IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6151 Views
  • 14 replies
Hi Netpro'sI have a UCM 7 system with 2 central servers. All 7 remote sites break out of the PSTN when making calls to other sites.My problem is this, we have a meetme number of 1900 which is a member of one partition that is allocated to our central...
Hii have configured some ATA with two ports .users are using analog device,and now they are complanining that if they hold one line ,they can hear the voice chat of other device whihc is connected wioth this ATA.i configured ata second port with 01...
Dear All,We are using the Cisco UCM version 7.1.1. We are facing the issue with the Conference Utilization report in CDR. In conference utilization report it is showing 0% for all the dates. It is not showing any % of utilization. Does anyone know wh...
rajupawar by Level 1
  • 549 Views
  • 2 replies
To all CUCM gurus,My customer would like to know which logs of the CUCM RTMT contains the below activities?· Call Forward All via CUCM Web by Administrator · Transfer the call by UsersAs for the Call Forward All, can my customer even see which Admi...
huntlee by Level 1
  • 1172 Views
  • 1 replies
Dear Buddy, i'm doing a testing with "auto qos".I have cisco ISR routers of series 2821 and 2811.We are using 512/128/64 leased line link for connectivity with routers in remote location.Voice is already implemented on FXO or E1. Here we a...
siddindia by Level 1
  • 276 Views
  • 1 replies
Hi I am learning VOIP and truing to set up a lab , I found this server and I would like to install CM, my question is can I do that ?what CM Ver. do I need ?what os needed to be install on dl320 before I install CM ?any wite paper or how too for this...
Hi,On a 3750 access switch the auto-qos voip trust command output differs in 12.2(44)SE2 and 12.2(46)SE.In the latter version the command "priority-queue out" is not automatically generated but can be included manually. I would suggest this command i...
Hye friendsI am using CCM 6 and UCCX 7. i am facing one problem in my call center that when any one calls me from outside on my call center, the CLI comes with zero for example the person number is 66405404 so this number comes like that on my CLI 06...
