Conference phone Daisy Chain Kit. CP-8832-DC=
Need a question answered if anyone knows the answer? Is it possible to connect a CP8832 conference phone to a CP8851 IP Phone using the CP8832 Daisy Chain Kit?
Jaime Valencia
That has not been tested and would not be supported, the daisy chain kits are specifically for the conference devices.
java
if this helps, please rate
Chris Deren
Technically that would work, but I would never recommend it as things like QoS, etc. would not work correctly.
