08-03-2009 02:13 AM - edited 03-15-2019 07:11 PM
Hi Netpro's
I have a UCM 7 system with 2 central servers. All 7 remote sites break out of the PSTN when making calls to other sites.
My problem is this, we have a meetme number of 1900 which is a member of one partition that is allocated to our central site.
How can I make our other sites access the 1900 via our WAN so that all remote users can use the 1900 number for conferencing??
As we don't have QOS on our network Its important that all (except for 1900 conference number) pass over the PSTN.
do I need to create a seperate partiton and CSS? or am i barking up the wrong tree.
Thanks in advance
Rod
08-03-2009 02:33 AM
Silly me,
After reading the admin guide I found that if you don't select any partition in the meetme number config option all sites automatically have access to the number !!!
problem resolved.
08-03-2009 06:19 AM
Yes, that's correct.
If you only want calls to the meet-me DN to traverse the WAN create a separate partition and make sure that's the only one everyone can reach.
java
if this helps, please rate
