  !
ephone 16
mac-address 20BB.C0DD.DF99
ephone-template 1
after-hours exempt
type 6921
button 1:16
ephone 17
mac-address 20BB.C0DD.E18A
ephone-template 1
type 6921
button 1:17
ephone 18
mac-address 20BB.C0DD.E1CE
ephone-template 1
type 6921
button 1:18
ephone 19
mac-address 20BB.C0DD.DE9D
ephone-template 1
after-hours exempt
type 6921
missed-calls all
button 1:19
ephone 20
mac-address 20BB.C0DD.E174
ephone-template 1
after-hours exempt
type 6921
button 1:20
--More--  !
ephone 21
mac-address 20BB.C0DD.E73F
ephone-template 1
type 6921
button 1:21
ephone 22
mac-address 20BB.C0DD.E66D
ephone-template 1
type 6921
button 1:22
ephone 23
mac-address 20BB.C0DD.E1C2
ephone-template 1
type 6921
button 1:23
--More--  !
ephone 24
mac-address 20BB.C0DD.E18E
ephone-template 1
type 6921
button 1:24
ephone 25
mac-address 20BB.C0DD.E1D9
ephone-template 1
type 6921
button 1:25
ephone 26
mac-address 20BB.C0DD.E149
ephone-template 1
type 6921
--More--   button 1:26
ephone 27
mac-address 20BB.C0DD.E1D3
ephone-template 1
type 6921
button 1:27
ephone 28
mac-address 20BB.C0DD.E187
ephone-template 1
type 6921
button 1:28
ephone 29
mac-address 20BB.C0DD.E128
ephone-template 1
--More--   type 6921
button 1:29
ephone 30
mac-address 20BB.C0DD.E529
ephone-template 1
after-hours exempt
type 6921
button 1:30
ephone 31
mac-address 20BB.C0DD.D833
ephone-template 1
after-hours exempt
type 6921
button 1:31
--More--  ephone 32
mac-address 20BB.C0DD.DF39
ephone-template 1
after-hours exempt
type 6921
button 1:32
ephone 33
mac-address 20BB.C0DD.D94D
ephone-template 1
after-hours exempt
type 6921
button 1:33
ephone 34
mac-address 20BB.C0DD.DC22
ephone-template 1
after-hours exempt
type 6921
--More--   button 1:34
ephone 35
mac-address 20BB.C0DD.E3F1
ephone-template 1
type 6921
button 1:35
ephone 36
mac-address 20BB.C0DD.E4DF
ephone-template 1
type 6921
button 1:36
ephone 37
mac-address 20BB.C0DD.E6A0
ephone-template 1
--More--   type 6921
button 1:37
ephone 38
mac-address 20BB.C0DD.E4CA
ephone-template 1
type 6921
button 1:38
ephone 39
mac-address 20BB.C0DD.E6DF
ephone-template 1
after-hours exempt
type 6921
button 1:39
ephone 40
--More--   mac-address 20BB.C0DD.E507
ephone-template 1
type 6921
button 1:40
ephone 41
mac-address 20BB.C0DD.E377
ephone-template 1
type 6921
button 1:41
ephone 42
mac-address 20BB.C0DD.E47B
ephone-template 1
after-hours exempt
type 6921
button 1:42
--More--  !
ephone 43
mac-address 20BB.C0DD.E522
ephone-template 1
after-hours exempt
type 6921
button 1:43
ephone 44
mac-address 20BB.C0DD.DA4D
ephone-template 1
type 6921
button 1:44
ephone 45
mac-address 20BB.C0DD.E557
ephone-template 1
type 6921
button 1:45
--More--  !
ephone 46
mac-address 20BB.C0DD.E524
ephone-template 1
after-hours exempt
type 6921
button 1:46
ephone 47
mac-address 20BB.C0DD.E503
ephone-template 1
type 6921
button 1:47
ephone 48
mac-address 20BB.C0DD.D744
ephone-template 1
--More--   type 6921
button 1:48
ephone 49
mac-address 20BB.C0DD.DDD9
ephone-template 1
after-hours exempt
type 6921
button 1:49
ephone 50
mac-address 20BB.C0DD.DE24
ephone-template 1
after-hours exempt
type 6921
button 1:50
--More--  ephone 51
mac-address F029.29E2.F777
ephone-template 1
after-hours exempt
type 7965
button 1:51
ephone 53
mac-address 20BB.C0DD.DDA3
ephone-template 1
after-hours exempt
type 6921
button 1:53
ephone 54
mac-address F029.29E2.FBEF
ephone-template 1
after-hours exempt
type 7965
--More--   button 1:54
ephone 55
mac-address 20BB.C0DD.DDE9
ephone-template 1
after-hours exempt
type 6921
button 1:55
ephone 56
mac-address 20BB.C0DD.E1C6
ephone-template 1
after-hours exempt
type 6921
button 1:56
ephone 57
--More--   mac-address 20BB.C0DD.D6EA
ephone-template 1
after-hours exempt
type 6921
button 1:57
ephone 58
mac-address 20BB.C0DD.DF25
ephone-template 1
after-hours exempt
type 6921
button 1:58
ephone 59
mac-address 20BB.C0DD.E16A
ephone-template 1
type 6921
button 1:59
--More--  !
ephone 60
mac-address 20BB.C0DD.E0B6
ephone-template 1
type 6921
button 1:60
ephone 61
mac-address 20BB.C0DD.E180
ephone-template 1
after-hours exempt
type 6921
button 1:61
ephone 62
mac-address 20BB.C0DD.E160
ephone-template 1
after-hours exempt
--More--   type 6921
button 1:62
ephone 63
mac-address 20BB.C0DD.E5CF
ephone-template 1
after-hours exempt
type 6921
button 1:63
ephone 64
mac-address 20BB.C0DD.E1B9
ephone-template 1
after-hours exempt
type 6921
button 1:64
--More--  ephone 65
mac-address 20BB.C0DD.D960
ephone-template 1
after-hours exempt
type 6921
button 1:65
ephone 68
after-hours exempt
vstack
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
--More--   stopbits 1
line 195
no exec
transport input all
In what way does your “question” match with the topic of the OP? Apart from that what is your ask? You only listed your whole configuration, but from what I can tell no actual question. Advise you to create a new post and clearly outline what it is that you’d need assistance with. Also please do not post any big output of text directly into the post as it makes the post very difficult to read. It’s better if you add that as an attachment in a text file.
Response Signature
ok thank sir
